Tracking Hub / Studio Manager 1.8.1
Release Date: 2026-04-20
These are the release notes for Tracking Hub and Studio Manager version 1.8.1. This document describes the user-visible changes that have been made to the software since release 1.8.0.
New Features / Improvements
Bug Fixes
Minimum Hardware Configuration
Minimum 16 GB Ram
Dual-Core Intel CPU
10 GB of free disk space
NVIDIA P2000 Graphics Card
OpenGL Hardware-accelerated Graphics Card
Info: Minimal Hardware Configuration provides sufficient resources for running a Tracking Hub configuration.
The new automated lens file calibration introduced with this version requires additional GPU processing power. To benefit from this feature, use the Recommended Hardware Configuration.
HP Z4 G4 - 12-Core CPU
64 GB Ram
2x Gbit RJ45
30 GB of free disk space
NVIDIA RTX 4000 Ada
Setup Required for NDI Workflow
HP Z4 G4 - 6-Core CPU
32 GB Memory
2x Gbit RJ45
256 GB SSD for OS
512 GB SSD for Data
NVIDIA RTX A4000 /16 GB GDDR6
Supported Drivers and Software
This software has been tested to run on:
Windows 11 LTSC 64-bit.
Windows 10 LTSC 64-bit.
Viz Engine 5.0 or later.
Service Host 2.1.
Version 5.46 for Plura PCL-PCI and PCL-PCIe (LV, 3G) timecode reader cards (available on the Vizrt FTP in Vizrt Drivers/Alperman PCL).
Sealevel SeaIO 5.1.3
WIBU Codemeter 8.30a. The driver is included in the installation package.
AI Core v2.2
This software has been tested with Viz Arc 2.1.1 or higher.
Certified Tracking Systems
Shotoku
Motion Analysis
NCam
Egripment (Trackmen)
StypeKit
Vinten
Free-D
StarTracker
Vicon tracking system
XPecto
Thoma
BlackCam
Spidercam FrameB
Sony BRC X1000/800
Sony ILME-FR7
Sony BRC-AM7
Sony OCELLUS
Panasonic AW-UE 150
Panasonic AW-UE 100
Vizrt PTZ3 UHD+
Vizrt PTZ3 HD
Canon CR-N500
Canon CR-N300
Known Issues
Note: Viz Virtual Studio 1.8.1 comes with AI Core 2.2. In case other AI components like Reality Connect or Viz AI Keyer are installed, make sure they run on the latest version.
NDI
Security Updates Windows 11 – KB5063878 and Windows 10 – KB5063709 can lead to traffic drops in NDI output.
Installation
Administrator privileges are required to install Tracking Hub/Studio Manager.
If the license dongle driver reports errors, please uninstall and reinstall the driver manually.
Note: Issues have been reported with failing redistributable updates on Windows 10. This can lead to Tracking Hub not starting properly. In case this happens:
Ensure there is no Microsoft update in queue or in progress (if you are not sure, reboot Windows).
Manually uninstall any MS Visual C++ 2015-2022 Redistributables (both x86 and x64) and restart.
Manually install the MS Visual C++ V14 Redistributable (both x86 and x64) and restart.
Install VizVirtualStudioBundle-x64-1.8.1.
Note: Issues have been reported with failing redistributable updates on Windows 10 and Windows 11 related to Microsoft Visual C++ v14 Redistributable 14.50.35719. The Bundle installer will print an error after installation if this redistributable is already installed on the PC. Options to prevent this error:
Uncheck redist option in bundle if it is already installed.
Uninstall Microsoft Visual C++ v14 Redistributable 14.50.35719 before starting the bundle installer.
Tracking Hub / Studio Manager 1.8.0
Release Date: 2025-09-11
These are the release notes for Tracking Hub and Studio Manager version 1.8.0. This document describes the user-visible changes that have been made to the software since release 1.7.1.
New Features
Minimum 16 GB Ram
Dual-Core Intel CPU
64 GB Ram
2x Gbit RJ45
NVIDIA RTX 4000 Ada
32 GB Memory
2x Gbit RJ45
256 GB SSD for OS
512 GB SSD for Data
Service Host 2.1.
Shotoku
Motion Analysis
NCam
StypeKit
Vinten
Free-D
StarTracker
XPecto
Thoma
BlackCam
Spidercam FrameB
Sony BRC X1000/800
Sony ILME-FR7
Sony BRC-AM7
Panasonic AW-UE 150
Panasonic AW-UE 100
Vizrt PTZ3 UHD+
Vizrt PTZ3 HD
Canon CR-N500
Canon CR-N300
Known Issues
NDI
Installation
Documentation
Documentation for Tracking Hub and Studio Manager are available at the Vizrt Documentation Center:
Support
