Tracking Hub / Studio Manager 1.9.0
Release Date: 2026-11-19
These are the release notes for Tracking Hub and Studio Manager version 1.9.0. This document describes the user-visible changes that have been made to the software since release 1.8.1.
New Features / Improvements
KeySummary
VIZVS-3974Reset a Lens Point
VIZVS-3969Perspective camera control
VIZVS-3946Adapt VIPS Airpixel protocol
VIZVS-3896redesign Trackingflow Analyzer
VIZVS-3884Renaming camera services
VIZVS-3883XR Color Correction within Studio Manager
VIZVS-3872Support of OpenTrackIO
VIZVS-3847FBX Export
VIZVS-3781Auto alignment of videowall - Stage1
VIZVS-3755Load, save, edit lens calibration files
VIZVS-3746VideoWall Editor UI
VIZVS-3738Modifier Tool for new Lens files
VIZVS-3492To display only the specified cameras in the Studio Manager.
Bug Fixes
KeySummary
VIZVS-4047Tracking Hub: "Calc Nodalpoint into position" is ignored for multi-camera services
VIZVS-4045DOF from the lens file changes while zooming
VIZVS-4033Studio Manager memory leak
VIZVS-4026Tracking Hub crashes when a TC camera service is added
VIZVS-4007SM freezes when shutting down a lens calibration
VIZVS-3986Tracking Hub can close by itself when a camera service is deleted while its engine is not connected
VIZVS-3961NDI service: first START sends the video without tracking
VIZVS-3954Tracking Hub crashes on CONFIG LOAD sent during startup (command port serves before startup is complete)
VIZVS-3920Change in config creates service duplicates
VIZVS-3918Tracking Hub crashes while RECEIVING a large lens file over TCP (regression of VIZVS-3415)
VIZVS-3796XML Tracker uses wrong TickCounts due to wrong Index alignment
VIZVS-3788TrackingHub crashes during startup without dump file
VIZVS-3758Legacy lens files leads to corrupted output in 1.8 (merge to 1.9)
VIZVS-1628Object rigs offsets are not shown correctly on 3D preview
Minimum Hardware Configuration
  • Minimum 16 GB Ram
  • Dual-Core Intel CPU
  • 10 GB of free disk space
  • NVIDIA P2000 Graphics Card
  • OpenGL Hardware-accelerated Graphics Card
Info: Minimal Hardware Configuration provides sufficient resources for running a Tracking Hub configuration.
The automated lens file calibration requires additional GPU processing power. To benefit from this feature, use the Recommended Hardware Configuration.
  • HP Z4 G4 - 12-Core CPU
  • 64 GB Ram
  • 2x Gbit RJ45
  • 30 GB of free disk space
  • NVIDIA RTX 4000 Ada
Setup Required for NDI Workflow
  • HP Z4 G4 - 6-Core CPU
  • 32 GB Memory
  • 2x Gbit RJ45
  • 256 GB SSD for OS
  • 512 GB SSD for Data
  • NVIDIA RTX A4000 /16 GB GDDR6
Supported Drivers and Software
This software has been tested to run on:
  • Windows 11 LTSC 64-bit.
  • Windows 10 LTSC 64-bit.
  • Viz Engine 5.0 or later.
  • Service Host 2.1.
  • Version 5.45 for Plura PCL-PCI and PCL-PCIe (LV, 3G) timecode reader cards (available on the Vizrt FTP in Vizrt Drivers/Alperman PCL).
  • Sealevel SeaIO 5.1.3
  • Wibu Codemeter 8.30a.
  • AI Core v2.2
Note: Viz Virtual Studio 1.9 Bundle does not include Wibu Codemeter. This needs to be installed separately.
This software has been tested with Viz Arc 2.1.1 or higher.
Certified Tracking Systems
  • Shotoku
  • Motion Analysis
  • NCam
  • Egripment (Trackmen)
  • StypeKit
  • Vinten
  • Free-D
  • StarTracker
  • Vicon tracking system
  • XPecto
  • Thoma
  • BlackCam
  • Spidercam FrameB
  • Sony BRC X1000/800
  • Sony ILME-FR7
  • Sony BRC-AM7
  • Sony OCELLUS
  • Panasonic AW-UE 150
  • Panasonic AW-UE 100
  • Vizrt PTZ3 UHD+
  • Vizrt PTZ3 HD
  • Canon CR-N500
  • Canon CR-N300
Known Issues
Note: Viz Virtual Studio 1.9 comes with AI Core 2.2. In case other AI components like Reality Connect or Viz AI Keyer are installed, make sure they run on the latest version.
NDI
  • Security Updates Windows 11 – KB5063878 and Windows 10 – KB5063709 can lead to traffic drops in NDI output.
Studio Manager
  • On some machines with an NVIDIA graphics card, the memory (RAM) used by Studio Manager increases steadily while its 3D preview is shown. The cause is the NVIDIA driver setting Threaded optimization; this also affects earlier versions such as 1.8.1. From 1.9.0, the Studio Manager installer sets Threaded optimization to Off for StudioManager.exe, and Studio Manager shows a warning at start-up when the setting is on. If the warning appears: in the NVIDIA Control Panel, go to 3D Settings > Manage 3D settings > Program Settings, add StudioManager.exe, set Threaded optimization to Off and restart Studio Manager. Step-by-step instructions are in Important Checklist Before Installation.
  • Lens File Editor: if Tracking Hub restarts or the network connection drops while the Lens File Editor is open, Studio Manager reconnects, but the open editor does not. Changes saved from that editor are not written to the lens file, although the editor shows them as saved, and no message appears. Workaround: after a reconnect, close the Lens File Editor with the window's X button and open it again before editing. (VIZVS-4036)
Installation
  • Administrator privileges are required to install Tracking Hub/Studio Manager.
  • If the license dongle driver reports errors, please uninstall and reinstall the driver manually.
Note: Issues have been reported with failing redistributable updates on Windows 10. This can lead to Tracking Hub not starting properly. In case this happens:
  • Ensure there is no Microsoft update in queue or in progress (if you are not sure, reboot Windows).
  • Manually uninstall any MS Visual C++ 2015-2022 Redistributables (both x86 and x64) and restart.
  • Manually install the MS Visual C++ V14 Redistributable (both x86 and x64) and restart.
  • Install VizVirtualStudioBundle-x64-1.9.0.
Note: Issues have been reported with failing redistributable updates on Windows 10 and Windows 11 related to Microsoft Visual C++ v14 Redistributable 14.50.35719. The Bundle installer will print an error after installation if this redistributable is already installed on the PC. Options to prevent this error:
  • Uncheck redist option in bundle if it is already installed.
  • Uninstall Microsoft Visual C++ v14 Redistributable 14.50.35719 before starting the bundle installer.
Documentation
Documentation for Tracking Hub and Studio Manager are available at the Vizrt Documentation Center:
Support
