An air-gapped installation, on hosts that have no internet access, needs assistance from Vizrt support. Contact Vizrt support first, before you plan one.
If your installer host has internet access, follow Running the Installer instead.
Notes and Limitations
- Licensing still applies: offline refers to the software download, not to licensing. The cluster still needs a reachable WIBU CodeMeter license server on TCP 22350. That server is normally inside the same isolated network, so plan for it before you disconnect. See Prerequisites > Licensing.
- Identity provider: the cluster still needs network access to your identity provider for sign-in, even when the install itself is offline.
- VMware vSphere: offline installation on VMware vSphere is not supported.
