This guide covers installing VAM on VMware vSphere, where the installer provisions the Talos Kubernetes nodes as virtual machines on a vCenter-managed cluster. It is used alongside the main Running the Installer walkthrough. The main difference is the Cluster Setup step, where you select Create New Cluster and set Provisioning target to VMware vSphere.
This page is for the vSphere administrator who prepares the environment and the permissions, and for the operator who runs the VAM installer. If the installer is provisioning nodes on Hyper-V or you are bringing your own Kubernetes cluster, this page does not apply.
How It Works
The installer deploys a Talos Kubernetes cluster on vSphere:
- Downloads the Talos OVA (from the Image Factory, or uses a cached copy) and imports it into a vCenter content library.
- Deploys the control plane and worker VMs from that template into a resource pool, on a DHCP-enabled network, in Talos maintenance mode.
- Detects each VM's IP address through VMware Tools.
- Applies the Talos configuration to each node, bootstraps the cluster and retrieves the cluster credentials.
Re-runs are safe: if the content library, OVA template, resource pool, or VMs already exist from a previous attempt, the installer detects and reuses them rather than recreating them.
Environment Prerequisites
Set these up in vCenter before running the installer:
Requirement | Details |
vCenter | vCenter 7.0 or later, reachable from the installer host (for example, |
ESXi version | ESXi 6.7 Update 2 or later (VM hardware version |
Datacenter | A vSphere datacenter that hosts the VMs. |
Host / cluster | A specific ESXi host or cluster within the datacenter. |
Datastore | A datastore with room for the OVA template plus all VM disks. |
Network / port group | A network with DHCP enabled. VMs get their first IP address from DHCP. |
Content library | vCenter content libraries must be available. |
Internet access | The installer host needs internet access to the Talos Image Factory to download the OVA. Offline installation on vSphere is not supported. |
Credentials | A vSphere account with the permissions in Required vSphere Permissions. |
Network Requirements
- The target VM network must have DHCP, because the installer relies on it for initial IP assignment.
- The VMs must be reachable from the installer host on their DHCP addresses.
- VMware Tools must be able to report guest IPs back to vCenter (this is built into the Talos OVA).
- The installer host must be able to reach the VMs on port 50000 (Talos maintenance mode) and, after bootstrap, port 6443 (Kubernetes API).
Sizing
On vSphere the installer creates one disk per VM, sized to the full node total. It attaches no separate object-storage disk, so the asset store shares that disk. For the minimum and recommended totals, see Prerequisites > How the Installer Splits Disk per Node.
Budget the datastore for the sum of the VM disks, plus about 1 GB for the OVA template in the content library.
The vSphere account used by the installer needs a role with the privileges below. For simplicity you can assign the role at the datacenter level with propagation to children, but for tighter security, scope it to the specific datacenter, host/cluster, datastore, network, content library and resource pool the installer touches.
Recommended Custom Role: "VAM Installer"
Content Library
- Create local library
- Delete local library
- Update library item
- Add library item
- Deploy from OVF template
- Read storage
Virtual Machine: Inventory
- Create new
- Delete
Virtual Machine: Configuration
- Advanced configuration
- Change CPU count
- Memory
- Disk change
Virtual Machine: Interaction
- Power On
- Power Off
Virtual Machine: Guest Operations
- Guest operation queries (read guest IPs through VMware Tools)
Resource
- Assign virtual machine to resource pool
- Create resource pool
Datastore
- Allocate space
- Browse datastore
Network
- Assign network
Read-Only / Inventory
System.Read(verify connectivity)Inventory.Browse(enumerate datacenters, hosts, pools, datastores, networks)
Where to Apply the Role
Apply with propagation to children on: the target datacenter, the host / cluster that runs the VMs, the datastore used for VM storage and the content library backing, the VM network / port group, the content library and the target resource pool (or its parent host or cluster if the installer creates the pool).
Running the Installation
- Prepare the vCenter environment and permissions above.
- Launch
vamctl.exeand follow Running the Installer through Prepare Installer and Registry Login. - On Cluster Setup, select Create New Cluster, set Provisioning target to VMware vSphere, and enter vCenter URL, Username and Password.
- On Cluster Config, pick the Datacenter, ESXi host, Datastore, Network and Resource pool from lists populated from your vCenter.
- Set the cluster topology and per-node sizing, review and start the install. The installer imports the OVA, deploys the VMs, waits for them to report IPs (up to ~10 minutes), applies the Talos configs and bootstraps the cluster.
- Continue with the deployment and sanity-check steps as in the main walkthrough.
Known Issues
VMXNET3 Network Adapter and Cluster Networking
With the default VMXNET3 adapter, the cluster's pod network (Flannel vxlan) can fail due to hardware checksum-offload issues. Either:
Use an Intel E1000 adapter for the VMs, or
disable hardware offload on the pod-network interface with a Talos
EthernetConfigpatch:apiVersion: v1alpha1kind: EthernetConfigname: flannel.1features:tx-checksum-ip-generic:false
If you hit this, contact Vizrt support. The patch can be applied during installation.
OVA Download Failures (TLS)
The Talos Image Factory CDN uses post-quantum TLS that native Windows tooling may not support. The installer works around this automatically (falling back to a bundled wget). If OVA downloads fail, make sure the installer host has internet access to the Talos Image Factory.
