MCP Server Integration
Viz Arc includes an MCP (Model Context Protocol) server that enables integration with AI assistants and development tools. MCP is an open standard (now under the Linux Foundation) that provides a universal way to connect AI tools to external data and capabilities.
Compatible MCP Clients
The Viz Arc MCP server works with any MCP-compatible client, including:
Client | Type | Notes |
Claude Desktop | Desktop App | Anthropic's desktop application |
ChatGPT Desktop | Desktop App | OpenAI's desktop application (MCP support added March 2025) |
Cursor | IDE | AI-powered code editor with MCP support |
VS Code + Copilot | IDE | GitHub Copilot agent mode supports MCP |
Windsurf | IDE | Built-in MCP Plugin Store |
Cline | VS Code Extension | Autonomous coding agent with MCP integration |
Continue | IDE Extension | Open-source extension for VS Code and JetBrains |
OpenAI Codex | CLI/IDE | Supports MCP servers in CLI and IDE extension |
Architecture Overview
MCP Client VizArc.McpServer.exe Viz Arc(Any compatible) <----> (Lightweight server) <----> (Main application) stdio REST APIBenefits
Work with multiple AI tools, not locked to one provider.
Use your existing AI subscriptions.
Access Viz Arc documentation and templates from your preferred tool.
Create and modify templates through natural conversation.
Work alongside the main Viz Arc application.
Setup Instructions
Step 1: Locate the MCP Server
Find VizArc.McpServer.exe in your Viz Arc installation:
C:\Program Files\Vizrt\Viz Arc\VizArc.McpServer.exeStep 2: Configure Your MCP Client
Configuration varies by client. Below are examples for popular MCP clients.
Claude Desktop
Open configuration file: %APPDATA%\Claude\claude_desktop_config.json.
Add the configuration:
{"mcpServers": {"vizarc": {"command":"C:\\Program Files\\Vizrt\\Viz Arc\\VizArc.McpServer.exe","args": []}}}Restart Claude Desktop completely (check system tray).
ChatGPT Desktop
Open ChatGPT Desktop settings.
Navigate to MCP Servers section.
Add new server with command: C:\Program Files\Vizrt\Viz Arc\VizArc.McpServer.exe.
Restart ChatGPT Desktop.
Cursor
Open Cursor Settings (CTRL + ,).
Navigate to MCP section.
Add server configuration:
{"vizarc": {"command":"C:\\Program Files\\Vizrt\\Viz Arc\\VizArc.McpServer.exe","args": []}}Restart Cursor.
VS Code with GitHub Copilot
Open VS Code Settings (CTRL + ,).
Search for MCP.
Edit settings.json and add:
{"github.copilot.chat.mcpServers": {"vizarc": {"command":"C:\\Program Files\\Vizrt\\Viz Arc\\VizArc.McpServer.exe","args": []}}}Reload VS Code.
Windsurf
Open Windsurf's MCP Plugin Store.
Search for VizArc or add custom server.
Set command path: C:\Program Files\Vizrt\Viz Arc\VizArc.McpServer.exe.
OpenAI Codex CLI
codex --mcp-server "C:\Program Files\Vizrt\Viz Arc\VizArc.McpServer.exe"Important: Use double backslashes (\\) in JSON paths for Windows.
Step 3: Verify Connection
After configuring your MCP client:
Start a new conversation.
Ask: "What Viz Arc tools do you have access to?".
The AI should respond with information about available Viz Arc tools.
Example Prompts
For documentation queries (Viz Arc not required)
"Show me the available parameter types in Viz Arc"
"How do callbacks work in Viz Arc templates?"
"What is the difference between SetControlObject and UpdateTemplate?"
For live template work (Viz Arc must be running)
"What template do I have open in Viz Arc?"
"Add a text input parameter called 'headline' to my current template"
"Show me the control objects available in my template"
"Link the 'score' parameter to the 'ScoreText' control object"
Available AI Tools
Static Tools (Always Available)
These tools work without Viz Arc running:
Tool | Description |
get_documentation | Access Viz Arc API documentation. |
get_parameters_reference | Get parameter types and properties reference. |
get_sample_templates | Show example template implementations. |
list_parameter_types | List all available UI parameter types. |
query_documentation | Search documentation for specific topics. |
Dynamic Tools (Require Viz Arc Running)
These tools require Viz Arc to be running and a valid AI license:
get_current_project | Get information about the loaded project. |
list_templates | List all templates in the current project. |
get_template | Get details of a specific template. |
validate_template_code | Validate JavaScript or VBScript code. |
create_template | Create a new template and open it in Template Designer. |
get_current_editing_template | Get the template currently open in Template Designer. |
modify_current_template | Apply changes to the currently open template. |
get_control_objects | Get available control objects for linking. |
link_parameter_to_control_object | Create UI linkage between parameter and control object. |
unlink_parameter | Remove linkage from a parameter. |
get_parameter_linkages | View all current parameter linkages. |
Modifying Parameters
When using modify_current_template, you can update various parameter properties:
Property | Description |
| Parameter position |
| Parameter dimensions |
| Display label |
| Background color |
Supported Color Formats
Hex:
#FF5500or#AARRGGBBRGB function:
RGB(255, 85, 0)Comma-separated:
255, 85, 0JSON object:
{"R": 255, "G": 85, "B": 0}
Troubleshooting
AI Prompt Panel Not Visible
Cause: AI license not valid or not available.
Solution:
Verify AI license status in System > Configuration > Info.
Contact your Vizrt representative if license is missing.
MCP Server Not Connecting
Check 1: Configuration file syntax
Ensure claude_desktop_config.json has valid JSON syntax.
Verify double backslashes in Windows paths.
Check 2: Executable path
Confirm VizArc.McpServer.exe exists at the specified path.
Test by running the executable directly in a terminal.
Check 3: Restart Claude Desktop
Fully quit Claude Desktop (check system tray icon).
Relaunch the application.
"AI License Required" Error
Cause: Valid AI license not detected.
Solution:
Ensure Viz Arc is running.
Verify AI license in System > Configuration > Info.
Contact your Vizrt representative for license issues.
Documentation Not Loading
Check that the documentation folder exists: %ProgramData%\Vizrt\VizArc\Resources\MCP\AI_Documentation\.
If missing, reinstall Viz Arc or contact support.
Dynamic Tools Not Working
Cause: Viz Arc application not running.
Solution:
Start Viz Arc.
Load a template in template editor.
Try the tool again.
Note: Static tools (documentation, parameter types) work without Viz Arc running. Dynamic tools require Viz Arc to be running with a loaded template.
