- To Play All Animations in a Director from the Start of the Time-line
- To Play Multiple or All Animations in a Scene
- To Play an Animation in Reverse
- To Stop a Director
- To Stop an Animation
- To Stop All Animations
- To Continue an Animation
- To Jump to Start of an Animation
- To Jump to the End of an Animation
- To Delay Animations in a Director with Offsets
- Scale Animations
- To Scale Animations in a Director
Select the required Director.
Either
Click the Start Animation button in the Time-line Editor.
When the Stage is active, pressing ENTER starts any animations on the selected director(s) from the first frame. Pressing SPACE pauses or resumes play-out.
Click the Start Animation of Selected Layers button from the Director Control Panel.
When working with a scene that contains more than one director, the current director is always selected by default in the scene editor preview window. To preview all animations in a multi-director scene, all directors can be started simultaneously:
Open the Director Control Panel.
Click the All button, or hold SHIFT + click to select the range of directors. Holding CTRL and clicking allows for selecting individual directors instead of a range.
To start the animation(s), either
Click the Start button in the Time-line Editor.
Click the Play layer button in the Director Control Panel.
Click the Start animation of selected layers button in the Director Control Panel. This also starts the selected animations in the other layers, if they are available.
In the Time-line Editor, click the (Reverse Play) button.
Either:
Press SHIFT + ENTER when the Stage is active.
To Stop a Director
Select one or more Directors.
Either:
In the Time-line Editor, right-click the Stop button.
Click the Stop button from the Director Editor.
Press SPACE while the Stage is active.
In the Time-line Editor, click the Stop button. It is also possible to add one or more stop points to a Director, so that each time the time-line reaches a certain frame, the animations stop automatically.
Enable the Director Control Panel
Select all directors and all layers.
Click the Stop animation of selected layers button. This stops all animations in all layers.
Either:
Click the Continue Animation button in the Time-line Editor
While in the Stage, press SPACE.
Click the Continue Animation button in the Director Editor.
Click the Go to Start button in the Time-line Editor, or press CTRL + HOME.
Click the Go to End button in the Time-line Editor, or press CTRL + END.
Enable the Director Editor and select the required Director.
In the Director editor, set the Offset value (in fields). It is also possible to move the Director, including all its animations, horizontally along the time-line in the Time-line Editor. This does not add the offset value.
Scale Animations
Scaling a Director is the easiest way to change the total running time of the animations in the Director. Scaling is done proportionally and includes all Sub-Directors.
Drag the start or the end point of a Director in the Dopesheet Editor. It is not possible to drag the start point beyond the offset value.
