To explain the described terms and definitions, this section shows some source code examples and explains the important steps and commands.
Most of the examples detailed here are written in an easy and understandable form for programing beginners. Some are basic, while others are more advanced and specific for their use case. More efficient code structures and improvements are possible.
Initializing Scripts
This example declares and defines two variables with a value. In the main procedure OnInit() those two variables and their addition are output to the console using Println.
Callback procedures like OnInit() are used to initialize scripts.
'Declaration of the variables dim a as Integer a = 10000 dim b as Integer b = 5000 'Start of the main procedure sub OnInit() 'Executing the commands println "\n"     println "The variable a has the following value: " & a println "\n"    println "The variable b has the following value: " & bprintln "\n"    println "The sum of the variables is: " & a + b 'End of the main procedure end subResult output to the Viz Engine console:
Register Parameters
This script example creates a custom editor for filling in index and alpha values. The index value decides which container does not receive the alpha value, whereas the alpha value is set for all other containers.
sub OnInitParameters()    RegisterParameterInt("index", "Index", 1, 1, 7)    RegisterParameterDouble("alpha", "Alpha", 50.0, 0.0, 100.0)    RegisterSpacer("space", 30)    RegisterSeparator("sep", "Actions")    RegisterPushButton("action1", "Action 1", 1)    RegisterPushButton("action2", "Action 2", 1)end sub sub OnExecAction(buttonId as Integer)    dim c as Container    dim i, index as Integer    dim a as Double    index = GetParameterInt("index")    a = GetParameterDouble("alpha")    i = 1    c = ChildContainer    do while c <> null        if i = index then            c.alpha.value = 100.0        else            c.alpha.value = a        end if    i = i + 1    c = c.NextContainer    loop end subMouse Events I (Set)
This script example shows how to use a ‘mouse event’” to set an object’s alpha value with OnEnter and OnLeave.
sub OnEnter()    alpha.value = 100.0 end sub sub OnLeave()    alpha.value = 50.0 end subMouse Events II (Start, Stop and Reverse)
This script, when added to a container, allows an animation to be started with the click of a mouse button over an object (for example, rectangle). Press again and it stops. Press again and it continues from the point it stopped.
dim my_dir = stage.FindDirector("Default") sub OnLButtonDown()     if my_dir.IsAnimationRunning() then          my_dir.StopAnimation()     else         my_dir.ContinueAnimation()     end if end subWith the script detailed below, start an animation and let it run until a stop point. Click again and it runs in reverse:
dim my_dir = stage.FindDirector("Defult") sub OnLButtonDown()     menu.ContinueAnimation()     if my_dir.reverse == true then         my_dir.reverse = false     else         my_dir.reverse = true     end if end subMouse Events III (Grow and Shrink)
With this script added to a Container an object grows when the mouse is hovering over the object and conversely. In this case, the center of the object is set to the lower right corner to let it grow out from that center.
dim growing as Boolean = false sub OnInitParameters()     RegisterParameterDouble("min", "MinScale", 1.0, 0.0, 10.0)     RegisterParameterDouble("max", "MaxScale", 1.5, 0.0, 10.0)     RegisterParameterDouble("fac", "GrowFactor", 1.1, 1.0, 10.0) end sub sub OnEnter()     growing = true end sub sub OnLeave()     growing = false end sub sub OnExecPerField()     dim min = GetParameterDouble("min")     dim max = GetParameterDouble("max")     dim fac = GetParameterDouble("fac")     if growing then         scaling.xyz *= fac         if scaling.x > max then scaling.xyz = max     else         scaling.xyz /= fac         if scaling.x < min then scaling.xyz = min     end if end subSimple Gesture Recognition
This example script can be used to detect a drawn square on the screen:
dim gRecognizer as gesturerecognizer sub OnInit()    gRecognizer.handlepatterns = true    gRecognizer.addhandler(scriptplugininstance) end sub  sub OnGesture(gesture As Gesture)    if gesture.patternid == PATTERN_SQUARE then        println("This is a square")    end if end sub sub OnTouchTrace(trace as Trace, touch as Touch)    gRecognizer.addtrace(trace) end subNote: Some gesture patterns need to be checked for their alignment as well, for example up, down, left, and so on. For this you can activate the CheckPatternOrientation property in the gesture recognizer object.
Calculate the Days of a Week and Month
This script example calculates the day of the week and the number of days of the month:
DIM smap AS Array[String] smap.size = 7smap[0] = "Sun"smap[1] = "Mon"smap[2] = "Tue"smap[3] = "Wed"smap[4] = "Thu"smap[5] = "Fri"smap[6] = "Sat" function CalcDayOfWeek(iYear AS Integer, iMonth AS Integer, iDay AS Integer) AS String DIM dt AS DateTime    dt.year = iYear    dt.month = iMonth    dt.dayofmonth = iDay    dt.normalize()     CalcDayOfWeek = smap[dt.dayofweek] end function  function CalcNumOfDaysOfMonth(iYear AS Integer, iMonth AS Integer) AS IntegerDIM dt AS DateTime    dt.year = iYear    dt.month = iMonth+1    dt.dayofmonth = 0    dt.normalize()    CalcNumOfDaysOfMonth = dt.dayofmonthend function  sub OnInit()DIM dt AS DateTime    dt.year = 2019    dt.month = 2    dt.dayofmonth = 23     println("Date: " & CalcDayOfWeek(dt.year, dt.month, dt.dayofmonth) & ", " & dt.year & "" & dt.month & "" & dt.dayofmonth)    println("Days: " & CalcNumOfDaysOfMonth(dt.year, dt.month)) end subUpdate a Scene Using a Text File
This script example updates a Scene from a text file.
dim timer,limit as integer timer = 0 sub OnInitParameters()    RegisterInfoText("Text File Grabber 1.0" & chr(10) & chr(10)         & "Grabs text file and puts optional prefix/suffix around the contents of the text file." & chr(10)         & "Filename supports paths with drive letters and UNC paths." & chr(10) & chr(10)         & "Text in \"Default Text\" box is used if file specified in File box cannot be opend or accessed." & chr(10) & chr(10)         & "Listens to scene map variable \"text_update\" -- text files are re-read when this variable changes.")    RegisterFileSelector("file", "File", "c:\test", "1.txt", "*.*")    RegisterParameterString("default","Default text","",40,50,"")    RegisterParameterString("prefix","Prefix (optional)","",40,50,"")     RegisterParameterBool("prefixIfNull","Include prefix if file not found",FALSE)    RegisterParameterString("suffix","Suffix (optional)","",40,50,"")    RegisterParameterBool("suffixIfNull","Include suffix if file not found",FALSE)    RegisterParameterInt("updateFields","Auto-Update interval (fields)",300,60,999999999999)    RegisterParameterBool("debug","Debug output to console",FALSE) end sub  sub OnParameterChanged(parameterName As String)    're-populate text when a parameter changes    if parameterName <> "updateFields" then UpdateText     if parameterName = "updateFields" then        limit = GetParameterInt("updateFields")    end if end sub  sub OnExecPerField()    timer = timer + 1    if timer >= limit then        if GetParameterBool("debug") then println "Timer limit reached"            UpdateText            timer = 0    end if end sub  sub OnInit()    Scene.Map.RegisterChangedCallback("text_update")    limit = GetParameterInt("updateFields")    UpdateText end sub  sub OnSharedMemoryVariableChanged(map As SharedMemory, mapKey As String)    if mapKey = "text_update" then        UpdateText    end if end sub  sub UpdateText()    geometry.text = GetTextFile() end sub function GetTextFile() as string    dim content, path as string    path = GetParameterString("file")    if GetParameterBool("debug") then println "File path: " & path    if System.LoadTextFile( path, content ) then        if GetParameterBool("debug") then println "Successfully loaded file"        content.trim        if len(GetParameterString("prefix")) > 0 then content = GetParameterString("prefix") & " " & content        if len(GetParameterString("suffix")) > 0 then content = content & " " & GetParameterString("suffix")    else        if GetParameterBool("debug") then println "Could not load file; using default text"        content = GetParameterString("default")        if GetParameterBool("prefixIfNull") then content = GetParameterString("prefix") & " " & content        if GetParameterBool("suffixIfNull") then content = content & " " & GetParameterString("suffix")    end if    GetTextFile = content    if GetParameterBool("debug") then println "Returning '" & GetTextFile & "'" end function
