General Shortcuts
Function | Default Key and/or Mouse Shortcut | Configurable |
Moves to Top Container | HOME |
Moves to Last Container | END | |
Moves to top of page | PAGE UP | |
Moves to bottom of page | PAGE DOWN | |
Scrolls up the Container list | UP ARROW (↑) | |
Scrolls down the Container list | DOWN ARROW (↓) | |
Opens Container tree | RIGHT ARROW (→) | |
Closes Container tree | LEFT ARROW (←) | |
Opens plug-in panel | + |
Basic View Controls and Shortcuts
Inserts New Container | CTRL + INSERT (The new Container is created above the first selected Container.) |
Rename Container | F2 |
Multiselects Containers | CTRL + Left click |
Deletes selected Container(s) | CTRL + DELETE |
Opens whole Tree | CTRL + O |
Opens Subtree | ALT + + |
ALT + RIGHT |
Collapses whole Tree | CTRL + I |
Collapses Subtree | ALT + - |
ALT + LEFT |
Locks selected Container(s) | CTRL + L |
Unlocks selected Container(s) | CTRL + SHIFT + L |
Groups selected Container(s) | CTRL + G |
Ungroups selected Container(s) | CTRL + SHIFT + G |
Hides selected Container(s) | CTRL + H |
Shows selected Container(s) | CTRL + SHIFT + H |
Searches Container | CTRL + F |
Copies selected Container(s) | CTRL + Left click on container name and drag |
Copies selected Container(s) to Clipboard | CTRL + C |
Pastes Containers from Clipboard | CTRL + V (They are created one hierarchical level underneath selected container.) |
Cuts selected Container(s) | CTRL + X |
Moves selected Container(s) | Left click on container name and drag |
Moves selected Container and retain transformation properties | ALT + Left click on container name and drag |
Copies Properties of Container | Left click on container Properties and drag |
Merges Group | CTRL + M |
Splits Container | CTRL + SHIFT + M |
Convert to Dynamic Geometry | CTRL + D |
Plug-in Overlay
Function | Key and/or Mouse Shortcut | Configurable |
Opens plug-in Panel | + |
Selects plug-in | Cursor Keys |
Selects plug-in and applies to selected container(s) | ENTER |
Leaves plug-in Overlay | ESC | |
