As previously mentioned, the make-up of a toggle-layer in a Transition Logic scene is a relationship between the Toggle plug-in and a Director in the stage. Through the use of the Director's timelines, it is possible to animate between different variations in the design, called states. In order to make use of these states, each object scene refers to a specific toggle-layer and desired state.
Toggle Layer States
Animating between different toggle layer states is called state transition animation. The example above shows a lower third’s backplate being animated from a narrow version to a wide version (two states).
Defining States
A toggle layer is required to have a default state named O. The O state is often referred to as the Out state as it is the state the toggle layer is taken to when the operator issues a Take Out command. This means that in most cases, this is also the state where the toggle layer’s referring foreground scene is no longer visible on-screen.
In addition to the O state, at least one additional state is required to run animations when taking items to air. Any state that is not the O state is often referred to as an in state, or visible state, because it most often refers to the state when a referring object scene is shown on-screen.
Tip: The master scene should be saved with the play head at the beginning of the timeline, which is equal to the O state. This makes sure that the scene is properly initialized in the O state.
Use the following conventions when naming states:
  • O states must be named in upper case only. This is a reserved state that is tied to the take-out command.
  • It is recommended to name states according to the referring control scene’s appearance or other distinguishing characteristic. For example, for a toggle-layer responsible for content displayed in the lower third of the screen that varies in size from large to small typically has two states named LARGE and SMALL. A graphic placed over the shoulder of a presenter, where the graphics should switch between the left and right side of the screen, would be named LEFT and RIGHT, or OTS_LEFT and OTS_RIGHT, with OTS being short for Over The Shoulder.
  • To maintain consistency between designers, it is recommended to write all state names using upper case characters only. This also makes it simpler to implement the state change in later steps.
    When taking an item which requires the SMALL state, the master scene animates from the O state to the SMALL state, once that item is taken On Air. When a take-out command is issued, the master scene then animates in reverse to the O state.
    Transitioning from a SMALL to an O state is achieved by using the animation from the O to the SMALL state. In such a case, the animation plays in reverse. If this is not required, you simply add another O state after the SMALL state, and create a new animation.
    If the layer should transition from the small sized version to the large version, you simply add the state to the toggle-layer director, and create a transition animation for the layer going from SMALL to LARGE . This also requires that the LARGE state has an O state such that the graphics can transition and animate out from the LARGE state.
How GOTO_TRIO Works
When GOTO_TRIO $FROM $TO is issued, Viz Engine searches the layer director:
  1. Left to right: Find $FROM, then look right for $TO. If found, play the animation forward between them.
  2. Backtrack: If not found left-to-right, find $TO and look right for $FROM. If found, play that segment in reverse.
This means a single animation segment can serve both directions, $O → $IN plays forward, $IN → $O plays the same segment in reverse.
Identifying States
There are no hard limits to the number of states. However, increasing the number of states also increases the number of animations, and consequently the complexity of the scene. To decide the minimum number of animations required it is possible to do a Euler Walk (1).
The Euler Walk, although not always possible, is defined as the optimal route taken to visit each edge exactly once. However, the theory can be applied to Transition Logic to identify the minimum required states needed to connect each state to the others exactly once.
Straightening the Euler walk out onto the layer’s director shows the required transition animations:
Minimum Animation Count
The Euler Walk determines the minimum number of animation segments needed to connect all states:
States
Min Animations
Example Director Layout
2
1
$O ─── $IN ─── $O
3
3
$O ─── $SMALL ─── $LARGE ─── $O ─── $LARGE ─── $SMALL ─── $O
4
6
(complexity increases significantly)
5
10
(consider splitting into separate layers)
Practical guideline: Keep layers to a maximum of two to three states. If a layer needs four or more states, consider whether the design can be split into multiple layers, each with fewer states.
Note: When performing transition animations from one state to the other Viz Artist/Engine searches from left to right on the layer’s director for the correct combination of states. If the operator wishes to go from state A to B, Viz Artist/Engine traverses the layer’s director for state A and looks to the right and see if it finds state B. If a match is found, Viz Artist/Engine performs the transition animation.
Looking at the above example director, it becomes clear that not all combinations can be found by traversing from left to right. If a change from state A to D is not found, Viz Engine first traverses from left to right, then starts to backtrack and traverse from right to left looking for a D from A animation.
When the minimum required animations have been discovered, it is time to add extra animations required by the overall design. For example, it might be desirable to add a transition from state B to O, to animate the layer out from state B in a different way than reversing the in animation. As an example, think of a lower third graphics animating in from the left, stopping, then animating out to the bottom. Adding new out states quickly increases the complexity of a layer. As all states are required to be connected to each other, it would not be advisable to simply make an O state in place of the B to C animation.
Detailed below are the minimum required number of transition animations for a graphics layer with a given number of states:
  • One State: Animations are not possible.
  • Two States: Requires a minimum of one animation.
  • Three States: Requires a minimum of three animations.
  • Four States: Requires a minimum of six animations.
  • Five States: Requires a minimum of ten animations.
  • Six States: Requires a minimum of 15 animations.
Adding Custom Out Animations
By default, going from $IN to $O simply reverses the in-animation. To create a different out animation (for example, slide in from left, drop out to bottom), add a second $O stop point after the visible state:
Director "BannerLyr"
─$O────────$LOWERTHIRD────────$O─
│← in animation →│← out animation →│
(slide from left) (drop to bottom)
After adding new stop points, always re-run Default Keyframes on the Toggle plug-in (delete the old ones first).
