The following lists all container and codecs that have been tested and verified to work correctly using the VML player introduced in Viz Engine 4.3.
There is no perfect codec, therefore we can not recommend a particular one. Some codecs (for example AVC) are very CPU intense, whereas others result in large files and require a higher I/O bandwidth. Additional factors like framerate, bitrates, resolution also have a huge influence on playback performance. The following lists all containers and codecs that have been verified so far to be readable by the VML clip player.
Note: There is no guarantee that this list is complete. All Clips have been verified on common framerates and orientations.
Supported Containers
MPEG-4 Part 14 (MP4)
Video Codec
Audio
Formats
H.265 (5)
AAC/AC3/MP3
H.264
AAC/AC3/MP3
Profiles:
Baseline@L1, L1.1, L1.2, L1.3
Baseline@L2, L2.1, L2.2 (3)
Baseline@L3, L3.1, L3.2
Baseline@L4, L4.1, L4.2
Baseline@L5, L5.1, L5.2
Baseline@L6, L6.1, L6.2 (4)
Main@L1, L1.1, L1.2, L1.3
Main@L2, L2.1, L2.2 (3)
Main@L3, L3.1, L3.2
Main@L4, L4.1, L4.2
Main@L5, L5.1, L5.2
Main@L6, L6.1, L6.2 (4)
High@L1, L1.1, L1.2, L1.3
High@L2, L2.1, L2.2 (3)
High@L3, L3.1, L3.2
High@L4, L4.1, L4.2
High@L5, L5.1, L5.2
High@L6, L6.1, L6.2 (4)
High10(1)@L1, L1.1, L1.2, L1.3
High10(1)@L2, L2.1, L2.2 (3)
High10(1)@L3, L3.1, L3.2
High10(1)@L4, L4.1, L4.2
High10(1)@L5, L5.1, L5.2
High10(1)@L6, L6.1, L6.2 (4)
MPEG-2
AAC/AC3/MP3
Profiles:
Main@High
MPEG-4
AAC/AC3/MP3
Profiles:
Visual Simple@L0, L5, L6
XDCAM EX
AAC/AC3/MP3
(1) HDR playback is not supported yet
(2) Shows incorrect colors
(3) The level defines the maximum resolution and bitrate. Anything less than level 3 is not relevant for broadcast environments
(4) Known as CPU intensive
(5) Requires ClipPlayer Pro license
MPEG 4 Video (M4V)
Video Codec
Audio
Formats
AVC
AAC LC
Profiles:
High@L1, L1.2
[email protected]
High@L3, L3.1
High@L4, L4.2
High@L5
MPEG 2 Video (M2V, MPG, VOB) & Transport Stream (M2TS, TS)
Video Codec
Audio
Formats
MPEG Video 2
Mpeg Audio , Layer2
Profiles:
Main@Main
Main@High, High 1440
MPEG Video 2 Transport Stream
Mpeg Audio , Layer2
Profiles:
Main@Main
Main@High 1440
Moving Picture Experts Group Phase 1 (MPEG)
Video Codec
Audio
Formats
MPEG Video 1 (1)
Mpeg Audio, Layer1
(1) known as very low quality
Audio Video Interleave (AVI)
Video Codec
Audio
Formats
Lagarith
PCM
supports Alpha
uncompressed
PCM
RGB +Alpha
UYVY 422
Newtek Codecs
Speed HQ 420
Speed HQ 4224 Alpha
Speed HQ 4224 DCT Alpha
Speed HQ 4444 (2)
Speed HQ 4444 DCT (2)
DVCAM
DV50
DVPAL
DVCPro
DVCPro100
PCM
Profiles: 420, 422
411
JPEG
PCM
Intel IYUV
PCM
Matrox Mpeg2 i-Frame
Matrox Mpeg2 i-Frame HD
PCM
alpha not supported
alpha not supported
Mpeg-4 Visual
MPEG Audio Layer 3
Simple@L1
Apple QuickTime Movie (MOV)
Video Codec
Audio
Formats
Animation (3)
PCM
DV25
DV50
DVC Pro
PCM
ProRes
PCM
422: HQ/LT/Proxy
4444:
DNxHD
PCM
SQ 8bit
HQ 8bit
HQX 10bit
DNxHR
PCM
SQ 8bit
HQ 8bit
LB 8 bit
HQX 10bit (1)
444 10bit (1)(2)
AVC
AAC/PCM
Profiles:
[email protected]
High@L3, L3.2
High@L4, L4.1, L4.2
uncompressed (3)
PCM
RGB
YUV 422 8bit
Apple JPEG
PCM
HAP (4)
AAC/PCM (5)
HAP, HAP Alpha, HAP Q, HAP Q Alpha, HAP R
(3) Known as extremely I/O intensive
(4) Requires ClipPlayer Pro license
(5) HAP is a pure image compression codec. Audio is based on the stream inside the container.
IMPORTANT! The DNxHD and DNxHR codecs require a separate license, issued by Vizrt.
Material Exchange Format (MXF)
Video Codec
Audio
Formats
DV, DVCPro, DVCPro HD
PCM
IMX
PCM
Class 30/40/50
DNxHD
PCM
Matrox MPEG iFrame
PCM
alpha not supported
MPEG 2
PCM
Profiles:
Main@Main
XDCam/XDCAM HD
PCM
Class 18/25/35
4:2:2 50
XDCam EX
PCM
Class 18/35
AVC Intra
PCM
Class 50/100/200
AVC Long GOP
PCM
4:2:0 Class 6/Class 12/Class 25
4:2:2 Class 25
XAVC Intra (4)
PCM
Class 100/Class 200
XAVC Intra 2K (4)
PCM
Class 100
XAVC Intra QFHD (4)
PCM
Class 300/480
XAVC Intra 4K (4)
PCM
Class 300/480
XAVC Long GOP (4)
PCM
25MBit/35MBit/50MBit
XAVC QFHD Long GOP (4)
PCM
4:2:0
4:2:2: 100MBit/140MBit/200Mbit
(4) Known as extremely CPU intensive
Windows Media Video (WMV)
Video Codec
Audio
Formats
Windows Media V7
WMA Pro
Profiles:
V7
V8
V9, V9 Advanced, V9 Screen
MPEG-4 Visual (Microsoft)
n/a
Advanced Systems Format (ASF)
Video Codec
Audio
Formats
n/a
Third Generation Partnership Project (3GP)
Video Codec
Audio
Formats
MPEG-4
AAC
Profiles:
Visual Simple@L2, L6
AVC
n/a
Profiles:
High@L4, L5.1
WEB Media (WEBM)
Video Codec
Audio
Formats
VP9
opus
VP8
opus
H.263
Profiles:
[email protected]
AVC
opus/aac
Profiles:
Baseline@L1
Matroska Multimedia Container (MKV)
Video Codec
Audio
Formats
AVC
Vorbis, opus, aac
Profiles:
[email protected]
[email protected]
High@L3, L3.1
High@L4
High@L5
AVC (H264)
AAC, opus, aac, eac3
High@L4
MPEG-2
AAC
MPEG-4 Visual
AAC
Simple@L1
Theora
AAC
VP8
AAC
VP9
AAC
Clipplayer Pro License
The following codecs need to be licensed to be played:
  • H.265
  • HAP
Known Limitations
Unsupported Containers
The following containers are known to be not compatible with VML Clip Player:
Container
Additional Information
R3D
RED camera container
OGV
Ogg Video File
F4V
Flash Video
MJPEG
Motion JPEG
RM
Real Media Video
SWF
Small Web Format / Shockwave
WTV
Windows Recorded TV Show
DV
Raw DV stream (.dv file, no container). DV video plays in AVI, MOV or MXF.
OGG
Ogg Audio File (.ogg). Vorbis audio can't be seeked accurately, so audio can be missing or scratchy after a seek. Files with zero padding at the end don't open. Use WAV, or AAC in MP4.
Unsupported Codecs and Known Incompatibilities
The following codecs are known to be not compatible with VML Clip Player:
Container
Video Codec
AVI
Ross Expression
AVI
huffyuv
AVI
Cinepak
AVI
FMP4
AVI
M701
AVI
xVid
AVI
Microsoft RLE
AVI
Microsoft Video1
AVI
YUV 10bit V210
MOV
AIVM
MOV
ProRes 4444 XQ
MOV
GoPro Cineform
MOV
uncompressed YUV 422 10bit
V210
MP4
AV1
