Debugging Transition Logic scene is a complex task, we recommend to use the Health Check in Logicmaker to perform most common basic checks, however additional issues are listed here:
Symptom
Cause
Fix
Object scene doesn't animate in
ControlObject's Layer identifier or State identifier doesn't match the master scene (case-sensitive mismatch)
Verify names match exactly. Check capitalization: BannerLyr ≠ bannerlyr ≠ Bannerlyr
Backplate visible on first take
Master scene was saved with a director not in $O state
Seek all directors to $O / frame 0, then re-save the master scene
Cross-fade looks different on alternate takes
AX and BX directors have different animations
Ensure AX and BX are identical. Delete both, re-create, and copy keyframes
Object scene loads but data doesn't appear
Data pushed to $current instead of $other, or wrong field_id
Always push data to $other$object before switch. Verify field_id values
Toggle generates no sub-directors
Default Keyframes wasn't clicked, or the director has fewer than two stop points
Add at least $O + one visible state, then click Default Keyframes
Scene frozen after switch (subscene mode)
Missing continue INVOKE after switch in subscene mode
Add Toggle*continue INVOKE after Toggle*switch INVOKE
ControlList shows fewer rows than expected
Not enough row containers pre-created in the scene tree
Pre-create sub-ControlObject containers up to your maximum row count
Stop points lost after object-pool merge
Stop points were not stored before saving
Click Store Stop Points on ControlObject before saving the object scene
Master scene named "background" causes issues
The name background triggers legacy mode in MSE
Rename to default or any other name
GOTO_TRIO doesn't find state pair
Stop points not connected on the timeline (missing Euler walk segment)
Verify the director has a path from $FROM to $TO — either left-to-right or by backtracking
