Viz Artist 5.4.1
Release Date: 2025-11-19
These are the release notes for Viz Artist version 5.4.1. This document describes the user-visible changes that have been made to the software since release 5.4.0
Fixed Issues
Security Updates
Key
Summary
Known Issues
  • Control Object View will not highlight the correct control plug-in from within a list if multiple control plug-ins are on one container.
  • Clip Playback in the new Viz One Browser is currently disabled. Preview will be added in a future release of Viz Artist.
  • Due a technical limitation of QT framework, the focus of an input field can not be restored when switching containers.
  • Referenced Materials do not correctly update their icon if changed.
  • It is not recommended to run the User Interface within a Virtual Set environment, as it can cause timing issues under certain circumstances.
  • Viz Engine render window is always on top when started in videowall mode -u1 -y -n and output system FULLSCREEN (VIZART-2400). Does not happen in mode -u1 -w or with any vga_preview and is independent on the number of monitors and if a mosaic is used or not.
    • What can be observed is that the output is always on top and it is not possible to get anything else on top (taskbar, other windows with ALT + TAB, task manager). SHIFT + BACKSPACE works only when Viz Artist has focus. When CTRL + BACKSPACE does not work it can be achieved with CTRL + ALT + DEL, task manager, ALT + TAB to Viz Artist and SHIFT + BACKSPACE. ALT + TAB does not work initially as the window is not shown. This behavior is actually desired to have the output of Viz Engine always on top (for example, interactive scenes shown on screens in the studio).
Windows
  • Right clicking on the Taskbar icon of Viz Engine starts a new instance. Starting an additional Viz GUI process is prevented on Windows 10.
  • On Windows version LTSC 1809: Logging out/in may be required for the fonts in the Viz Artist user interface to apply the set scaling after the user changes the Windows scaling setting.
Build Information
  • Platform Toolset: Visual Studio 2022 (v143)
  • Windows SDK Version: 10.0.22621
Viz Artist 5.4.0
Release Date: 2025-08-28
These are the release notes for Viz Artist version 5.4.0. This document describes the user-visible changes that have been made to the software since release 5.3.
Note: Viz Engine maintains its release notes in a separate document starting from version 3.12.0.
Installer Notes
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
  • Viz Artist is installed in C:\Program Files\Vizrt\VizEngine\VizArtist.
  • Visual C++ Redistributable files are not part of the .msi setup file anymore. These files are now installed with the bundle setup application (VIZENG-13210, VIZENG-12629, VIZENG-12701).
  • The new bundle setup application installs or upgrades Viz Artist together with its required Visual C++ Redistributable files (VIZENG-12936, VIZENG-13804).
  • All files contained in the bundle setup application can be extracted using the /dump command line option. This creates a sub-folder where the files are extracted (VIZENG-13020).
  • Multiple installations of Viz Artist are not supported.
  • The installer automatically upgrades (replaces) any existing Viz Artist 3.x installation. However, downgrading is currently not supported (VIZENG-7098).
  • The installer package is digitally signed (VIZENG-7378).
  • The user account must have SeCreateGlobalPrivilege (SE_CREATE_GLOBAL_NAME) enabled.
Windows
This software has been tested to run on the following systems:
  • Windows Server 2019
  • Windows Server 2022
  • Windows 10 (LTSC 1809)
  • Windows 10 (LTSC 21H2)
  • Windows 11 LTSC 2024
Note: Only English language Operating Systems are supported.
  • It is recommended to install the latest Windows Security Updates and Patches, except Nvidia drivers.
  • .NET Framework 4.5 or higher is required (VIZENG-6036).
  • Minimum Windows Installer version is now 5.0.0.
  • To run Viz Artist/Viz Engine without Administrator privileges, you need to grant the following permissions:
    • SeIncreaseBasePriorityPrivilege
    • SeCreateGlobalPrivilege
    • SeCreatePagefilePrivilege
    • SeIncreaseWorkingSetPrivilege
Note: Viz Artist requires a minimum resolution of 1920x1080 pixels.
Windows
  • Network shares are not accessible from within Viz Artist when UAC is enabled or when running on Windows 10. The Viz Configuration page Local Settings has been extended for enabling Network drive linking (VIZENG-15594, VIZENG-15319).
UAC
  • Viz Artist is UAC aware. Log-files and additional files are stored in %VIZ_PROGRAMDATA%, which defaults to %ProgramData%\Vizrt\VizArtist. Configuration-files and profiles are stored in %ProgramData%\Vizrt\VizEngine. Temporary data is stored in %VIZ_TEMPDATA% which defaults to %TMP%\Vizrt\VizEngine. The default value can be changed in viz.cmd or on the command line of viz.exe.
  • Starting Viz Artist shows a UAC popup for VizStarter.exe (VIZENG-8683).
Changes
  • Default Color Mode setting has been removed from Configuration Settings.
Note: Viz Artist no longer installs the local version of the documentation. Documentation is available online or as .pdf only.
New Features
Key
Summary
VIZART-5086
Add "Name" Label to Indicate Scene Name Field in "Save Scene As" Dialog
VIZART-5061
Add a counter to file links inside the asset view
VIZART-5447
Add Advance Options for Light Falloff
VIZART-5408
Add checkbox to enable/disable NVDEC for Clip Texture Renderer
VIZART-5077
Add Clear Search Functionality for Built-in Geometries in Scene Tree Search
VIZART-5415
Add config option for text to use classic extrusion
VIZART-5458
Add configuration GUI for HDR settings
VIZART-5399
Add context menu to DynamicGeometry for selecting nodes
VIZART-5266
Add Delete as shortcut to delete scenetree containers
VIZART-5273
Add Desaturation effect control in PreFX Texture Renderer
VIZART-5450
Add importer option for new geometries
VIZART-5387
Add information about UHD2 resolutions to output formats
VIZART-5375
Add Libero Fill&Key render sequence
VIZART-5448
Add missing icons for dynamic geometry nodes
VIZART-5353
Add support for Webchannels
VIZART-5164
Add Tooltips in Graphic Hub Integration
VIZART-5132
Add Visual Feedback for Cut Operation in Scene Tree
VIZART-5416
Add widgets to change HDR properties (VER scene): colorspace, transferfunction, whitelevel
VIZART-5173
Adding Mediaassets via Context menu does not update Scene Overview
VIZART-5297
Audio driver mode: change driver mode options to accommodate changes in audio settings
VIZART-5223
Change color of toolbar extension button on Timeline Editor
VIZART-5195
Container color changes improvement
VIZART-5319
Create a color control for HDR use cases
VIZART-2174
Create new UI for After Effect Import Task
VIZART-5228
CTRL+C/CTRL-SHIFT-V from the search results
VIZART-5116
Default Color mode not working
VIZART-5283
Double clicking a transition shader opens the script window
VIZART-5313
Drag and droping a scene on container in Scene Tree creates subscene instead of loading scene
VIZART-5280
Drag Plugins/Assets into Tree View Directly as Sibling
VIZART-5258
Enable Magnifier Plugin in Viz Engine Renderer
VIZART-5342
Explicitly list non-unique Control Plugins
VIZART-5306
Expose material color to control channels (Phong and PBR)
VIZART-5340
Expose stylesheet settings in Artist UI
VIZART-5460
Hide new output option when hardware is not Matrox
VIZART-5078
Improve Search Asset Items Display and Tooltips in Scene Tree
VIZART-5252
Improve workflow for setting clips
VIZART-5391
Improved DynamicGeometry creation workflow
VIZART-5317
Let user rearrange Function Plugins to define priority
VIZART-5216
Make reverse button easier to distinguish in Timeline Editor
VIZART-4344
Missing "?" Icon in Detached Dock Windows without Group
VIZART-5385
Parallel Output Configuration
VIZART-4911
Possibility to configure used font inside the text editor
VIZART-5517
Provide context menu entries to assign colorspace/tf to image
VIZART-5455
Provide context menu entry to convert image
VIZART-5240
Re-Implement Scene Tree Sort Menu
VIZART-5463
Replace shipped documentation by online version
VIZART-3997
Research and develop new version of Viz One Browser based on Qt
VIZART-5411
Separate Generator and Modifiers nodes in DynamicGeometryEditor
VIZART-5276
Show current active Graphic Hub in Artist title bar
VIZART-3843
Show PropertyStatus on Container level.
VIZART-5202
Snapshot popup position
VIZART-5400
Use Extrusion editor for extrusion nodes in a dynamic geometry editor
VIZART-5249
Vertical alignment setting in Text Editor not updating
VIZART-5354
Visual hint for Format dependent animation channels in stage
VIZART-4975
Viz 5 GUI: Control Objects improvements
Fixed Issues
Known Issues
Windows
Build Information
Documentation
Info: Starting with Viz Artist/Viz Engine 5.4.0, the installer no longer installs an offline documentation.
Documentation for Viz Engine, Viz Artist and Viz Plugins is available online on the Vizrt Documentation Center:
Support
Installation
The installation wizard guides you through the installation process. Make sure to close any running Viz Artist/Viz Engine application, prior to the installation. To run Viz Artist or Viz Engine independent of a database server, you need to install the Graphic Hub database software locally.
Support
