Viz Artist 5.6.0
Release Date: 2026-11-19
These are the release notes for Viz Artist version 5.6.0. This document describes the user-visible changes that have been made to the software since release 5.5.0.
ATTENTION: The Bundle Installer no longer includes WibU Codemeter runtime.
This mandatory component needs to be installed manually. Please download it manually or run
winget install --id Wibu-Systems.CodeMeterRuntimeKit -e
Installer Notes
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
  • Viz Artist is installed in C:\Program Files\Vizrt\VizEngine\VizArtist.
  • Visual C++ Redistributable files are not part of the .msi setup file anymore. These files are now installed with the bundle setup application (VIZENG-13210, VIZENG-12629, VIZENG-12701).
  • The new bundle setup application installs or upgrades Viz Artist together with its required Visual C++ Redistributable files (VIZENG-12936, VIZENG-13804).
  • All files contained in the bundle setup application can be extracted using the /dump command line option. This creates a sub-folder where the files are extracted (VIZENG-13020).
  • Multiple installations of Viz Artist are not supported.
  • The installer automatically upgrades (replaces) any existing Viz Artist 3.x installation. However, downgrading is currently not supported (VIZENG-7098).
  • The installer package is digitally signed (VIZENG-7378).
  • The user account must have SeCreateGlobalPrivilege (SE_CREATE_GLOBAL_NAME) enabled.
Windows
This software has been tested to run on the following systems:
  • Windows Server 2019
  • Windows Server 2022
  • Windows 10 (LTSC 21H2)
  • Windows 11 LTSC 2024
Note: Only English language Operating Systems are supported.
  • It is recommended to install the latest Windows Security Updates and Patches, except NVIDIA drivers.
  • .NET Framework 4.5 or higher is required (VIZENG-6036).
  • Minimum Windows Installer version is now 5.0.0.
  • To run Viz Artist/Viz Engine without Administrator privileges, you need to grant the following permissions:
    • SeIncreaseBasePriorityPrivilege
    • SeCreateGlobalPrivilege
    • SeCreatePagefilePrivilege
    • SeIncreaseWorkingSetPrivilege
Note: Viz Artist requires a minimum resolution of 1920x1080 pixels.
Windows
  • Network shares are not accessible from within Viz Artist when UAC is enabled or when running on Windows 10. The Viz Configuration page Local Settings has been extended for enabling Network drive linking (VIZENG-15594, VIZENG-15319).
UAC
  • Viz Artist is UAC aware. Log-files and additional files are stored in %VIZ_PROGRAMDATA%, which defaults to %ProgramData%\Vizrt\VizArtist. Configuration-files and profiles are stored in %ProgramData%\Vizrt\VizEngine. Temporary data is stored in %VIZ_TEMPDATA% which defaults to %TMP%\Vizrt\VizEngine. The default value can be changed in viz.cmd or on the command line of viz.exe.
  • Starting Viz Artist shows a UAC popup for VizStarter.exe (VIZENG-8683).
Changes
  • Note: Viz Artist no longer installs the local version of the documentation. Documentation is available online or as .pdf only.
New Features
SummaryKey
"Welcome back" screen VIZART-5723
Add LUT support for CamerasVIZART-5745
Allow to add Path aliases directly in Import viewVIZART-5798
Asset view: Quick Look featureVIZART-4475
Better Workspace (Shader/Textures) UXVIZART-5718
Double-click on a TR file inside a material should jump to used TR file inside the Workspace viewVIZART-5763
Double-click on a TR file should jump to the folder where it is stored inside the asset viewVIZART-5647
Exit Dialog improvementsVIZART-5746
Improve Scene tree searchVIZART-5726
Indicate containers belonging to subscene in scene treeVIZART-5733
Make it possible to Import/Export saved workspaceVIZART-4044
Merged title bar for Viz ArtistVIZART-4558
New improved logicmaker implementationVIZART-5781
New Tracking timing overlay in On Air ViewVIZART-5666
Offer splitting geometries on container dropVIZART-5803
Texture Slot copy and deactivating VIZART-5606
UI for AI keyer scene settingsVIZART-5744
Fixed Issues
SummaryKey
Syncobjects list not working for Superchannels in texture modeVIZART-5921
MultiSelection: Container Info Width and Height does not display combined BoundingBox sizeVIZART-5874
HEX color values will get stuck in dialogue box if it is not a complete hex valueVIZART-5817
Can't set SD output formats via the config GUIVIZART-5810
Plugin favorites can disappear in certain scenariosVIZART-5787
Plugin favorites are only visible after Artist restartVIZART-5786
Post rendering preview no longer follows the duration valueVIZART-5778
Custom Tree Colors Are Not previewed in Config-UI After RestartVIZART-5770
Viz Maps Plugins installer removed from bundle installerVIZART-5765
Script plugin view doesn't get updatedVIZART-5704
RegisterSeperator script function shows name twice inside the plugin viewVIZART-5698
Modifying classic font parameters on multiple selected text containers doesn't workVIZART-5263
VizOne Clip preview fails if source is httpsVIZART-5180
Security Updates
SummaryKey
Known Issues
SummaryKey
"Open tree" and "Collapse tree" in Asset viewVIZART-5226
Adaptive: Postion/Rotation/Scale do not show underlineVIZART-4332
Apply Blur in Image Editor forces flickering of update window VIZART-5171
Drag & Drop of Flexbox ParametersVIZART-3515
Extend Snapshot dialog for configured color spaceVIZART-5615
Implement right mouse drag for color selectorVIZART-5554
Jump to Container from Texture Media Asset not working in New Render pipelineVIZART-4348
Superchannel Asset Preview is not being updatedVIZART-4983
Viz One: Test Connection only works if entry is selectedVIZART-4398
XRDraw/Particle not accepted as plugin searchVIZART-5345
  • Quick Look feature can’t work on Scene View Texture Renderer Material Definitions as they need a scene to render.
  • Not all audio formats support displaying a waveform and additional informations in Quick Look.
  • Control Object View will not highlight the correct Control plug-in from within a list if multiple control plug-ins are on one container.
  • Due a technical limitation of Qt framework, the focus of an input field can not be restored when switching containers.
  • Referenced Materials do not correctly update their icon if changed.
  • It is not recommended to run the User Interface within a Virtual Set environment, as it can cause timing issues under certain circumstances.
  • Viz Engine render window is always on top when started in videowall mode -u1 -y -n and output system FULLSCREEN (VIZART-2400). Does not happen in mode -u1 -w or with any vga_preview and is independent on the number of monitors and if a mosaic is used or not.
    • What can be observed is that the output is always on top and it is not possible to get anything else on top (taskbar, other windows with ALT + TAB, task manager). SHIFT + BACKSPACE works only when Viz Artist has focus. When CTRL + BACKSPACE does not work it can be achieved with CTRL + ALT + DEL, task manager, ALT + TAB to Viz Artist and SHIFT + BACKSPACE. ALT + TAB does not work initially as the window is not shown. This behavior is actually desired to have the output of Viz Engine always on top (for example, interactive scenes shown on screens in the studio).
Windows
  • Right clicking on the Taskbar icon of Viz Engine starts a new instance. Starting an additional Viz GUI process is prevented on Windows 10.
Build Information
  • Platform Toolset: Visual Studio 2022 (v143)
  • Windows SDK Version: 10.0.22621
Documentation
Info: Starting with Viz Artist/Viz Engine 5.4.0, the installer no longer installs an offline documentation.
Documentation for Viz Engine, Viz Artist and Viz Plugins is available online on the Vizrt Documentation Center:
Support
Installation
The installation wizard guides you through the installation process. Make sure to close any running Viz Artist/Viz Engine application, prior to the installation. To run Viz Artist or Viz Engine independent of a database server, you need to install the Graphic Hub database software locally.
Support
