Channel Basic Info
Screen Dimension: Reference-value for Page Editor Preview panel. Options are:
SD NTSC: 720 x 486
SD PAL/SECAM: 720 x 576
HD 720: 1280 x 720
HD 1080: 1920 x 1080 (current default value)
Aspect Ratio: Defines the aspect ratio of the Page Editor's Preview panel. Options are 4:3 and 16:9.
Frames per Second: Defines the frame rate at which the output will be displayed. The Media Sequencer may be responsible for the entire playlist or only secondary events (when an external system controls the primary events).
Unless this setting is correct, the Media Sequencer will not calculate the events correctly, creating a frame inaccurate system. See Triggering Control.Broadcast Day Start Time: The broadcast day start time in use for the channel.
Triggering Control
Timed Playout: Allows Media Sequencer to control the triggering of the playlist’s timed events.
External Triggering: Allows the automation system to trigger the playlist’s timed events.
Triggering: Allows you to define the level at which the automation system will have control over the timed events.
Primary Events:
Media Sequencer will trigger the secondary events based on offsets to the timed primary events.Secondary and Video Events:
The automation system is in full control of the playlist and Media Sequencer will act as secondary.
Note: Using Secondary and Video Events and assets from Viz One system as Primary Events, the video of the primary Primary and all other Secondary types can be played out in combination and controlled from Automation.
Playlist Date Management
All events in one playlist: Allow only one continuous playlist exist per channel. Regardless of time and on-air date, all events are included in the imported playlist. This setting is recommended.
Split events by date: Schedules received from automation systems are split by date. When selected, events are separated by date and begin time into broadcast-date playlists according to the Broadcast Day Start Time settings (above).
