Exporting from LST
When exporting from an LST schedule file:
  • A new LST schedule file in the LST version 12 format (with header) is produced, regardless if the processed schedule file is LST version 11, LST version 12 or a headless file.
  • The original, processed schedule file will remain untouched.
  • The new schedule file will be named either
  • The new schedule file is placed in the folder specified in Channel Settings.
  • The export process happens after every imported/updated schedule file.
  • The exported schedule will be in the schedule time zone.
Direct Export
Performing a Direct Export produces a schedule file containing each event present in the playlist(s) that was added or modified during the import process.
This includes:
  • Events imported from the processed schedule file.
    This includes Message Events introduced due to missing Page, Action or PDE.
  • Events added by Rules.
  • (At update) Events that were previously there, regardless of origin, such as manually added events or events added by the import/update of a previous schedule file.
A new header is created for the exported schedule file.
Merge Export
When performing a Merge Export:
  • A schedule file is produced containing every event in the processed schedule file merged with the events added by Rules after the import/update process.
  • The events added by Rules do not necessarily mean they were added during the import/update of the processed schedule file.
    If events added by Rules were already previously present, those might or might not be merged into the processed schedule file.
  • If an event added by Rules is not under a Primary Event contained in the processed schedule file, the event will be skipped from being merged, as an event that is missing a Primary Event parent can not be merged.
  • Events merged are placed under the Primary Event that they belong to, in the binary of the exported schedule file.
  • The header is updated with the correct timestamp and checksum.
Export Characteristics
Event Metadata Loss
In the case of an event being imported as a Message Event due to a missing Page, Action or PDE, its metadata will not be preserved, as metadata for Message Events is not saved. This is relevant as certain information coming from the LST schedule file is saved as event metadata to later be retrieved during the export process. The lack of metadata in an event will lead to an incomplete exported event.
Exported Data too large for LST Structure
Due to size limitations of an LST structure for event data, event data exceeding LST structure limits will be truncated with the maximum possible information being saved.
For example, for an event containing a description larger than 32 bytes (the maximum size), only exports the first 32 bytes.
Exported Event TITLE
The TITLE field of exported secondary events will have the value of its page name. The playlist description of secondary events is not saved during the export process. For exported primary events, the TITLE field will contain the information in the playlist description.
Universal Sercom Driver
If an imported event has its Trigger Id value replaced due to the usage of Universal Sercom Driver (USD), then this process will be reverted during the export process. To achieve this, the original value for Trigger Id is saved in event metadata during the import process.
Note: This is only possible if metadata is preserved. Not every event type supports metadata.
Note: Page is not restored in the event of being replaced by USD. Events added by rules and manually added events are not considered if USD is used. This is planned to change in the future.
LST Version 11 to 12 Conversion
As the exported schedule file will always be in LST version 12, a processed LST version 11 schedule file will be converted to LST version 12 during the merge export process.
Note: This conversion process is not required for Direct export.
The conversion process attempts mapping of data from a v11 structure to a v12 structure in the best way it can:
  • New data only available in v12 will have default value.
  • Dynamic data will be combined with their respective fields.
    For example, ExtendedId will be combined with Id.
