The ability to join fields and store info in a Mapping Table for an import module and instantly re-use it to another mapped variable. By default, the variable begin_at is mapped up to be a merge of the Date- and Time-field, with a value-separator.
date = /date/
time = /time/
begin_at = @dateT@time
The text between joined fields can be of any size.
title = /title/
date = /date/
description = Video @title playing on @date
Fields with same the same starting name will have the longer field prioritized. In the following example, @titleid will be prioritized over @title"id".
title = /title/
titleid = /titleid/
description = DescriptionFor@titleidInPlaylist
IMPORTANT! The merging field must be located in the table after its parts-fields.
Example 1 for Fixed Width Any Text Import Type
StartHour
= $L(1,2)StartMin
= $L(3,4)StartSecond
= $L(5,6)Begin
= @StartHour:@StartMin:@StartSecond
Example 2 for Delimited Any Text Import Type
StartHour
= $L(4)StartMin
= $L(5)StartSecond
= $L(6)Begin
Example 3 for Any XML Import Type
This example shows time read in a format HH-MM-SS-FF from an entry /begin_time/time/.
TheStartTime
= /begin_time/time/StartHour
= &(TheStartTime,”-”,1,1)StartMin
= &(TheStartTime,”-”,2,1)StartSecond
= &(TheStartTime,”-”,3,1)StartFrame
= &(TheStartTime,”-”,4,1)Begin
= @StartHour:@StartMin:@StartSecond:@StartFrame
