When working with a specific channel, you can select one or several scenes for import.
To view and select scenes for import
Click Template Import at the lower right to view the contents of your Viz Graphics Hub and select scenes for importing. Scenes can be sorted by Name and Modified date, by clicking their respective column header.
Double-click scenes to import or select several and right-click and select Import Scene to Channel.
Note: You must have a working Viz Graphics Hub connection to view the content. For information on how to configure your local Viz Engine Database connection settings, see the Viz Engine Administrator Guide.
