Slot/Card Installation
Default Hardware
  • Single CPU 20-Cores​
  • Dual redundant Power Supply ​
    • 1125/1450W Platinum redundant, hot-swap
  • PCIe Gen4 + Gen5 Slots
  • 8 PCIe Slots
  • 64GB DDR5
  • 1x 512GB M.2 + 1x 1TB M.2
  • 2x Gbit RJ45 onboard
  • OS Support:
    • Windows 10 LTSC 2021
    • Windows 11 LTSC 2024
  • GPU Support: ​
    • A2000
    • A4000
    • A5000
    • A6000
    • 4000 Ada
    • 5000 Ada
    • 6000 Ada
PCI Configuration
Slot
Usage
Slot 1 Gen5 x16
Second Graphics Card (no Monitor)
Slot 2 Gen5 x4
Free or used by Dual Slot GPU
Slot 3 Gen5 x16
First Graphics Card (with Monitor)
Slot 4 Gen4 x4 (PCH)
Slot 5 Gen4 x16
Matrox Video Card (X.mio3, X.mio5, DSX LE4)
Slot 6 Gen3 x8
Empty
Slot 7 Gen4 x16
Matrox M264 or other Expansion Card (Serial, GPI)
Slot 8 Gen4 x4 (PCH)
Other Expansion Card (Serial, GPI)
Bios Settings
  • Security/Secure Boot Configuration Secure Boot: Enable
  • Advanced/Built-In Device Options:
    • Increase PCIe Idle Fan Speed(%): 50
    • PCIe Idle Fan Tracking mode: Enable
  • Advanced/Power Management Options:
    • Hardware P-States: Disable
    • S4/S5 Maximum Power Savings: Disable
    • PCI Express Power Management: Disable
  • Advanced/Performance Options:
    • Workload Configuration: I/O-Focused
  • Advanced/Power Supply Options:
    • Power Supply Mode: Redundant
