This section describes the specification and PCIe board layout of a HP ZCentral 4R machine with the different cards provided by Vizrt.
Default Hardware
  • Server 1RU
  • OS: Windows 10 IoT Enterprise LTSC 2021
  • CPU: 1x Intel Xeon W-2235 6-Core
  • RAM: 32 GB DDR 4 (2x 16GB)
  • 1st SSD: 512 GB M.2 on Mainboard
  • 2nd SSD: 512 GB M.2 on Mainboard
  • RAID Controller: Intel Onboard
  • Hot Plug Power Supply: 2x 675W
Connectors
Front Connectors
  1. Front I/O module power button, 2 USB-A 3.1 G1, 2 USB-C 3.1 G2, Headset audio
  2. 2 x 2.5” external drive bays
  3. Optional 1 x 3.5” or 2 x 2.5” drive bay
  4. Locator LED
  5. 2 x external 675W PSU bays
Back Connectors
6. Primary PSU connector
7. Secondary PSU connector
8. Rear power button
9. Padlock loop
10. 1GbE RJ-45 (AMT)
11. 1/2.5/5/10GbE RJ-45
12. 4x USB 3.1 G1 Type-A
13. Single Slot Riser (1 PCIe G3 x16)
14. Dual Slot Riser
  • 1 x PCIe G3 x16*
  • 1 xPCIe G3 x16 wired as x8
Info: Slot 2 runs at Gen3 x8 Speed, if Slot 3 is loaded.
PCIe Configuration with A4000
Slot
Usage
Slot 1
Graphics Card (Single Slot)
Slot 2
Matrox Video Card (X.mio3, X.mio5, DSX LE4) or other PCIe card
Slot 3
Matrox AES Audio or other PCIe card
PCIe Configuration with A2000 or A5000
Slot
Usage
Slot 1
Slot 2
Graphics Card (Dual Slot)
Slot 3
Info: Dual A4000 or Single A6000 GPU configurations will not run power redundant and are not tested by Vizrt.
BIOS Settings
  • During post, press F10 to access BIOS setup.
  • Click Advanced tab > Boot Options: Enable the Fast Boot.
  • Go back to Advanced tab > Secure Boot Configuration. Select Legacy Support Disable and Secure Boot Enable.
  • Go back to Advanced tab > Build in Device Options. Increase PCIe Idle Fan Speed to 0020.
  • Press ESC and save configuration.
Info: Certain third party vendor drivers require secure boot to be disabled to install properly.
