Viz Artist 5 introduced a significantly enhanced user experience. An all-new Scene Tree benefits users with improved accessibility and navigation within Scene Tree Containers.
New versions of Layer Manager and Scene Overview panel were included, plus IES Lighting and Adaptive Scene Design (which intelligently adjusts pre-defined output formats on the fly) are just some of the new features of Viz Artist 5.
The latest release, Viz Artist 5.3, delivers an improved user experience driven by a modern state-of-the-art user interface, coupled with an increase in application performance and several new features.
New Particle System
Viz Engine 5.3 introduces the first iteration of a GPU accelerated Particle Effects System.
At introduction, Fire and Smoke are offered (with modifiers available, such as Wind, Turbulence, and Gravitation).
Third-party Particle Effect System plug-ins will also be possible via API.
Read more…
Improved PBR Workflow
When a set of images is imported, Viz Artist 5.3 detects if a PBR material can be generated. If matching images are detected, Viz Artist automatically creates the material, saving time and improving workflows.
Viz Artist users can now drag ZIP files into the Viz Artist GUI and files automatically expand and import into Graphic Hub.
Read more….
New XR/AR Possibilities
AR elements are defined and more easily visualized within a Scene as layers in front of virtual set extensions, the video wall, and the talent. Users benefit from this simplified XR workflow when implementing AR graphics and virtual set extensions adjacent to video walls.
Within Virtual Set use cases, users have the option to dedicate a GPU to Unreal Engine, while Viz Engine maintains the capability to run on a separate GPU.
Performance is increased across the workflow and Scenes can be optimized efficiently.
Improved Clip Playback
With the new container based Clip Player implementation, Viz Engine Render offers a new alternative to the Softclip solution in the Classic Render Pipeline while supporting most common codecs.
A switch to GPU-based hardware acceleration with NVDEC (NVIDIA Decoder) significantly enhances Clip Player Pro performance.
NDI 6 & HDR
Support for NDI 6 has been added to Viz Engine 5.3 and includes support for HDR HLG workflows on input and output.
HDR S-Log3 is added, as is support for HDR displays and HDR video walls – as managed through the HDR feature within Microsoft Windows OS.
Viz Engine Migration Helper Tool
Many Viz Engine users are operating on legacy Viz Engine 3.x and Viz Engine 4.x hardware and software. This is severely limiting their ability to implement modern and efficient graphics workflows. One reason given for the delay is that they operate with very large graphic libraries and therefore must contend with time and resource constraints.
 Viz Engine 5.3 introduces a ‘Classic Render Pipeline’ Viz Engine Renderer Migration Helper Tool that will save many hours of effort to migrate and convert large graphic libraries to the new and more powerful Viz Engine Renderer.
Read more….
Viz Engine
Integrations
  • Classic – Viz Engine Render Pipeline migration helpers
  • NDI 6 Support + HDR HLG workflows ​
  • HDR S-Log3 Support
  • Clip Player Pro – GPU Hardware Acceleration
  • Container/Scene-based clip playback for Viz Engine Render Pipeline
  • Matrox DSX LE 5 SDI LP Support
  • Support RTX 4500 Ada and RTX 5000 Ada
  • New Audio Backend
  • Parallel Output Additions
    • Matte Scene Output
    • Precision Keyer Preview/Aux Output​
  • Improved IO delay handling and configuration
  • Frameserver Core
  • Quick Presets
  • Viz Engine Render Pipeline Improvements
    • Particle System
    • Limited Front- and Back- Layer compatibility mode
    • Multi-Layer XR Set sequence to render Set Extension + AR objects​
    • Interactive XR Line drawing tool to combine with Reality Connect or trackers
    • Plug-in API
      • Compute Shader Support
      • Buffer Objects (Compute Shaders, Instancing)
    • Runtime/Plug-in Material Shadow and Picking
    • Hot-reloading of textures
    • Shadow Light
    • Scene View additions (disable self draw)​
    • HDR Window/Context creation for HDR displays
    • Interactivity support from Classic Render Pipeline
    • Improved Media Asset Compositing (blending against background color, antialiasing artifacts)
    • Preparation for Viz Libero Support
    • Newly supported Plug-ins:
      • Text FX Write
      • Temo
      • DataPool Countdown
      • Extended Control Text feature set
    • Viz Script
      • New callback functions
      • Access Material Definition Plug-in Instance
  • Security Upgrades
  • Improved image import for PBR Materials
  • Option to apply color coding to entire container
  • Configurable Shortcuts for Viz Artist and Viz Engine
  • Color schema for Live Input sources
  • Switching active Graphic Hub without restart
  • New Undo/Redo Stack
  • Examples for Vertex-, Fragment- and Transition- Shaders
  • Favorites for Fontfaces
  • New modern Icon Set
  • Unreal Engine
    • UE 5.4 Support
    • Multi GPU Support to distribute load for Viz Engine and UE
    • Multi-Layer External VS render sequence
Changed Shortcuts
The following shortcuts have changed:
Scene Editor
Action
Old Shortcut
New Shortcut
Delete Object
BACKSPACE
Added DELETE as additional shortcut
Camera View Zoom
X/Z or (O + Mouse Wheel)
X/Z or (Mouse Wheel)
Orthogonal Rubberband Zoom
X/Z + Mouse Drag
Q/W + Mouse Drag
Switch to Back Camera (Orthogonal)
Keypad 0
Keypad 1
Mouse Position/Rotate/Scale
(Undocumented and Classic only)
X/Y/Z Key + Mouse Wheel
Removed
Render Editor (On Air)
Action
Old Shortcut
New Shortcut
Off Air
ESC
Added CTRL + Q as additional shortcut
Toggle Preview
SHIFT + BACKSPACE
Added CTRL + P as additional shortcut
Stage
Action
Old Shortcut
New Shortcut
Select Keyframes
S + Mouse Drag
R + Mouse Drag
Set Stoppoint
S + Mouse Click on Director
P + Mouse Click on Director
View Spline 1/2/3
CTRL Z/X/C
1/2/3
