This section describes the procedures to configure the following options when running a Bluefish444 setup:
To Enable Dual Link Input for Epoch | 4K Supernova and Epoch | 4K Supernova S+ Boards
Stop Viz Engine.
Open the Viz Configuration file (for example: VIZENGINE-0.cfg).
Note: The default location for this file is %ProgramData%\Vizrt\VizEngine.
Locate
SECTION VIDEO
.Enable the Dual Link Input setting by changing the default value
0
to1
:dual_link_input = 1
.Save the file.
Start Viz Engine.
To Enable Dual Link Output for Epoch | Neutron
Stop Viz Engine.
Locate
SECTION VIDEO
.Enable the Dual Link Output setting by changing the default value
0
to1
:dual_link_output = 1
.Save the file.
Start Viz Engine.
To Enable Automatic Bypass for BlueFish444 Epoch Boards
Viz Engine supports automatic mechanical bypass (copper-to-copper) of video for BlueFish444 Epoch boards. To use this feature enable the feature.
Stop Viz Engine.
Locate
SECTION VIDEO
.Enable the Watchdog setting by changing the default value
0
to1
:video_use_watchdog = 1
.Save the file.
Start Viz Engine.
