Port Numbers
The table below lists all default server and listening port numbers used. When the firewall is well configured, it can be kept enabled. Client-side firewalls may cause issues when the Viz Artist/Viz Engine version is below 3.8.2 or the Graphic Hub version is below 3.0.0, since the communication protocol used was two-way and requires the firewall on the client side to be open for the Viz Artist/Viz Engine processes. However, it is not required to disable the firewall completely.
Viz Engine Ports
Service
Port(s)
Descriptions and comments
MVCP and Xlator control port for video servers.
VDCP ports
5250 TCP
Note: This port is only necessary in combination with the video server extension (Service: AVCP).
These ports are configurable in Config File:
  • MVCPServer_Port
  • vdcp_controller[n]_port
Viz World Maps Editor
1337 TCP
Websocket communication with Viz World Maps Client.
Tracking Hub communication
3000 UDP
Used by Tracking Hub to communicate with Viz Engine.
  • trackinghub_port
Control Ports
6100 TCP
6700 TCP
6800 TCP
55000-55031 TCP
56000-56015 TCP
Communication ports used by Control Applications (like Media Sequencer) to connect to a Viz Engine program and/or preview channel. Viz Engine’s default program and preview port is 6100.
In a single channel configuration where both program and preview output is on the same machine, the default preview port is set to 6800 to separate the program and preview channels.
In a dual channel configuration, the default program ports are 6100 and 6800 for channel one and channel two, respectively. In a dual channel configuration, when used for stereo production, the default program ports are 6700 and 6800 for channel one (left eye) and channel two (right eye), respectively.
For controlling Graphics Channels and/or Super Channels, ports 55000-55031 and 56000-56007 are used (can be changed in the config).
These ports are configurable via Config GUI.
Viz Engine Unreal Integration
6102 UDP
6104 UDP
6103 UDP
Communication ports from Viz Engine to Unreal Engine.
6998, ... TCP
Used to communicate with Viz Artist. Every instance opens two ports, starting with 6998 and 6999.
Note: These ports can not be changed!
Shared Memory Master Port
freely configureable
  • smm_master_eng_port
Command Feedback Port
7476 UDP
Port to send feedback of commands. This port is configurable in Config File:
  • command_feedback_port
Viz Engine REST service
freely configureable TCP
To control Viz Engine via REST commands.
This port can be configed via Config GUI.
Extension Plugin Commands via Websockets
6900 TCP
To allow to control Viz Engine via a Websocket.
This port can be changed manually in the JSON file C:\ProgramData\vizrt\VizEngine\extensions\CommandOverWebsocket.json.
Multitouch communication
TUIO
3333 UDP
To connect to a TUIO multitouch service.
  • tuio_serv
Graphic Hub
19396-19398
Ports in use when connecting to different Graphic Hub components. Since Graphic Hub version 3.0.0 and Viz Artist/Viz Engine version 3.8.2, a limited number of open network ports is required. These do not require any port exemption rules on the client side firewall configuration. However, for earlier versions, all ports must be open on the client side.
MV Network Service
50000 TCP
responsible for NMOS requests. It might be necessary to manually add this exception to an existing firewall.
netsh advfirewall firewall add rule name="Matrox NMOS API" protocol=TCP dir=in localport=50000 action=allow program="C:\ProgramFiles\Matrox DSX-TopologyUtils\System64\mvNetworkService.exe"
Multiplexer ports
50007 - 50009 TCP
Multiplexing Ports that enable Viz Engine to work on other scenes in sessions that are used for preview purposes.
50007 TCP
MUX Isolated port: All connections to this port get their own session.
50008 TCP
MUX Shared port: All connections from one single host shares one session.
50009 TCP
MUX Fixed port: Same as shared port except that allocated resources are never cleared from memory.
50010 TCP
Still Preview port: Enables a user to request a preview of the next scene to be put On Air while another scene is On Air.
WebRTC Extension Plugin
9092
Can be configured in the config file:
WebrtcOut1.WebsocketPort
or via command:
CONFIGURATION*CHANNELS*WEBRTCOUT_0*PORT SET <port_number>
OpenTelemetry
4318 (configurable)
Endpoint for Open Telemetry Monitoring Service (Viz Engine Monitor).
Information: Depending on your hardware (Matrox IP) in use, the number of ports can be much higher.
Other Integrations
Listener
Port(s)
Mediaftp
21
Used for video transfers from Viz One to Viz Engine.
Viz One
22
TCP and UDP for logging in to the Viz One operating system (Service: SSH).
Viz World Server
102
103
102 (TCP) is a Viz World Server listener port for Viz World Client connections when Server Allocator is not in use or only has one Viz World Server running.
103 (TCP) is a Viz World Server listener port for configuration tool connections to the first Viz World Server instance (as configurations are controlled by the first server instance). See also Vizrt Maps.
Viz One
137
139
Used for SMB file sharing (Service: Netbios)
Viz One, Microsoft Bing and Imagery on Demand
80
8080
Web interface and client software. SOAP port for communication with Viz One. For download of Microsoft Bing and Imagery on Demand images (Service: HTTP).
OpenSLP
427
Service Location Protocol (SLP) based discovery and search (TCP, UDP).
Viz One
443
445
(Service: HTTPS) TCP and UDP used for SMB file sharing (Service: Microsoft-DS).
Viz One Delivery
554
Real-time Streaming Protocol (Service: TCP).
Oracle database
1521
For clients that connect to the Viz Pilot Database.
Viz One
3080
Low resolution video and index files (Service: lighttpd).
Viz Trio
6200
6210
6200 is used for controlling the Viz Trio client over a socket connection.
6210 is used by the Graphics Plug-in to establish a connection to Viz Trio.
Newsroom Component
6220
Used by the Graphics Plug-in to establish a connection to Viz Pilot’s Newsroom client.
Graphics Plugin Editor
6230
Used by the Graphics Plug-in to establish a connection to the Graphics Plug-in Editor (on Mac).
Graphics Plugin Config
6240
Used by the Graphics Plug-in to establish a connection to the Graphics Plug-in Configuration tool (on Mac).
Viz Ticker Service
6300
6301
Viz Ticker handler in the Media Sequencer connects to port 6300 for feedback from Viz Ticker Service.
Viz Ticker handler in the Media Sequencer connect to port 6301 when controlling Viz Ticker via a socket connection.
Viz Pilot
6484
Socket connection used for controlling Viz Pilot using macro commands.
Viz One
6555
Message bus port for communication with Viz One (Service: Message bus).
Preview License server
7452
For the Newsroom Component using an unlicensed Viz Engine for local preview with a connection to the Preview License server (is not the same as the Preview Server).
Viz Pilot Data Server
8177
Used to connect over HTTP with the REST interface.
Media Sequencer
8580
8594
For clients connecting to the Media Sequencer. 8580 is specifically used to connect over HTTP with the REST interface.
Viz One
8080
Used for sending key frames (Service: ardok).
Gateway
10001
10002
10540
10541
For DB notification events. For Gateway controller clients. For MOS object updates. For MOS playlist updates.
Viz World Server
10100
10200
10100 (TCP) is a Server Allocator listener port for Viz World Client connections, and is only used for clients to get connection details about Viz World Server(s). The first client connection is always diverted to port 102. In case of multiple server instances, port numbers are assigned according to a predefined schema (10101, 10102 for server instance two and three and so on). In case there is no Server Allocator, Viz World Server itself switches to port 102.
10100 (UDP) is a Viz World Server listener port for Server Allocator communication.
10200 (UDP) is a Server Allocator listener port for Viz World Server communication. Both UDP ports are internal ports used between the servers. For more information, please see the Viz World Client and Server 11.1 User Guide and later.
Viz Pilot
10640
Used by Gateway to establish a connection to Viz Pilot to send and receive updates on MOS messages (for example, items and playlists).
Graphic Hub
19396-19398
Connection Broker
21098
Connection to the Connection Broker configuration interface (for example, http://localhost:21098/).
Preview Server
54000
Codemeter Webinterface
22352
To configure the Codemeter runtime via WebInterface.
Multiplexing Ports
Ports
Viz Engine
All other ports
Still Preview Port
MUX Isolated PortMUX Shared PortMUX Fixed Port
The multiplexer functionality is an integral part of Viz Engine. When using Viz Engine a session management takes place internally, with one default session for the GUI and internal/external commands, and additional sessions created on-demand for the multiplexing ports or the preview port.
With multiplex ports, other than the MUX Still Preview port, the Viz Engine state is only switched when a command is received, which means a new session is created; hence, ten consecutive commands from a client only results in one state switch on the first command.
  • The MUX Still Preview Port (50010) state is switched when a command is received and immediately switched back to the main session such that On Air rendering is not hindered in any way.
  • The MUX Fixed Port (50009) is traditionally used by the old Viz Pilot Newsroom Client, and is the same as the MUX Shared Port, except that allocated resources are never cleared from memory. To avoid memory overload, it is recommended to clean up the Viz Engine regularly when this port is used.
Info: There is no automated cleanup of memory on this port.
  • The MUX Shared Port (50008) is a shared port where all connections from one single host shares one session. It is most often used by Viz Trio and the Newsroom Client to show preview frames.
  • The MUX Isolated Port (50007) is an isolated port where all connections get their own session. It is used, for example in an NLE configuration, to deliver frames to the host NLE-system when rendering or scrubbing video clips with graphics. Using this port also suppresses bounding box commands.
All multiplexing ports are supported by all Viz Engine versions, but require a license.
Reserve Ports
It may happen that the operating system is allocating ports Viz Engine is configured to use, and therefore these ports can no longer be used by Viz Engine. To prevent Windows to allocated (for example, the Superchannel) ports, run the following command:
netsh interface ipv4 add excludedportrange protocol=tcp startport=55000 numberofports=32
This ensures the IP range 55000 to 55031 is no longer occupied by Windows.
