Supported NVIDIA GPUs
Blackwell GPUs | Ada Lovelace GPUs | Ampere GPUs | Turing GPUs | Volta GPUs | Pascal GPUs | Maxwell GPUs |
Blackwell 6000 Max Q | RTX 6000 Ada | RTX A6000 | RTX 6000 | GV100 | Quadro P6000 | Quadro M6000 |
Blackwell RTX 4000 Pro | RTX 5000 Ada | RTX A5500 | RTX 5000 | Quadro P5200 | Quadro M4000 | |
Mobile GPUs | RTX 4500 Ada | RTX A5000 | RTX 4000 | Quadro P4200 | Quadro M2000 | |
RTX 4000 Ada SFF | RTX A4500 | RTX 3000 | Quadro P4000 | |||
RTX 2000 Ada | RTX A4000 | T1000 | Quadro P3200 | |||
RTX A2000 | Quadro P2200 | |||||
RTX A3000 (mobile) | Quadro P2000 | |||||
RTX A2000 (mobile) | Quadro P1000 | |||||
RTX A1000 (mobile) |
Virtualized GPUs
The following GPUs have been tested in virtualized environments, the listed driver version is the one being used. The following GPUs are currently supported (Kepler are only supported in the Classic Render Pipeline):
Model | Driver | Platform |
NVIDIA L4 | 573.07 | AWS (g6 instances, gr6 instances) |
NVIDIA A10G | 573.07 | AWS (g5 instances) |
NVIDIA T4 Tensor Core | 573.07 | AWS (g4dn instances) |
NVIDIA Tesla V100 | 431.79 GRID9.1 | AWS (p3 instances) (1) |
NVIDIA A40 (2) | 572.60 | vSphere 7.0 and 8.0 |
NVIDIA RTX6000 | 572.60 | vSphere 7.0 and 8.0 |
(1) Instance not supported on Windows Server 2025 or higher (legacy uefi boot).
Driver History
Viz Artist/Engine Version | Driver |
5.5.0 | 573.76 for Ada Lovelace GPUs |
5.4.1 | 572.83 for Ada Lovelace GPUs |
5.4.0 | 572.83 for Ada Lovelace GPUs |
5.3.1, 5.3.2 | 553.24 for Ada Lovelace GPU |
5.3.0 | 552.22 for Ada Lovelace GPUs |
5.1.0, 5.1.1, 5.2.0, 5.2.1 | 528.89 for Ada Lovelace GPUs |
5.0.0, 5.01 | 516.59 |
4.4.0, 4.4.1 | 472.12 |
4.3.0, 4.3.1 | 462.31 |
4.2.0 | 442.19 |
3.13.x, 3.14.x,4.0, 4.1 | 419.17 |
3.9.x, 3.10.0, 3.11.x, 3.12.x | 385.41 |
3.8.3 | 368.86 |
3.8.2 | 361.91 |
3.8.1 | 353.82 |
3.8.0 | 347.25 |
3.6.4 | 341.21 |
(1) When used in combination with Unreal Engine 5.3 and higher, 572.83 is mandatory. | |
Note: There is no driver recommendation for virtual environments as they rely on the host operating system being used.
