Depending on the current run status you can use the buttons in the lower left corner of the interface to Start, Restart, or Stop the Gateway:
When Gateway is running, the following buttons are visible and enabled:
When Gateway is stopped, the following button is visible and enabled:
If the MSE_VIZGATEWAY license has expired, the Start button is disabled if the gateway is stopped.
Similarly, the Restart button is disabled if the gateway is running when the license expired.
Starting the Gateway
Start the Gateway Client when it is stopped.
To start Gateway, click Start.
A message appears in the messages area confirming that Gateway has started.
Stopping the Gateway
Stop the Gateway Client when it is running.
To stop Gateway, click Stop.
A message appears under Message area confirming that Gateway has stopped.
Restarting the Gateway
Restart the Gateway client when it is running.
Note: Refreshing the browser does not restart the Gateway; this only reloads the page.
Click Restart.
You receive a message that Gateway is stopping, followed immediately by another message that Gateway was initialized again.
Tip: Please keep in mind that changing some Gateway configuration settings requires a restart in order for the changes to take effect.
