These config files are initially located in the Viz Mosart Server installation folder in a sub folder, Configuration Files.
For operations, you copy the file to "%ProgramData%/
Calrec TCP/IP Configuration File
The Calrec TCP/IP configuration file is named AudioMixerCalrec.xml.
Please see the file for the available settings and their documentation.
SSL Configuration File
The SSL configuration file is the same as used for Calrec TCP/IP Configuration File.
Lawo Ember+ Configuration File
The Lawo Ember+ configuration file is named AudioMixerLawoEmberPlus.xml.
Ardour Configuration File
The Ardour configuration file is named AudioMixerArdour.xml.
MidiMixer Configuration File
The MidiMixer configuration file is named AudioMixerMidiMixer.xml.
General Audio Mixer Configuration File
For the other audio mixers, those not specifically mentioned above, there is a general configuration file named AudioMixerConfiguration.xml.
Note: In the default version of this file, there are some settings specific for the Lawo RMNOPL audio mixer driver.
