Note: This example relates to the topic GPI/O.
Sample Configuration (W&T Web-IO)
W&T's Web-IO products enable TCP/IP Ethernet-based switching signals for control, acquisition and monitoring. Their products are accessed using API queries from, for example, a standard web browser, or in this case, Viz Mosart.
From the Web-IO side, GPI is enabled by attaching a device capable of sending GPI signals to Viz Mosart. The configuration below shows configuration of a W&T Web-IO device capable of 24 GPI/GPO connections.
This configuration uses at a maximum 24 GPO signals. A maximum of 12 GPI signals can be used to control Viz Mosart.
GPI 0-4
The first 5 GPI signals are connected to fixed Viz Mosart commands for backward compatibility.
The signals are as follows:
GPI 0 - Reload rundown. Triggers a rundown reload event. The timeline will be stopped and the current rundown will be reloaded from the NCS cache.
GPI 1 - Start/continue rundown. Triggers the TAKE-NEXT event and with then start the timeline or advance to the next timeline element.
GPI 2 - Start rundown from top. Starts the rundown from the first story.
GPI 3 - Disable rehearsal mode.
GPI 4 - Enable rehearsal mode.
GPI 5-11
Each of the GPI signals 5-11 may be assigned to either trigger a Viz Mosart control command, trigger an arbitrary template from the active template set or trigger a direct take.
Working configuration from Viz Mosart Lab in Bergen, October 2014
<?xml version="1.0" encoding="ISO-8859-1"?>
V2.30, Aug 1 2013, 12:55:23
<io-Digital12x12.3>
<Config>
<Device>
<Text>
<DeviceName>WEBIO-<wut1></DeviceName>
<DeviceText> From the terminal block directly to the network </DeviceText>
<Location></Location>
<Contact></Contact>
</Text>
<Time_Date>
<TimeZone>
<UTCoffset>01:00</UTCoffset>
<Enable>
<Apply_Time_Zone>ON</Apply_Time_Zone>
</Enable>
<Summertime>
<UTCoffset>02:00</UTCoffset>
<Enable>
<Apply_Summertime>ON</Apply_Summertime>
</Enable>
<Start>
<Month>
<January>OFF</January>
<February>OFF</February>
<March>ON</March>
<April>OFF</April>
<May>OFF</May>
<June>OFF</June>
<July>OFF</July>
<August>OFF</August>
<September>OFF</September>
<October>OFF</October>
<November>OFF</November>
<December>OFF</December>
</Month>
<Mode>
<first>OFF</first>
<second>OFF</second>
<third>OFF</third>
<fourth>OFF</fourth>
<last>ON</last>
</Mode>
<Weekday>
<Sunday>ON</Sunday>
<Monday>OFF</Monday>
<Tuesday>OFF</Tuesday>
<Wednesday>OFF</Wednesday>
<Thursday>OFF</Thursday>
<Friday>OFF</Friday>
<Saturday>OFF</Saturday>
</Weekday>
<Time>02:00</Time>
</Start>
<Stop>
<Month>
<March>OFF</March>
<April>OFF</April>
<May>OFF</May>
<June>OFF</June>
<July>OFF</July>
<October>ON</October>
</Month>
<Mode>
<first>OFF</first>
<third>OFF</third>
<last>ON</last>
</Mode>
<Weekday>
<Sunday>ON</Sunday>
</Weekday>
<Time>03:00</Time>
</Stop>
</Summertime>
</TimeZone>
<TimeServer>
<UTCServer1>de.pool.ntp.org</UTCServer1>
<UTCServer2>europe.pool.ntp.org</UTCServer2>
<SyncTime>0</SyncTime>
<Enable>
<Apply_TimeServer>OFF</Apply_TimeServer>
</Enable>
</TimeServer>
<DeviceClock>
<Time>15:56</Time>
<Day>01</Day>
<Month>01</Month>
<Year>2004</Year>
</DeviceClock>
</Time_Date>
<BasicSettings>
<Network>
<IP_Addr>10.211.114.124</IP_Addr>
<Subnet_Mask>255.255.255.00</Subnet_Mask>
<Gateway>10.211.114.01</Gateway>
<BOOTPClient>
<STATIC>ON</STATIC>
<BOOTP_enable>OFF</BOOTP_enable>
<DHCP_enable>OFF</DHCP_enable>
</BOOTPClient>
<DnsServer1></DnsServer1>
<DnsServer2></DnsServer2>
<KeepAliveTime>00</KeepAliveTime>
</Network>
<HTTP_Set>
<Startup>
<index.htm>ON</index.htm>
<home.htm>OFF</home.htm>
<user.htm>OFF</user.htm>
</Startup>
<Enable>
<GET_Header_enable>OFF</GET_Header_enable>
<GET_HTTP_enable>OFF</GET_HTTP_enable>
</Enable>
<_HTTP_Port>80</_HTTP_Port>
<InputTrigger>
<Input_0>ON</Input_0>
<Input_1>ON</Input_1>
<Input_2>ON</Input_2>
<Input_3>ON</Input_3>
<Input_4>ON</Input_4>
<Input_5>ON</Input_5>
<Input_6>ON</Input_6>
<Input_7>ON</Input_7>
<Input_8>ON</Input_8>
<Input_9>ON</Input_9>
<Input_10>ON</Input_10>
<Input_11>ON</Input_11>
</InputTrigger>
</HTTP_Set>
<HTTP_Client>
<HTTP_Client>
<HTTP_Client_enable>OFF</HTTP_Client_enable>
</HTTP_Client>
<Enable>
</Enable>
<LocalPort>AUTO</LocalPort>
<ServerPort></ServerPort>
<Server_IP_Addr></Server_IP_Addr>
<ServerUrl></ServerUrl>
<InactiveTimeout></InactiveTimeout>
<InputTrigger>
<Input_0>OFF</Input_0>
<Input_1>OFF</Input_1>
<Input_2>OFF</Input_2>
<Input_3>OFF</Input_3>
<Input_4>OFF</Input_4>
<Input_5>OFF</Input_5>
<Input_6>OFF</Input_6>
<Input_7>OFF</Input_7>
<Input_8>OFF</Input_8>
<Input_9>OFF</Input_9>
<Input_10>OFF</Input_10>
<Input_11>OFF</Input_11>
</InputTrigger>
<Timer_Cron></Timer_Cron>
</HTTP_Client>
<Mail>
<Name>Web-IO 12xDigital</Name>
<ReplyAddr>Web-IO@no.reply</ReplyAddr>
<MailServer></MailServer>
<Authentication>
<_SMTP_authentication_off>ON</_SMTP_authentication_off>
<_ESMTP>OFF</_ESMTP>
<_SMTP_after_POP3>OFF</_SMTP_after_POP3>
</Authentication>
<User></User>
<Password></Password>
<POP3_Server></POP3_Server>
<Enable>
<Mail_enable>OFF</Mail_enable>
</Enable>
</Mail>
<SNMP>
<Community_String_Read></Community_String_Read>
<Community_String_Read_Write></Community_String_Read_Write>
<Manager_IP></Manager_IP>
<SystemTraps>
<Cold_Start>OFF</Cold_Start>
<Warm_Start>OFF</Warm_Start>
<Diag_Messages>OFF</Diag_Messages>
</SystemTraps>
<Enable>
<SNMP_enable>ON</SNMP_enable>
</Enable>
</SNMP>
<UDP>
<Port>42279</Port>
<RemotePort></RemotePort>
<Enable>
<UDP_enable>OFF</UDP_enable>
</Enable>
</UDP>
<Syslog>
<SyslogServerIP></SyslogServerIP>
<SyslogServerPort>514</SyslogServerPort>
<SystemMessages>
</SystemMessages>
<Enable>
<System_Messages_enable>OFF</System_Messages_enable>
</Enable>
</Syslog>
<FTP>
<FtpServerIP></FtpServerIP>
<FtpControlPort>21</FtpControlPort>
<User></User>
<FtpAccount></FtpAccount>
<Options>
<PASV>OFF</PASV>
</Options>
<Enable>
<FTP_enable>OFF</FTP_enable>
</Enable>
</FTP>
<Binary1>
<OperationMode>
<TCP_Server>ON</TCP_Server>
<TCP_Client>OFF</TCP_Client>
<UDP_Peer>OFF</UDP_Peer>
</OperationMode>
<Enable>
<Enable_BINARY_1>ON</Enable_BINARY_1>
</Enable>
<TcpServer1>
<LocalPort>49153</LocalPort>
<Client_HTTP_Port>80</Client_HTTP_Port>
<InputTrigger>
</InputTrigger>
<ApplicationMode1>
<Socket_device>ON</Socket_device>
<Compatible_50xxx>OFF</Compatible_50xxx>
<Box2Box_Slave>OFF</Box2Box_Slave>
<OPC_Device>OFF</OPC_Device>
</ApplicationMode1>
</TcpServer1>
<TcpClient1>
<ServerPort>49153</ServerPort>
<Server_HTTP_Port>80</Server_HTTP_Port>
<ServerPassword></ServerPassword>
<InactiveTimeout>30</InactiveTimeout>
<InputTrigger>
</InputTrigger>
<Interval></Interval>
<ApplicationMode2>
<Box2Box_Master>OFF</Box2Box_Master>
<ILOface>OFF</ILOface>
</ApplicationMode2>
</TcpClient1>
<UdpPeer1>
<LocalPort>45889</LocalPort>
<RemotePort>45889</RemotePort>
<Remote_IP_Addr></Remote_IP_Addr>
<InputTrigger>
</InputTrigger>
<ApplicationMode3>
</ApplicationMode3>
</UdpPeer1>
</Binary1>
<Binary2>
<OperationMode>
</OperationMode>
<Enable>
<Enable_BINARY_2>ON</Enable_BINARY_2>
</Enable>
<TcpServer2>
<LocalPort>49154</LocalPort>
<InputTrigger>
</InputTrigger>
<ApplicationMode1>
</ApplicationMode1>
</TcpServer2>
<TcpClient2>
<ServerPort>49154</ServerPort>
<InputTrigger>
</InputTrigger>
<ApplicationMode2>
</ApplicationMode2>
</TcpClient2>
<UdpPeer2>
<LocalPort>45890</LocalPort>
<RemotePort>45890</RemotePort>
<InputTrigger>
</InputTrigger>
<ApplicationMode3>
</ApplicationMode3>
</UdpPeer2>
</Binary2>
</BasicSettings>
<OutputMode>
<Output0>
<_HTTP>ON</_HTTP>
<_UDP_ASCII>OFF</_UDP_ASCII>
<_SNMP>OFF</_SNMP>
<Binary_1>OFF</Binary_1>
<Binary_2>OFF</Binary_2>
<_Logic>OFF</_Logic>
</Output0>
<Output1>
<_HTTP>ON</_HTTP>
<_SNMP>OFF</_SNMP>
</Output1>
<Output2>
<_HTTP>ON</_HTTP>
<_SNMP>OFF</_SNMP>
</Output2>
<Output3>
<_HTTP>ON</_HTTP>
<_SNMP>OFF</_SNMP>
</Output3>
<Output4>
<_HTTP>ON</_HTTP>
<_SNMP>OFF</_SNMP>
</Output4>
<Output5>
<_HTTP>ON</_HTTP>
<_SNMP>OFF</_SNMP>
</Output5>
<Output6>
<_HTTP>OFF</_HTTP>
<_SNMP>OFF</_SNMP>
<Binary_1>ON</Binary_1>
</Output6>
<Output7>
<_HTTP>OFF</_HTTP>
<_SNMP>OFF</_SNMP>
</Output7>
<Output8>
<_HTTP>OFF</_HTTP>
<_SNMP>OFF</_SNMP>
</Output8>
<Output9>
<_HTTP>OFF</_HTTP>
<_SNMP>OFF</_SNMP>
</Output9>
<Output10>
<_HTTP>OFF</_HTTP>
<_SNMP>OFF</_SNMP>
</Output10>
<Output11>
<_HTTP>OFF</_HTTP>
<_SNMP>OFF</_SNMP>
</Output11>
<Safety_Timeout></Safety_Timeout>
<Enable>
<Load_Control_enable>OFF</Load_Control_enable>
</Enable>
</OutputMode>
<Alarm>
<Alarm1>
<InputTrigger>
<Input_0><enable>OFF</enable><state>OFF</state></Input_0>
<Input_1><enable>OFF</enable><state>OFF</state></Input_1>
<Input_2><enable>OFF</enable><state>OFF</state></Input_2>
<Input_3><enable>OFF</enable><state>OFF</state></Input_3>
<Input_4><enable>OFF</enable><state>OFF</state></Input_4>
<Input_5><enable>OFF</enable><state>OFF</state></Input_5>
<Input_6><enable>OFF</enable><state>OFF</state></Input_6>
<Input_7><enable>OFF</enable><state>OFF</state></Input_7>
<Input_8><enable>OFF</enable><state>OFF</state></Input_8>
<Input_9><enable>OFF</enable><state>OFF</state></Input_9>
<Input_10><enable>OFF</enable><state>OFF</state></Input_10>
<Input_11><enable>OFF</enable><state>OFF</state></Input_11>
</InputTrigger>
<OutputTrigger>
<Output_0><enable>OFF</enable><state>OFF</state></Output_0>
<Output_1><enable>OFF</enable><state>OFF</state></Output_1>
<Output_2><enable>OFF</enable><state>OFF</state></Output_2>
<Output_3><enable>OFF</enable><state>OFF</state></Output_3>
<Output_4><enable>OFF</enable><state>OFF</state></Output_4>
<Output_5><enable>OFF</enable><state>OFF</state></Output_5>
<Output_6><enable>OFF</enable><state>OFF</state></Output_6>
<Output_7><enable>OFF</enable><state>OFF</state></Output_7>
<Output_8><enable>OFF</enable><state>OFF</state></Output_8>
<Output_9><enable>OFF</enable><state>OFF</state></Output_9>
<Output_10><enable>OFF</enable><state>OFF</state></Output_10>
<Output_11><enable>OFF</enable><state>OFF</state></Output_11>
</OutputTrigger>
<SystemTrigger>
<Load_Control>OFF</Load_Control>
<Interval_Timer>OFF</Interval_Timer>
</SystemTrigger>
<MaxCounterValue></MaxCounterValue>
<AlarmEnable>
<SNMP_Trap_enable>OFF</SNMP_Trap_enable>
<UDP_Client_enable>OFF</UDP_Client_enable>
<Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections>
<TCP_Client_enable>OFF</TCP_Client_enable>
<Syslog_Messages_enable>OFF</Syslog_Messages_enable>
<FTP_Client_enable>OFF</FTP_Client_enable>
</AlarmEnable>
<Mail>
<E-Mail-Addr></E-Mail-Addr>
<Subject></Subject>
<Mailtext></Mailtext>
<Alarm_clear_subject></Alarm_clear_subject>
<Alarm_clear_text></Alarm_clear_text>
</Mail>
<SNMP>
<TrapText></TrapText>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
<SyslogText></SyslogText>
</Syslog>
<FTP>
<FtpLocalDataPort>AUTO</FtpLocalDataPort>
<FileName></FileName>
<FtpAlarmText></FtpAlarmText>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm1>
<Alarm2>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm2>
<Alarm3>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm3>
<Alarm4>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm4>
<Alarm5>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm5>
<Alarm6>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm6>
<Alarm7>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm7>
<Alarm8>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm8>
<Alarm9>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm9>
<Alarm10>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm10>
<Alarm11>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm11>
<Alarm12>
<InputTrigger>
</InputTrigger>
<OutputTrigger>
</OutputTrigger>
<SystemTrigger>
</SystemTrigger>
<AlarmEnable>
</AlarmEnable>
<Mail>
<Subject></Subject>
</Mail>
<SNMP>
</SNMP>
<UDP>
<IP_Addr></IP_Addr>
<Port></Port>
<UdpText></UdpText>
</UDP>
<TCP>
<IP_Addr></IP_Addr>
<Port></Port>
<TcpText></TcpText>
</TCP>
<Syslog>
<IP_Addr></IP_Addr>
<Port>514</Port>
</Syslog>
<FTP>
<Options>
<STORE>OFF</STORE>
<APPEND>ON</APPEND>
</Options>
</FTP>
</Alarm12>
</Alarm>
</Device>
<Ports>
<Inputs>
<Input0>
<Name>Input 0</Name>
<Text>Description Input 0</Text>
<Filter></Filter>
<InputMode>
<Short_Pulse_detection_enable>OFF</Short_Pulse_detection_enable>
<Change_detection_enable>OFF</Change_detection_enable>
<Clear_counter_on_read>OFF</Clear_counter_on_read>
<Bidirectional_counter_enable>OFF</Bidirectional_counter_enable>
</InputMode>
<Counter_Mode>
<PulsPolarity>
<negative>OFF</negative>
<positive>ON</positive>
</PulsPolarity>
<InactiveTimeout>1</InactiveTimeout>
</Counter_Mode>
</Input0>
<Input1>
<Name>Input 1</Name>
<Text>Description Input 1</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input1>
<Input2>
<Name>Input 2</Name>
<Text>Description Input 2</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
<positive>OFF</positive>
</PulsPolarity>
</Counter_Mode>
</Input2>
<Input3>
<Name>Input 3</Name>
<Text>Description Input 3</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input3>
<Input4>
<Name>Input 4</Name>
<Text>Description Input 4</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input4>
<Input5>
<Name>Input 5</Name>
<Text>Description Input 5</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input5>
<Input6>
<Name>Input 6</Name>
<Text>Description Input 6</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input6>
<Input7>
<Name>Input 7</Name>
<Text>Description Input 7</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input7>
<Input8>
<Name>Input 8</Name>
<Text>Description Input 8</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input8>
<Input9>
<Name>Input 9</Name>
<Text>Description Input 9</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input9>
<Input10>
<Name>Input 10</Name>
<Text>Description Input 10</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input10>
<Input11>
<Name>Input 11</Name>
<Text>Description Input 11</Text>
<Filter></Filter>
<InputMode>
</InputMode>
<Counter_Mode>
<PulsPolarity>
</PulsPolarity>
</Counter_Mode>
</Input11>
</Inputs>
<Outputs>
<Output0>
<Name>Output 0</Name>
<Text>Description Output 0</Text>
<GroupMode>
<_0_1_2_3_separated>ON</_0_1_2_3_separated>
<_0--1_2--3_parallel>OFF</_0--1_2--3_parallel>
<_0--1--2--3_parallel>OFF</_0--1--2--3_parallel>
</GroupMode>
<SafetyState>
<Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
<Output_Inverter>OFF</Output_Inverter>
</OutputInverter>
</Logic>
<Puls>
<Duration>5000</Duration>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output0>
<Output1>
<Name>Output 1</Name>
<Text>Description Output 1</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<Duration>2000</Duration>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output1>
<Output2>
<Name>Output 2</Name>
<Text>Description Output 2</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<Duration>1000</Duration>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output2>
<Output3>
<Name>Output 3</Name>
<Text>Description Output 3</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output3>
<Output4>
<Name>Output 4</Name>
<Text>Description Output 4</Text>
<GroupMode>
<_4_5_6_7_separated>ON</_4_5_6_7_separated>
<_4--5_6--7_parallel>OFF</_4--5_6--7_parallel>
<_4--5--6--7_parallel>OFF</_4--5--6--7_parallel>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<Duration></Duration>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output4>
<Output5>
<Name>Output 5</Name>
<Text>Description Output 5</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output5>
<Output6>
<Name>Output 6</Name>
<Text>Description Output 6</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output6>
<Output7>
<Name>Output 7</Name>
<Text>Description Output 7</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output7>
<Output8>
<Name>Output 8</Name>
<Text>Description Output 8</Text>
<GroupMode>
<_8_9_10_11_separated>ON</_8_9_10_11_separated>
<_8--9_10--11_parallel>OFF</_8--9_10--11_parallel>
<_8--9--10--11_parallel>OFF</_8--9--10--11_parallel>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output8>
<Output9>
<Name>Output 9</Name>
<Text>Description Output 9</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output9>
<Output10>
<Name>Output 10</Name>
<Text>Description Output 10</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output10>
<Output11>
<Name>Output 11</Name>
<Text>Description Output 11</Text>
<GroupMode>
</GroupMode>
<SafetyState>
</SafetyState>
<Logic>
<InputMask>
</InputMask>
<InputInverter>
</InputInverter>
<LogicFunc>
<AND>ON</AND>
<OR>OFF</OR>
</LogicFunc>
<OutputInverter>
</OutputInverter>
</Logic>
<Puls>
<PulsPolarity>
</PulsPolarity>
</Puls>
</Output11>
</Outputs>
</Ports>
<Manufacturer>
<Name>Wiesemann & Theis GmbH</Name>
<Address>Porschstr. 12<br>
42279 Wuppertal<br>
Germany</Address>
<Support_Hotline>+49-(0)202-2680-0</Support_Hotline>
<Internet>www.wut.de</Internet>
<DeviceTyp>Web-IO Digital 12xIn, 12xOut</DeviceTyp>
<DeviceNo>#57630 TB 900571</DeviceNo>
<Logo>logo.gif</Logo>
</Manufacturer>
</Config>
</io-Digital12x12.3>
Hardware Configuration
For this example, you configure the in and out ports as required for the GPIO system, by following their own specifications.
The Web-IO physical device can be configured via a browser pointed to the box’ IP address.
To access the configuration menus
  • Config > Login > Administrator login
    from the Start page.
Note: Configuration changes are only saved after clicking the Logout button.
Mosart IAT/SAT
  • For testing from Viz Mosart, the new configuration is either directly loaded, or inspected and used for setting the inport 0 manually.
    Inspection and comparison may be necessary should the load fail. If necessary reset the box to factory settings before using the configuration below.
  • Under the inport nodes in the menu tree
    • Set the port minimum pulse filter to 100ms
    • Set the input type to positive pulse (three separate settings).
  • If you use port 0 it is easier to test Viz Mosart, as this port is hardwired to the Reload Rundown function.
Preparation of Test Circuit
  • This requires two pieces of wire, ~20cm, stripped (and preferably tinned) at the end.
  • To set up the box for generating an input test pulse, interconnect the terminal strip ground connector for power supply ground (the outermost VCC connector) with the outermost GND connector, across the box. This establishes a common ground between power supply side and the input logic circuits.
  • Note:
    • It is not possible to simply take the output of one output port and feed it directly back to the input side, as the outputs are intended to drive relay circuits (these are also known as current drivers, they operate at a very low voltage)
    • The 12 in 12 out version requires an external relay.
    • The inputs requires 8V referred to GND to detect a pulse.
Testing GPI 0
  • To generate the input pulse, connect a piece of wire from the other VCC connector and briefly touch the connector for Inport 0 (the pulse must be >100ms).
  • A green light beside the connector will briefly light up if successfully triggered. Given that AV Automation has GPIO enabled and is also enabled for Input 0, any loaded rundown will reload, clearly visible on the Mosart GUI.
  • Configure GPIO with the file containing the working configuration.
