To Add a Template
You can add a new template to the currently selected template set.
  1. Select File > New template.
  2. Enter the new Template Operations#Template Properties.
To Edit a Template
  • Select Edit > Template properties.
Note: Template properties can also be accessed by right-clicking in the device's Function area. See the table Template Operations#Template Properties.
To Remove a Template
  1. Select File > Remove template.
  2. Confirm delete in the dialog box.
To Flatten a Template
You can push a new template, created in another template set (that was created using the hierarchical approach), back to the originating template set.
  1. Select Template > Flatten.
    A dialog box displays which template set the selected template will be flattened to.
  2. Click Yes.
Note: For a description of Hierarchical templates, please refer to Working with Template Sets.
To Copy a Template
You can copy a template from one template set to another template set.
  1. Open the template you want to copy.
  2. Select Edit > Copy template.
  3. Switch to the other template set, and then apply Edit > Paste template.
  4. Select Edit > Paste to all to copy the template to all template sets.
