These config files are initially located in the Viz Mosart Server installation folder in a sub folder, Configuration Files.
For operations, you copy the file to "%ProgramData%/
- Ardour Configuration File
- Calrec TCP/IP Configuration File
- Lawo Ember+ Configuration File
- LAWO PowerCore Configuration File
- MidiMixer Configuration File
- Stagetec Configuration File
- Stagetec Ember+ Configuration File
- Studer 3000 TCP/IP Configuration File
- Studer Vista Configuration File
- Tascam Sonicview 16 Ember+
- General Audio Mixer Configuration File
See also Audio.
This driver first reads the general configuration file named AudioMixerConfiguration.xml.
Then it reads the specific Ardour configuration file named AudioMixerArdour.xml.
Please see these files for the available settings and their documentation.
Then it reads the specific Calrec TCP/IP configuration file named AudioMixerCalrec.xml.
Info: AckTime and ConWait
The sample AudioMixerCalrec.xml file includes two settings AckTime and ConWait with their respective default values.
If you need to change the value of these defaults, you must at the same time, change the naming to all lowercase (acktime and conwait) for the change to be accepted and applied.
Then it reads the specific Lawo Ember+ configuration file named AudioMixerLawoEmberPlus.xml.
This driver reads AudioMixerEmberPlus.xml.
Please see that file for the available settings and their documentation.
Then it reads the specific MidiMixer configuration file named AudioMixerMidiMixer.xml.
Then it reads the specific Stagetec configuration file named AudioMixerStagetecDiamondRas.xml.
This driver reads the Ember+ configuration file named AudioMixerEmberPlus.xml.
Then it reads the specific Studer 3000 TCP/IP configuration file named StuderOnAirEmberConfiguration.xml.
Then it reads the specific Studer Vista configuration file named StuderVistaEmberConfiguration.xml.
Audio mixers not specifically mentioned above, all use the general configuration file named AudioMixerConfiguration.xml.
Info: In the default version of this file, there are some settings specific to the Lawo RMNOPL audio mixer driver.
