This section lists a selection of device properties:
- Working with Device Functions
- Testing a Template
- Video Switcher Crosspoint
- Video Switcher Transition
- Video Switcher Register/Timeline Recall
- Macro Recall
- Video Switcher Auxiliary Bus Delegation
- Keyfill: Video Switcher Key Bus Delegation
- Video Server
- Graphics
- Video Wall Register Recall
- Audio Player
- Virtual Set
- Robotic Camera Control
- GPO
- Light Control
- Router Control
- Audio Faders
- Generic REST commands
Right-click inside the device function area to open a menu containing the following options:
Enable: These commands are described in more detail below.
Template properties: Opens the current template's properties page, see Template Properties in section Working with Templates.
Clear devices: Removes all devices from the device function menu, after confirming in a pop-up message window.
Apply device settings to all sets: Applies all the device settings to all templates of same type and variant throughout all template sets.
Mark as intentionally empty: This option is available for empty templates only and shows up when the Use ‘Mark template as empty’ feature is enabled in Settings Editor MOS-General. See Empty Templates for more details.
To enable device functions
Right-click in the device's Function area (black row).
Select the device to configure from the Enable menu.
This opens the Edit box for the selected device.
Info: Depending on the protocol chosen, the caption EMEM Recall may alternatively be:
Emem Recall
Dmem Recall
Snapshot Recall
Memory Recall
To modify device functions
Select Device properties. See the topics below for listings of properties for each device.
Info: Depending on the Protocol chosen, the caption Macro Recall may alternatively be:
Custom Control
To remove device functions
Right click in the Device function area
De-select it from the Enable menu.
Linking Device Properties and Newsroom Tags
To make a property editable from the NRCS
Right-click over Property and select Add newsroom tag.
The property is then reassigned to the value supplied from the newsroom system.In the grid-based device editors — Robotic Camera Control, Router Control and GPO — right-click over a cell instead, and select Add newsroom tag to make that column's attribute editable from the NRCS.
If several device properties are given to a newsroom tag with the same name in a template, all devices use the value given in the NRCS.
See also: Newsroom Tags.
Testing a Template
You can test the behavior of your template by simulating a Preview (cue) followed by a Take.
To test a template
Press the Take button to the right of the template heading.
This cues the template in Preview, and then five seconds later takes it to Program with the selected transition.
The video switcher crosspoint enables switching on the video switcher. The A or B bus assignment of the mixer effect (PP/MEx) is automatically handled by the automation.
Guidelines for Video Switcher Crosspoint Configuration
Item | Description |
Mix Effect | Selects which Mix Effect (ME) bank on your vision mixer that you are currently handling. Info: For vMix, PP maps to the main vMix output. ME1 maps to the first Mix input, ME2 to the second, and so on. Info: For ATEM, both PP and ME1 map to the same physical ME1 on the switcher. The difference is only relevant for keyfills. See Guidelines for Keyfill Configuration below. |
Crosspoint | Crosspoint on the video switcher. Default value: none
Info: Newsroom tag available. |
Audio link | Default value: none |
Crosspoint PP | If another Mix Effect (ME) than PP is selected, then you can select a crosspoint for program by writing the crosspoint name in the field. |
Set ME in PP | If another Mix Effect (ME) than PP is selected, check this box to make that ME the crosspoint for PP. (Checking this box disables XPOINT PP). |
Cross Point Hold | Keeps the crosspoint on the selected Mix Effect. |
Mix Delay | Offset, in frames, of when to perform the transition. |
Mix Delay Out | Delay, in frames, of when to perform the next transition. |
Transition Only | Only delay the switcher transition (sub items will perform). |
DSK Off | Turns off the Downstream Keyer (DSK) on the video switcher when the template is active in program. |
DSK 2 On, ..., | Downstream Keyer (DSK) 2-8 on. Turns on the DSK 2-8 (PP key 2-8) on the video switcher when the template is active in program. |
Off delay | Delay in frames to set the DSK 2-8 off. |
The transition device is only available when video Switcher crosspoint is enabled.
To define video switcher transitions
This procedure is based on the example in the screenshot.
Click on MIX/WIPE/EFFECT to cycle through these three transition types.
Click directly on the selected value (in the screenshot above, this is either 0 or 1).
Enter
The default duration (in frames) for the Mix/Wipe transition, or
The effect number for the effect transition.
The transition is performed with the auto-transition functionality in the video switcher.
Usage and Tips
To add a cut: Use a MIX transition with
0frames duration.To add a mix delay:
Right-click on the device (MIX/WIPE/EFFECT), select the number (below Disable), and enter another number (in frames).
Adding a mix delay delays the start of the transition, compared to other device commands, when the template goes On Air.To disable a transition:
Right-click over the device and select Disable.
Video Switcher Register/Timeline Recall (EMEM Recall/Emem Recall/Dmem Recall/Snapshot Recall/Memory Recall) will recall a register and/or timeline in the video switcher.
To open the video switcher Register/Timeline recall
Open Template Editor.
Right-click over ememnr_pr
Select Enable > EMEM Recall
Enter or select required values
Info: If a Register recall is paired with the video switcher key bus delegation and/or auxiliary bus delegation, the key/aux bus delegation should be disabled in the Video Switcher Register to prevent a conflict between the stored delegation and the Viz Mosart-assigned delegation.
Guidelines for Video Switcher Register/Timeline Recall Configuration
NAME | Name of Register/Timeline. |
DESCRIPTION | Description of Register/Timeline. |
MIXEFFECT | Select the MIXEFFECT (ME) from where the Register/Timeline should be recalled. Drop-down menu values are PP (Program), ME1, ME2, ME3, ME4, and Master. Default value: Master. To dynamically choose ME1 or ME2, values M_RIP and M_OTH are available. Info: Newsroom tag available |
EMEMNR PREVIEW | Register/Timeline on the video switcher that will be recalled when the template is cued in Preview. |
EMEMNR PROGRAM | Register/Timeline on the video switcher that will be recalled when the template is taken to Program. |
LOAD TIME | Delay time (in frames) between when the mixer register is recalled (in Program or Preview) and when all other template instructions are executed. |
OPEN VS FADER | When selected, Viz Mosart opens the fader specified in Audio effect server, defined in the Audio tab of Device Properties in AV Automation. |
Macro Recall
Macro Recall is available with the following vision mixer protocols (selected in the configuration menu AV Automation Devices Vision Mixer):
Ross Acuity
Ross Carbonite
GV CPL
GV KAHUNA (Kahuna/Kula)
SONY SERIAL TALLY
TriCaster
ATEM
vMix
To open a Macro Recall
Navigate to Enable > Macro Recall
Enter or select required values.
Guidelines for Macro Recall Configuration
Item | General description | Drop-down | Text field |
Recall preview | Action to be taken when entering preview mode. | See below | See below |
Recall program | Action to be taken when entering program mode. | See below | See below |
On-air protection | Prevents macros in other templates from changing the on-air look while this template is on air. | See below | N/A |
Drop-down Menu Alternatives
Drop-down option | Description |
None | No action. |
Recall | Macro is prepared (or cued). |
Take | Macro is taken. |
Recall and Take | Macro is prepared and taken. |
Load project | Project is loaded. Supported only by Kahuna/Kula and vMix. Warning: Load Project could affect the performance of the switcher. Use with caution during a running show. |
Text field format depends on the mixer chosen
Mixer | Text field | Remark | ||||||||||
ATEM | Name or index (starting from 1) of the macro. | Load project not supported. | ||||||||||
Acuity | One bank character and two macro characters. | Recall (and Recall and take) only. Note that Device is named Custom Control instead of Macro Recall. | ||||||||||
Carbonite | One bank character and two macro characters. | Recall (and Recall and take) only. Note that Device is named Custom Control instead of Macro Recall. | ||||||||||
GV CPL | Macro number (integer) in the range 1-999. | Recall (and Recall and take) only. | ||||||||||
Kahuna/Kula | The meaning and format of the text fields depend on the selected drop-down option:
SONY SERIAL TALLY | Macro number (integer) in the range 1- 250. | Recall (and Recall and take) only. | ||||||||||
TriCaster | Plays a macro having the name provided or the unique ID (GUID). | Take only | ||||||||||
vMix | Name of vMix script to execute. Load project: Path to preset file to load. | Load project: Absolute or relative path from the vMix installation folder (the | ||||||||||
Off | No protection. Macros always run as configured. This is the default. |
All templates | While this template is on air, a macro in any other template is not fired when that template is cued. |
Same template type | While this template is on air, a macro is not fired when a template of the same type, for example another DVE, is cued and also has on-air protection enabled. Templates of other types are not affected. |
Auxiliary bus delegation enables routing of internal video switcher signals to the auxiliary outputs of your video switcher.
Info: TriCaster video switcher uses NDI outputs, not auxiliaries. On the template, the Auxiliaries device is instead displayed as NDI Router Output.
Type or select relevant values.
Guidelines for Auxiliary Bus Delegation Configuration
BUS | Selects the auxiliary to assign a new source. Info: For vMix, bus 1 corresponds to vMix Output 2, bus 2 to Output 3, and so on. Info: Newsroom tag available. |
XPOINT | Crosspoint on the video switcher. Info: Newsroom tag available. |
AUDIOLINK | Assigns a link group to this delegation. Please refer to Audio and Video Setup for the use of this feature. |
SET DELAY | Set the delay in frames of the key delegation when taking the template to Program. If the field is left blank, the key is set in Preview |
TRANS DUR | If the vision mixer has the ability to mix on the AUX channels, this is where the mix rate (in frames) is set, 0 is a cut |
Info: AUX transitions are only supported when using the GV CPL protocol.
Due to a limitation in the Grass Valley device, only one AUX bus can be transitioned at a time. This restriction comes from the switcher hardware, not from Viz Mosart.
Router source memory
Viz Mosart uses an internal AUX memory logic, where Mosart always stores the last crosspoint set on a specific AUX. If this AUXx is used as a source (rather than a destination) Mosart uses the source stored in memory. In the Template Editor, checking the Source drop-down list for a switcher crosspoint reveals at the bottom a list (that is automatically added appended) of AUXx sources. These refer to the internally stored AUX sources.
A similar logic applies to router crosspoints. However, the AUXx sources displayed in the switcher crosspoint Source drop-down, are not automatically shown in the router sources drop-down. Add them manually to the Router Source table in AVconfig, for the AUX memory logic to operate.
Info:
The source named shall not contain special characters (for example dash - or underscore _).
Naming in the form AUX 9 or AUX9 (without space) is recommended.
Using names like AUX-9 or AUX_9 will cause Mosart to ignore the memory logic and instead use the newly provided source identity.
Configuring an NDI Router (Viz Vectar Plus or Tricaster VMC)
Info: For NDI output crosspoints, you must refer to actual crosspoint names recognized by VMC1 (and not any user-friendly names that would be mapped to the physical inputs).
These default naming on the NDI router side is typically:
- INPUTn
- DDRn
- BFRn
- MIX n.
The same naming must be used on the Viz Mosart side.
In AV Automation > Devices > A/V Setup > Video Config > Mixer name column, you must provide the hardcoded name associated with the user-friendly name of the crosspoint.
This name is found on the switcher side.
In the example below, the value of the literal crosspoint name is the router output found in the switcher's Macro Configuration > Macro Editor menu and added to AV Automation:
There is a new setting UseOutputCrosspointNames in the IP-protocol config VizrtIpSystemsVideoSwitcherConfig.xml set by default to expect the crosspoint name, instead of the Viz Mosart standard of using physical input naming.
Video switcher key bus delegation enables routing of internal video switcher signals to the keyers on the different mixer effects of the switcher.
Info: For TriCaster video switcher supporting M/E effects with 4 layers, the device is named Key/Layer.
To enable Keyfill by bus delegation
Navigate to Enable > Keyfill > [Keyfill index]
To enable Keyfill by bus delegation for M/E effects with 4 layers
Devices like Vizrt’s TriCaster family TriCaster Plus or VMC1 let you configure M/Es with effects supporting up to four primary sources/input layers (along with Key layers), called A, B, C and D buses.
Viz Mosart can control these buses from a template or keyboard shortcut when TriCaster is used as a vision mixer.
Navigate to Enable > Key/Layer > [KeyLayer index]
The Key/Layer device on a template can be used for VMC1 vision mixer to either set the crosspoint for a Key bus or to set the crosspoint for A, B, C and D buses of a M/E effect with 4 layers.Right-click > Device properties.
Select from the BUS drop-down menu:If the device is used for setting the crosspoint for a key bus, set the BUS drop-down menu to a number between 1 and 8 on the Key/Layer device properties.
If the device is used for setting the crosspoint for a layer of a M/E effect with 4 layers, then choose one of the letters A, B, C and D from the BUS drop-down menu.
BUS | Selects the key bus on the selected ME. If the video switcher supports M/Es with four layers (for example Vizrt’s TriCaster family), four more buses are available corresponding to each layer, A, B, C and D: If the switcher is Ross Acuity, the number of buses is 16 where the first 8 are used for the selected mixer region keyers and the next 8 buses target the second channel of the keyers. Info: Newsroom tag available. |
XPOINT | Crosspoint on the video switcher. Default value: none Info: Newsroom tag available. |
AUDIOLINK | Assigns a link group to this delegation. Please refer to Audio and Video Setup (previously Linking video and audio sources) for the use of this feature. |
MIXEFFECT | Select the ME where the key crosspoint should be set. Info: Newsroom tag available. Info: For ATEM, both PP and ME1 map to the same physical ME1 on the switcher. |
KEY SET DELAY | Set the delay in frames of the key delegation when taking the template to a program. If the field is left blank the key is set in preview. |
KEY ENABLE | Key enable drop-down menu. Info: Newsroom tag available. |
Video Server
Guidelines for Video Server Configuration
Setting | Description |
SERVERCHANNEL | The Mosart video port / port group where the clip is to be played out /recorded. For recording the corresponding video port has to be part of the “Rec” port group. Port groups are created as part of the video server configuration in menu AV Automation > Devices > Preferences. In addition, the non-empty groups (groups with at least one port) are available. |
CLIP HIRESPATH | The (default) clip ID or name. Info: Newsroom tag available, meaning that a value from the NRCS will override the value specified here. |
CLIP DESCRIPT | You can enter a Clip description, however a clip description from the NRCS or video server overrides this value. Info: Newsroom tag available. |
TRIGGER START | Enables the Trigger start function from control command TRIGGER_START, a shortcut or continue point could be set to PLAY the Clip. |
RECUE CLIP | In an A/B roll situation, when several Adlibs are played back-to-back, this setting determines how a clip will be restarted after it has been paused. |
LOOP | Sets the server port to loop the clip. Beware! Not all video servers can loop. |
CUE ONLY | (Intended for Accessory and Package templates) Cues only the clip when the template is in Preview. The template will not start playing the clip when the template is taken. |
Graphics
The Graphics device enables recall of graphic elements.
Graphic elements are cued (loaded) in Preview and played (started) when taken to Program.
Guidelines for Graphics Configuration
Engine | Selects the engine to operate on when using this template, based on your configuration. |
Content Source |
Send Continue on DVE FORWARD | If selected, a continue command is sent together with a DVE Forward command. |
Use VizContentPilot | Enable to run this element through a Viz Pilot client. This allows for OnLiveUpdate events in Viz Pilot data elements. |
Scene Name | The default scene name is used, if not overridden by the NRCS. Info: Newsroom tag available. |
Scene Text | The default scene text will be used, if not overridden by the NRCS. Info: Newsroom tag available. |
Is database Index | |
Use take Out Command | If selected, a take-out command is sent when the template status changes from On Air to Off Air. |
Take Out Delay | Delay of sending takeout command after template status changes from On Air to Off Air. |
Translate Cue for Transition Logic elements | If active, this setting overrides the global setting with same name set in AV Automation > Devices > Properties > Graphics > General > [VIZRT] > Miscellaneous. This setting only applies to transition logic for Vizrt full screen graphics. The Media Sequencer ignores standard cue command for these items.
NAME | Internal name of the shot. |
RECALL PREVIE | For WATCHOUT, see notes below. For the other brands, this is the number of the recall to be taken when the template is cued in Preview. |
EMEMNR | For WATCHOUT, see notes below. For the other brands, this is the number of the preset to take when the template is taken in Program. |
Info: Notes for WATCHOUT
The fields RECALL PREVIE and EMEMNR should contain the command or sequence of commands to be sent when the template comes in Preview or Program, respectively.
The general format is:
[load "show"] [resetrun "timeline"]Both
loadandrunare optional, however at least one of them must be present. The show and timeline parameters may not contain double quotes.The
resetvalue is optional. For more information see the connection string property ResetAnyway, described in the section Video Wall Connection Strings.In most cases, RECALL PREVIE contains
load "show", and EMEMNR containsrun "timeline".Commands supported: load, run, reset, halt, kill, gotoControlCue.
Audio Player
This description applies to the Viz Mosart Audio Player. For the TriCaster Audio Player and third party audio players, see under Audio Player in section Audio.
LEVEL: This value does not affect the level! Instead, a value > -90 (the value must be an integer) starts playout, whereas a value <= -90 stops the playout.
AUDIO FILE: Enter the audio file name here to play a fixed audio clip.
Alternatively, enter a newsroom tag to get audio file name from the NRCS.
Info: All playable audio files must reside in the directory specified in the Mosart Audio Player.
For setup and configuration, see section Audio Player in AV Automation Devices (Audio).
OUTPUT: Choose the output on the Audio Player to be used. If no value is given, Output 1 is used.
This value will be overwritten if any (newsroom tag) value comes from the NRCS.
Info: Outputs are displayed on the Mosart Audio Player UI. See section Audio Player in AV Automation Devices (Audio).
LOOP: When selected, at end the audio file always replays.
Info: Newsroom tags available for the three fields, LEVEL, AUDIO FILE and OUTPUT.
Virtual Set
Viz Virtual Studio :
Camera : Preset router index number to recall in Viz Tracking Hub currently loaded studio configuration
Studio : Studio configuration name to recall in Viz Tracking Hub
Info: For Vizrt's virtual set manager, Viz Arc, please refer to section Viz Arc support within a Mosart show.
The camera control device allows for recalling camera shots (and pre-programmed moves) when the template is cued in preview or aired in program. The device editor supports salvo recalls of shots by adding multiple lines for each shot recall.
The Standard Robotic Camera Control Properties are described below, as well as exceptions for specific camera types.
Guidelines for Standard Robotic Camera Control Configuration
Shot Name | Not used. |
Camera number |
Preview | The exact meaning and format of the Preview fields depend on the type of camera robotics. (See the sections below.) These following three fields govern what happens when the template is taken in preview. |
Page Preview | This field (together with Preset Preview below) determines the shot/move. |
Preset Preview | This field (together with Page Preview above) determines the shot/move. |
Time preview | This field (together with Preset Preview and Page Preview above) determines the duration of a move. |
Delay preview | Not used. |
Program | The exact meaning and format of the Program fields depend on the type of camera robotics. (See the sections below). These following three fields govern what happens when the template is taken to air. |
Page program | This field (together with Preset program below) together determine the shot/move. |
Preset program | This field (together with Page program above) together determine the shot/move. |
Fade time Program | This field determines the duration of a move. |
Delay program | Delay of move in Program (frames). Info: Only available for Vinten robotics systems |
Protect onair source | Protected video switcher cross-point. If the video switcher cross-point is On Air, the shot/move recall will be ignored. |
Info: Newsroom tags are available on every column of the Robotic Camera Control device — Shot Name, Camera number, the Page, Preset, Time and Delay columns for both Preview and Program, Fade time Program, and Protect onair source. Right-click a cell and select Add newsroom tag; see Linking Device Properties and Newsroom Tags. These are free-text fields in the NRCS.
Cambotics Properties
Camera Number: Set camera number to
1.Page Preview/ Page program: Robotic camera number.
Preset Preview/ Preset program: Shot number.
Time preview/ Fade time Program: [Optional] Duration for move in deciseconds (10 deciseconds = 1 second).
Note: All parameters not defined specifically, must be set to -1.
Camerobot Properties
Page Preview/ Page program: Name of shot’s matrix in preview/program.
Preset Preview/ Preset program: Shot’s cell number in the selected matrix - the shot is adjustable from NRCS and GUI.
Time preview/ Fade time Program: Duration of the move, in frames. A value of 0 sends a cut (MATRIX_CUT_MPOS) to the position; any other value sends a move (MATRIX_MOVE_MPOS). Adjustable from NRCS and GUI.
Info: By default the value only selects cut or move, and Camerobot uses its own programmed move speed. When SendDuration is enabled in RoboticCameraConfiguration.xml (see Robotic Camera Configuration Files), the value is also converted to seconds using the configured video frame rate and sent as a <duration> element, so the move lasts exactly that long. For example, 50 frames at 25 fps sends <duration>2.00</duration>. Combined with a newsroom tag on this column, the duration can be set per story from the NRCS.
Cinneo System Properties
Page Preview/ Page program: Name of the camera to recall.
Preset Preview/ Preset program: Name of shot to recall - adjustable from NRCS/GUI.
Time preview/ Fade time Program: Desired moving time (seconds).
Fx-Motion Properties
Page Preview/ Page program: Identifies the camera to recall (identical to Camera Number > 0), optionally followed by :category for temporary overriding any NRCS or GUI settings.
Preset Preview/ Preset program: Name of shot or move to recall.
Time preview/ Fade time Program: =0 cut, <0 ~ default time to shot, >0 ~ wanted time (frames).
NDI PTZ Properties
Camera Number: A number as configured in the Cameras field for a robotic camera controller (see section Camera Robotics). This is used by Mosart to filter the shots for execution by a camera robotic controller.
If value -1 is set, the shots will be executed for all controllers are not in stand-by, as configured in AV Automation Device Properties.Page Preview/Page program: A number as configured in the Cameras field for a robotic camera controller (see section Camera Robotics). This identifies the exact camera for which the shot will be executed.
As long as the Camera number is greater or equal than 0, a number within the range of cameras supported for that controller should be set for either Page Preview or Page Program.Preset Preview/Preset program: Name of shot or move to recall.
Delay preview: Not supported.
Delay program: Delay of move in Program (in frames).
Panasonic Properties
Camera Number: Identifies the Controller that the command is linked to.
Page Preview/ Page program: Identifies the Camera Number to be controlled in Preview/Program.
Preset Preview/ Preset program: Identifies the Preset Stored Move in Preview/Program.
Time preview/ Fade time Program: Sets the Timed Delay in Preview/Program. Has no effect for Panasonic TCP.
Technodolly Properties
Page Preview/ Page program: Identifies the camera, identical to Camera Number when >0.
Preset Preview/ Preset program: Name of the move to recall.
Time preview/ Fade time Program: =0 ~ go to start of move, ≠0 ~ move.
Shotoku TR_T Properties
Page Preview/ Page program: Page of shot to recall.
Telemetrics Properties
Page Preview/ Page program: Preset page number to recall.
Preset Preview/ Preset program: Preset number to recall.
Time preview/ Fade time Program: =0 cut, <0 ~ default time to shot, >0 ~ wanted time (seconds).
Vinten 200 Properties
Page Preview/ Page program: Name of the show to recall.
Time preview: <0 ~ go to end position of a move, ≥0 ~ go to start position of a move. For shots: =0 ~ cut to shot, ≠0 ~ move to shot (frames).
Fade time Program: For moves, move forward or backward according to Time preview. For shots, =0 ~ cut to shot, ≠0 ~ move to shot (frames).
Electric Friends Robotic Camera
For Preview use:
Page Preview: Show and Robotic camera name separated with a colon (e.g.: ShowName:Cam 1).
Preset Preview [Optional]: Shot name. Shot attributes: prepare, prepareplay and loop. Separated with a colon (for example, prepare:ShotName and prepareplay:ShotName).
Time Preview [Optional]: Duration for move in frames. The time is rounded up to the nearest second.
For Program use:
Page Program: Show and Robotic camera name separated with a colon (e.g.: ShowName:Cam 1).
Preset Program [Optional]: Shot name. Shot attributes: prepare, prepareplay and loop. Separated with colon (for example, prepare:ShotName and prepareplay:ShotName).
Fade time Program [Optional]: Duration for move in frames. The time is rounded up to the nearest second.
Example: Setting up a Template with Camera Control Device Enabled
This example demonstrates configuring a template for a Camera Control device using an NDI PTZ camera. Whilst the steps are specific to NDI PTZ cameras, a similar setup applies to other camera types.
Depending on the camera model and its supported features, slight adjustments in the configuration may be required.
We assume the following setup is configured as described in section Camera Robotics (under Device Properties):
POD2-PTZ3 and VIZRTV-MTTE02 are connected.
POD2-PTZ4 is currently disconnected.
On a Mosart template, we have the following shots for a Camera Control device:
In the screenshot above, based on the numerical input Cameras, shots 1 and 2 will be executed by the first robotic camera controller, while shot 3 will be executed by the second robotic camera controller.
Shot 1:
Cameras number is set to 0, meaning the shot will be applied to the first controller configured, as 0 is within the range 0-1 set in the Cameras field.
Page Preview is set to 0, meaning Preset 4 (in field Preset Preview) will be applied to camera POD2-PTZ3 in Preview.
Page program is set to 2, which is outside the range 0-1, so the preset will not be applied in Program.
Shot 2:
Camera number is set to 1, meaning the shot will also be applied to the first controller, as 1 is within the range 0-1 set in the field Cameras.
Page Preview is set to 1, meaning Preset 2 will be applied to camera POD2-PTZ4 in Preview.
Page Program is set to 1, meaning Preset 3 will be applied to camera POD2-PTZ4 in Program, but with a delay of 15 frames.
Shot 3:
Camera number is set to 2, meaning the shot will be applied to the second controller configured, as the number matches the value set in the field Cameras.
Page Preview is set to 2, meaning Preset 1 will be applied to camera VIZRTV-MTTE02 in Preview.
Page Program is set to 2, meaning Preset 2 will be applied to camera VIZRTV-MTTE02 in Program.
In other words, the following moves were executed in Preview (note that camera POD2-PTZ4 is disconnected):
and the following moves were executed in Program (again, note that POD2-PTZ4 is still disconnected, the shot will not be executed. This event also appears in the technical logging):
GPO
The GPO editor is used for sending GPOs to external equipment.
The editor supports multiple GPO sends.
Add a new line in the editor for multiple GPO sends.
Tip: For GPO values, refer to section GPIIO.
gpo_preview: GPO to send when a template is cued in Preview. Info: Newsroom tag available.
gpo_program: GPO to send when a template is taken in Program. Info: Newsroom tag available.
Light Control
Info: The commands to use are driver-dependent and may vary.
Guidelines for Light Control Configuration
Option | Description |
PREVIEW COMMAND | Command to use for the light mixer cue to be recalled when template is cued in Preview. Info: Newsroom tag available. |
PREVIEW VALUE | Light mixer cue to use when template is cued in Preview. Info: Newsroom tag available. |
PROGRAM COMMAND | Command to use for the light mixer cue to be recalled when a template is taken in Program. Info: Newsroom tag available. |
PROGRAM VALUE | Light mixer cue to use when a template is taken in Program. Info: Newsroom tag available. |
Preview Command and Program Command options are available from the drop-down list.
For OSC drivers (grandMA3 or ETC Eos Family) messages will be parsed from Custom command text. See OSC parsing below.
Command | Parameter count | ||||||||||||||||||||||||||||||||||||||||||||||||||||
AllOff | <none>. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Fire | 1.For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Go | cue number. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
GoOff | cue number. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Load | cue number. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
NoteOff | numeric note # (Std. MIDI command). For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
NoteOn | numeric note # (Std. MIDI command). For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Reset | <none>. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Restore | <none>. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Resume | variable. For details, see Set below. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Set | The value of SET is presented below in the context of Midi Show Control Specifications
Info: You can include an optional time value (key/value[/time]), in the form: key=value@hh:mm:ss:ff If unexpected program conditions occur, use a (dummy) time parameter. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Stop | cue number. For details, see Set above. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Custom | SysEx bytes Send multiple custom SysEx bytes in the format | ||||||||||||||||||||||||||||||||||||||||||||||||||||
TimedGo | - (unsupported). For details, see Set above. |
OSC message parsing
For OSC-controlled lighting consoles, the Custom command type must be used for both Preview and Program; the string then added in the “Value” field should then be written according to the specification of the controlled device (grandMA3 or ETC).
grandMA3
The text before the first comma will be taken as the OSC address; for example: [/Page1/Fader201]
If there’s more text, then then next part until a comma will be interpreted as OSC type tags; for example: [iTs]
The rest of the text value will be interpreted as a list of OSC arguments, separated by commas; for example: [5, text]
Quoted texts will be parsed as one argument. Quotes can be escaped with “\“, and backslashes can also be escaped by “\“. Example: [5, text, “2 words“, “text with \\ backslash“]
For an OSC type that does not require an argument (for example True, False), there should not be any.
The number of provided arguments must be equal to the number of provided type tags (that require an argument).
The arguments must be parsable as their OSC type.
Supported OSC Types
int32 (i)
float32 (f)
OSC-string (s)
True (T)
False (F)
Null (N)
Impulse (I)
Examples (for illustration only; always refer to MA documentation):
/cmd, s, Echo word
/cmd, s, "Echo \",1\""
/Page1/Fader201, i, 100
/someAddress, sis, Flash, 1 , Strobe 1 Cue 1
ETC Eos family
The text before the first equals sign will be taken as OSC address; for example: [/eos/group/1/param/pan/tilt]
The rest of the text value will be interpreted as a list of OSC arguments, separated by commas; for example: [5, 10]
Arguments will be parsed first as int32. If that fails, then float32, and if that also fails, as string.
Supported OSC Types
int32 (i)
float32 (f)
OSC-string (s)
Examples (for illustration only; always refer to ETC documentation):
/eos/preset/fire=1
/eos/group/1/param/pan/tilt=90,75
/eos/cmd=”Chan 1 At 75"
Router Control
The router control device allows setting crosspoints for source/destination pairs when the template is both cued in Preview and aired in Program.
Add new lines in the router device editor to support setting multiple crosspoints.
Guidelines for Router Control Configuration
Source preview | Source to route when a template is cued in Preview. |
Dest preview | Destination of routing when a template is cued in Preview. |
Source program | Source to route when a template is aired in Program. |
Dest program | Destination to route when a template is aired in Program. |
matrix | If the router system supports multiple matrices, select the matrix to use here. |
level |
program_delay | Delay, in frames after the template has been taken to the air, for ‘program’ routing to happen. |
salvo_preview | Salvo name to recall when a template is cued in Preview. |
salvo_program | Salvo name to recall when a template is aired in Program. |
Info: Newsroom tags are available on every column of the Router Control device. Source preview, Dest preview, Source program and Dest program offer the configured router sources and destinations as a pick list; matrix, level, program_delay, salvo_preview and salvo_program are free-text fields.
Audio Faders
Adding, removing and configuring audio faders
To add audio faders
Add audio faders to the template by right-clicking in an empty part (large grey area to the left) of the audio fader area and selecting Add fader.
Set the audio mixer crosspoint from the drop-down menu by clicking the label at the top of the fader.
Note: Clicking Apply audio settings to all applies all the changes to all templates of the same type and variant throughout all template sets.
To set audio fader level
The main level for the fader is set by dragging the notch or clicking the arrows.
The default fader level when adding a new fader is0dB.To set level 2 of the fader press SHIFT while dragging.
A tool-tip opens to signal the editing of the level 2 fader level.To set level 3 of the fader press SHIFT+CTRL while dragging.
A tool-tip opens to signal the editing of level 3 fader level.
Level 3 audio can be used with VOICEOVERS, when the AUDIO control command FADE_DOWN_SECONDARY_AUDIO is called.
Video server faders are then faded to this level 3 (when set), instead of being muted.
To remove a fader
Right-click over the fader and select Remove fader.
To configure a fader
Right-click over the fader to open the context menu and follow the Guidelines below.
Guidelines for Audio Fader Configuration
Remove Fader | Removes the fader from the template. | ||||||||||||||||||||||||
Order | Rearranging the order:
Fader type | Action: When a fader control is set as an Action fader, the controls define whether the fader is enabled or disabled. Level: For standard audio operation. | ||||||||||||||||||||||||
Fader Action |
Link | Assigns a video/audio link group to this fader.
Keep level | Keeps the fader level until manually changed. | ||||||||||||||||||||||||
Fade up in preview | Fades up the audio in preview, when camera is in program. Enabling this functionality only works with specific template combinations, as shown below:
Input device | Sets the type of the audio fader.
Crossfade time | Sets the in and out crossfade time (in video frames) for the fader.
Manual close | Select to ignore sending Close-level commands to audio mixer. | ||||||||||||||||||||||||
Mode | Only for Studer Vista and Lawo! Sends the chosen value to the mixer board for the audio fader.
Delay | Only for Studer Vista, Studer 3000 using Ember and Lawo RMNOPL! Gives a delay value (in milliseconds) for that audio fader that will be sent to the audio board.
Loudness | Sends chosen recall value to send to the Jünger audio processor.
