Note: Timing Display has been retired. The Timing Display web app was removed from Mosart Web Apps 3.1.
Moving from Timing Display to Smart Panel
Smart Panel covers everything the Timing Display did, and adds control surfaces the Timing Display never had: buttons that fire Viz Mosart commands, audio faders, live video, graphics lists, and the ability to output a whole panel as an NDI source. Rather than only timing, a single panel can now host both timing information for the studio floor and controls that operator needs.
Everything you built a Timing Display for has a direct equivalent:
In the Timing Display
In Smart Panel
Timer fields driven by the active rundown
The Timer item, which shows a live timer or countdown driven by Viz Mosart. The Label item does the same for text values.
Editing grid for laying out timers
The panel canvas. Drag an item to move it and drag a corner or edge handle to resize it; items snap to the grid defined in Panel properties.
Drag and drop timing details from a list
The component palette on the left of the editor. Every placed item also appears in the searchable Panel Items list.
Text formatting: color, bold, alignment, show label
Item properties: Text color, Font weight, Text alignment and the label settings, plus a background color with optional transparency.
Customizable audio countdown
Audio Countdowns in the editor. The same eight events are available: End of Current Story, Start of Next Break, End of Rundown, End of Current Package, End of Current Break, End of Current Voice Over, End of Current Float/Adlib and End of Current Item, each with a configurable offset before or after the event.
Viz Mosart server status field
The Connection Status widget, which shows the server connection state including the main and backup beacon.
View Mode and Edit Mode
The editor and Display mode. Use the browser's own full-screen mode for an unattended screen.
Several named displays for different positions
Several panels. Each is listed on the Smart Panel landing page and opens independently.
Distributing a display with Copy link
Copy link on the panel card, shared the same way.
Browsing on a tablet or phone
Unchanged. A panel opens on any device with a browser.
Rebuilding your displays
Info: Existing Timing Display layouts are not converted automatically. A Timing Display layout is a flat list of timer fields, whilst a Smart Panel layout is a canvas of positioned items, so there is no meaningful automatic mapping between them. Saved Timing Display layouts are no longer read, the panels you want must be built once-only in Smart Panel.
In practice this takes a few minutes per display. To shorten it further, Smart Panel ships with a set of ready-made default panels that cover the usual Timing Display arrangements: pick one in the panel picker when you create a new panel, then adjust it rather than starting from an empty canvas.
Your audio countdown files do not need to be moved. Smart Panel reads them from the same media folder on the Mosart Web Apps host that the Timing Display used, so files already placed there remain available.
Note for Administrators
A TimingDisplay configuration section is still present on the Mosart Web Apps host, and its service endpoints remain in place. This is expected: Smart Panel uses them for panel layouts, images, audio countdown files and the media folder setting, along with the TriCaster credentials used for live video. Keep this configuration in place. Only the Timing Display web app itself has been removed.
Documentation for Earlier Versions
If you are still running Mosart Web Apps 3.0 or earlier, the Timing Display documentation for your version remains published at the Vizrt Documentation Center. Select your version there, for example the the 3.0 User Guide, and open its Timing Display section.
