A Viz Template Wizard template can be used to further extend a show’s functionality.
Dynamically Adding Components
Viz Trio supports the CreateVTWComponent function in Viz Template Wizard for dynamically adding components at run-time.
The following is an example where a text box and a button are used to generate a label at run-time:
curY = AddButton.Top + AddButton.Height + 5 Sub AddButtonClick(Sender)    lbl = CreateVTWComponent("TTWUniLabel", Sender.Parent)    lbl.Parent = Sender.Parent    lbl.Left = Sender.Left    lbl.Top = curY    curY = curY + lbl.Height + 2 SetUnicodeValue lbl, GetUnicodeValue(SampleEdit)End SubSet and Get Component Values
Viz Trio supports the SetUnicodeValue and GetUnicodeValue functions in Viz Template Wizard.
The following is an example of a text box being used to get and set a value in another text box without using TrioCmd:
Sub TWUniEdit1Change(Sender)    Text = GetUnicodeValue(TWUniEdit1)    SetUnicodeValue TWUniEdit2, Text End SubSet and Get Show Values
Using Viz Template Wizard to create standard templates for a show is useful as it enables you to execute default commands for an entire show. It's therefore possible to set and get show values; however, there are some subtle differences between the two.
For example, when issuing a command such as TrioCmd("page:read 1000") within a Viz Template Wizard template, the page numbered 1000 is read and previewed.
However, in order to get (return) values, a command must be properly triggered by another event since all Viz Trio commands are queued. The return value is therefore QUEUED. When a top-level command is executed (from the interface or a macro) it's added to an internal queue and executed after other queued commands are finished.
In order to get return values, the code using TrioCmd() must be issued by another top-level command. In a VTW template this is achieved by adding Viz Trio commands to events:
Function OnMyButtonClick(Sender)    TrioCmd("page:read 1000")    TrioCmd("vtwtemplate:run_vtw_script GetDescription")    TrioCmd("page:read 1100")    ... End Function Function GetDescription()    returnvalue = TrioCmd("page:getdescription")    msgbox returnvalue End FunctionIn the example above, the second command vtwtemplate:run_vtw_script is triggered within GetDescription and returns the description value.
