Viz Trio 4.4.3
Release Date: 2025-10-31
These are the release notes for Viz Trio version 4.4.3. This document describes the user-visible changes that have been done to the software since release 4.4.2.
Fixed Issues
  • Opening or drag-dropping any Pilot Edge elements into a playlist could raise an exception (TRIO-6597, TRIO-6669).
  • Using a Pilot Edge template, Superchannels and Shared Memory Script the UI could freeze when selecting a clip (TRIO-6656).
  • Vertical line char in control Hint-message leads to runtime exception (TRIO-6666).
Viz Trio 4.4.2
Release Date: 2025-10-09
These are the release notes for Viz Trio version 4.4.2. This document describes the user-visible changes that have been done to the software since release 4.4.1.
Fixed Issues
  • Opening elements in MOS playlist could raise an exception when using a relative and dynamic path variable instead of an absolute URI (TRIO-6639).
  • Generating many pages quickly could cause a script to fail to retrieve the description of the page (TRIO-6632).
  • Clicking in the Media Search window outside of an image could raise an exception (TRIO-6638).
  • During a Viz Archive import under some conditions an exception could be seen, that forced the Progress window to remain on screen (TRIO-6640).
  • When creating a new macro, the name was not immediately displayed and could force Settings dialog to be reopened (TRIO-6649)
Viz Trio 4.4.1
Release Date: 2025-09-12
These are the release notes for Viz Trio version 4.4.1. This document describes the user-visible changes that have been done to the software since release 4.4.0.
Improvements
  • Error dialogs for scripts is now more detailed, indicating the line and character location (TRIO-6577).
  • Images and geoms now display the full path in tabfields (TRIO-6576).
  • Loading and displaying thumbnails for video and image search, was improved with pagination and asynchronous retrieval (TRIO-6548).
Fixed Issues
  • Opening an existing Scroll Template ‘Config’ could crash the client (TRIO-6620).
  • Unable to create a new Viz Trio Scroll after starting the Viz Trio client (TRIO-6619).
  • When first opening a scene in the Page Editor, an error could be observed in the log due to the scene not being fully loaded (TRIO-6617).
  • Opening a template into the page editor would not show images, set via the image control, in the render preview (TRIO-6615).
  • Switching between shows with different script folders would cause a crash (TRIO-6614).
  • Scene Importer no longer reports to log about virtual tabfields missing payloads (TRIO-6613).
  • Combo templates are now automatically recreated when the scene is edited in the local Artist, or re-importing other (TRIO-6608).
  • Generating many pages via script could raise an exception (TRIO-6607).
  • Under some conditions, saving a combo template could raise an exception (TRIO-6605).
  • Templates saved as a Page, could miss tabfields from being stored in the Data section of the new page (TRIO-6603).
  • Import and Initialize buttons now work as intended (TRIO-6602).
  • No content was shown, while using media search against Viz One, and searching with keywords (TRIO-6599).
  • When using a Table Editor and the selected cell contains an image, selecting an image now properly loads it into the preview (TRIO-6595).
  • The Close button for Viz Archive import status window, could sometimes remain active and not enable close button (TRIO-6592).
  • Editing an attached show script could crash the client (TRIO-6589).
  • Combining a script with the usage of macros to change the position and data, together with hotkeys, was not fully functional (TRIO-6588).
  • Scenes using the ControlList plugin, were not updating the value changes in real-time, in preview (TRIO-6586).
  • Rich text tabfield no longer displays formatting wrappers as part of the displayed value (TRIO-6583).
  • Vertical misalignment could cause tab fields editors to be out of view (TRIO-6582).
  • Changing image scaling could result in invalid image path value (TRIO-6579).
  • Viz Trio OneBox failed to start program channel (TRIO-6578).
  • Selecting an image in tabfield for image, now shows the full image path (TRIO-6569, TRIO-6575).
  • Scripts are now properly reloaded if updated (TRIO-6568).
  • In some cases, releasing or requesting a rundown from NRCS, could raise an exception (TRIO-6567).
  • Template SaveAs no longer halts execution of OnSave call, but runs all commands (TRIO-6565).
  • Scripts now support passing arrays as reference parameters (TRIO-6551, TRIO-6552).
  • A selected image in a pages image tabfield, is now properly shown when switching to another tabfield and back (TRIO-6549).
  • Tab key behavior in tabfield for Control Objects with child-fields, is no longer unpredictable (TRIO-6547).
  • Reintroduced the ability to hide the Thumbnail column in the Template List (TRIO-6546).
  • Reintroduced the ability to open the context-menu in page editor for Cut/Copy/Paste functionalities (TRIO-6545).
Viz Trio 4.4.0
Release Date: 2025-06-02
These are the release notes for Viz Trio version 4.4.0. This document describes the user-visible changes that have been done to the software since release 4.3.1.
Release Highlights
This release of Viz Trio introduces the ability to create and manage playlists using Viz Pilot Edge elements and provides initial support for the upcoming Viz Pilot backend. This allows users to produce shows directly in Viz Trio without relying on NRCS or MOS playlists.
Furthermore, we are introducing a redesigned and faster Media Search panel, improvements to the Graphic Hub REST Scene importer (now called Rapid Import), and a new way to control waiting times from one place without intruding on existing macros and scripts.
New Features
  • Create a Media Sequencer hosted playlist and populate it using Viz Pilot Edge elements (TRIO-6452).
  • The new wait command allows custom delay between actions in a macro, defining the wait amount on a system wide base, per use of other commands (TRIO-6414, TRIO-6445).
Improvements
  • Playlist and Page List can now indicate content type, such as Viz Pilot Edge (elements), TL (for transition logic) and Combo (for pages based on a Combo Template) (TRIO-6023).
  • Graphic Hub archive import now displays a progress dialog, instead of merely freezing the main UI until done (TRIO-6447).
  • The Playlist elements Run and Preview status, expand from icon, to show a clear highlight for the full element line (TRIO-6375).
  • Media Search Frame reimplemented for performance and visual clarity, such as thumbnails displaying results without delay (TRIO-6395, TRIO-6434).
  • Transition Scene script increased the amount of characters used as a parameters from 200 to 1000. transitions.via must be reimported to allow this (TRIO-6168).
  • There is now a user setting to follow classic tabfield tab order, as seen in Viz Trio 3.x (TRIO-6461).
  • Viz Pilot Edge configured behind a failover, is now supported (TRIO-6482).
  • Page Editor side panel icons have tooltips to help and guide users (TRIO-6363).
  • The Viz Trio Profile configuration dialog and statusbar, can now display superchannel information (TRIO-5934).
  • A MOS playlist properly appears after activating the rundown in NRCS (TRIO-6417).
  • Scene import can be triggered by drag-dropping a scene from the scene browser, into the template pool (TRIO-6341).
  • The command-line parameter -usersetting can be used to share configuration layout for multiple clients (TRIO-6489).
  • Added the configuration for Viz Pilot Edge’s address as a setting (TRIO-6502).
  • Reimplemented gui:edit_page_description to allow a macro to step into editing mode, for the description of an element (TRIO-6450).
  • When using Viz Engine 5.1 and performing a Rapid Import, a new command allows a quicker creation of VDF for a scene (TRIO-6366).
  • Rapid Import reports progress and any seen errors in the log section (TRIO-6365).
  • Description of master template is now properly set during Rapid Import (TRIO-6405).
  • When using Media Sequencer 5.8.0 or newer and Rapid Import, the Export Mode fields are properly reflected (TRIO-6406).
Fixed Issues
  • Local preview is now updated with every keystroke when editing values in a Table Editor (TRIO-6398).
  • Activating GPI triggering with an unset (blank) command for an entry, no longer reports an error entry to the log-file (TRIO-6443).
  • If auto-login to Graphic Hub is set to false, setting and later removing the Graphic Hub address, no longer causes an exception shown on startup (TRIO-6403).
  • Page Editor now accurately reflects the caret position when selecting part of the text in the editing section (TRIO-6319).
  • Assigning a script from a file now works without issues being listed in the errors section (TRIO-6458).
  • Hovering the mouse cursor over a vertical toolbar button and holding the Tab key, shows an exception (TRIO-6459).
  • Scripts are now able to properly use COM objects, used by the external application, to populate data in pages (TRIO-6438).
  • Visual flickering when scrolling large pilot element playlists, has been removed (TRIO-6421).
  • Exporting and importing very large collections of pages is now possible without raising an out-of-memory exception (TRIO-6570).
  • Data in using a Control List plugin in a Combo page can now be edited (TRIO-6415).
  • Text Tabfield with the ‘single line' property set to true, no longer accepts Enter and Shift-Enter keys, to introduce new lines (TRIO-6457).
  • Script parser adjusted to allow the usage of extended Unicode characters in unit names in a script, without raising an exception (TRIO-5398).
  • Running scripts and setting not allowed values to properties, no longer raise an exception, but logs the information nicely (TRIO-6314).
  • Using Insert range of pages could raise an exception, this has been corrected (TRIO-6462).
  • Live preview of Combo page with formatted text Tabfield, now works correctly (TRIO-6460).
  • Automatic selection of next element in playlist or pagelist after read, now works as it should (TRIO-6330).
  • If a Tabfield editor value is set from a script or macro, the field is no longer automatically set to gain focus (TRIO-6485).
  • In a Table Editor (Control List plugin), now using the spacebar when navigating around the fields, quickly adjusts its state (TRIO-6505).
  • Tab order for Table Editor when a row is selected, is aligned to what Viz Trio 3.x had (TRIO-6509).
  • Under specific conditions, deleting data in Table Editor, could raise an exception (TRIO-6504).
  • The navigation of Control List via Table Editor, using arrow keys and mouse-click, has been corrected (TRIO-6507).
  • Profile names containing underscore, are now properly shown in the profile list, in the quick selection menu (TRIO-6531).
  • Text copied from a cell to another in a Table Editor (Control List plugin), no longer contains unwanted mark-up details (TRIO-6524).
  • When inserting or deleting a row in a Table Editor (Control List plugin), there is no longer a loss of cursor position (TRIO-6526).
  • Doing a Cut (Ctrl + X) inside a text cell in a Table Editor (Control List plugin), could result in the full selected row being copied and removed (TRIO-6534).
Licensing
Viz Trio 4.4.0 requires a WIBU software license.
Hardware Requirements
In general, Viz Trio hardware requirements should match the hardware requirements for a preview version of the Viz Engine. See the Viz Engine Release Notes for supported hardware.
Software Requirements
For Database connectivity with Excel files (.xls, .xlsm, .xlsb and .xlsx), you may need the following to be installed if Microsoft Office is not installed on the machine:
Microsoft Access Database Engine 2016 Redistributable (accessdatabaseengine_X64.exe). It can be downloaded from Microsoft: https://www.microsoft.com/en-us/download/details.aspx?id=54920.
Recommended Versions
Operating Systems
  • Windows 10
Server
  • Windows Server 2019
  • Windows Server 2022
Software
  • Viz Engine 5.3.0
  • Viz One 7.3.2
  • Graphic Hub 3.9.2 (optional with Graphic Hub REST 2.9.2)
  • Media Sequencer 5.8.0
  • Pilot Data Server 9.2.0
  • Viz Pilot Edge 3.3.0
  • Viz Maps 21, 22, 23 and 24
Previous Versions
In accordance with the Vizrt Global Support Handbook section Software Lifecycle, support for older versions ends 24 months after a subsequent minor or major version is released.
With this release, earlier versions of Viz Trio are no longer supported after 2027-06-02.
Support for Viz Trio 4.1.0 ends on 2026-04-02.
Documentation
Documentation for Viz Trio is available at the Vizrt Documentation Center:
Support
