Vizrt iNEWS Command Plugin 3.1.3
Release Date: 2026-06-23
These are the release notes for Vizrt iNEWS Command Plugin version 3.1.3. This document describes the user-visible changes that have been made to the software since release 3.1.2.
Fixed Issues
Fixed an issue where some unicode special characters (multi-character unicode codepoints) in *cg elements, could cause the system to become unresponsive (MSE-9734).
Requirements
This plug-in is to be used with:
Avid MediaCentral® | Command 2020.9.2 or higher.
Viz Pilot Data server 8.8.0 or higher.
Viz Preview Server 4.5 or higher.
Media Sequencer version 5.4.0 or higher.
This plug-in has been tested with the following versions:
Avid MediaCentral® | Command 2023.7 (Former Versioning: 3.17.0.41)
Avid MediaCentral® | Newsroom Management (iNEWS) 2022.12 (Former Versioning: 8.2.0.42)
Media Sequencer 5.8.1
Viz Pilot Data Server 9.6.0
Viz Pilot 8.9.5
Viz Trio 4.6.0
Viz Preview Server 4.7.1
Viz Engine 5.5.2
Viz Graphic Hub 3.9.3
Viz GH REST 2.9.3
Vizrt iNEWS Command Plugin 3.1.2
Release Date: 2023-12-18
These are the release notes for Vizrt iNEWS Command Plugin version 3.1.2. This document describes the user-visible changes that have been made to the software since release 3.1.1.
Improvements
Updated dependencies in order to address results of security scan (MSE-8946).
Fixed Issues
Fixed an issue where the plugin configuration panel did not show up if there were no channels configured in MediaCentral Command (MSE-8959).
Fixed an issue where polling of elements in a large playlist, could cause delays in playout commands (MSE-9086).
Requirements
Avid MediaCentral® | Command 2020.9.2 (Former Versioning: 3.16.2)
Avid MediaCentral® | iNEWS 8.2.0
Media Sequencer 5.5.1
Viz Pilot Data Server 9.0.0
Viz Pilot 8.9.1
Viz Trio 4.1.0
Viz Preview Server 4.6.0
Viz Engine 5.1.1
Viz Graphic Hub 3.9.1
Viz GH REST 2.9.1
Vizrt iNEWS Command Plugin 3.1.1
Release Date: 2022-10-26
These are the release notes for Vizrt iNEWS Command Plugin version 3.1.1. This document describes the user-visible changes that have been made to the software since release 3.1.0.
Improvements
Changes made on the connection library setting. This fixes the problem of stalled connections and redirect reported in MSE-8614 (MSE-8692).
Fixed Issues
Fixed the problem with UTF-8 chars ñ,á,é.í etc. (MSE-8613 and MSE-8698).
Requirements
Avid MediaCentral® | iNEWS 7.9.0
Media Sequencer 5.4.1
Viz Pilot Data Server 8.9.0
Viz Pilot 8.8.0
Viz Trio 4.0.0
Viz Preview Server 4.5.0
Viz Engine 4.4.1
Viz Graphic Hub 3.7.1
Viz GH REST 2.7.0
Vizrt iNEWS Command Plugin 3.1.0
Release Date: 2022-05-11
These are the release notes for the Vizrt iNEWS Command Plugin version 3.1.0. This document describes the user-visible changes that have been made to the software since release 3.0.2.
Requirements
Viz Pilot Data Server 8.8.0.17
Viz Trio 3.2.6.21193
Viz Pilot 8.7.0.24995
Media Sequencer 5.4.0
Viz Engine/Artist version: 4.4.1
New Features
Added support for HTTPS TLSv1.2. Internally all the HTTP communication is now using Apache HttpComponents instead of Apache Abdera (MSE-8348).
Restrictions
When Using Star CG Syntax
Using a combo template with an external id does only support layers with one state. That is:
If the layer has more than one choice that is non-empty, the layer is ignored.
If the layer has only one choice which is non-empty, this choice is selected.
Known Issues
No default values are present for star CG elements with no input data.
Info: If the following external template v1003 has two input text fields where default values have been set in Viz Content Pilot, then the syntax *CG v1003 gives a data element with empty values. (MSE-3966, VCP-2320)
Continue count is not supported for star CG elements based on Trio templates.
Restrictions on template identifiers recognized by the Avid MediaCentral® | Command system (MSE-4900).
When the configuration setting Use template name as an identifier for Viz Pilot CG elements is on, the identifier for the external template is the “Description” field of the external template given in Pilot Template Manager.
The integration with Avid MediaCentral® | Command has restrictions for the characters in the identifiers. This has to be enforced by the user.
Characters that do not work: forward slash, backward slash, full stop.
Note: iNews only accepts template identifiers being one word. Templates not following these rules might not be recognized by the Avid MediaCentral® | Command system.
For a template identifier containing the character full stop (“.”) the template will not work, and in addition to loading, such a template into the inventory causes problems to the inventory. This plug-in, therefore, filters out templates with such identifiers.
For Trio CG templates: Viz Artist disallows the mentioned characters in scene names.
Vizrt Plug-in Settings
Plug-in settings do not support Thai, Bengali, or Hindi. The problem is related to the environment run by Avid MediaCentral® | Command.
Standalone Playlists and Shotbox
This is not supported.
Other Known Issues
The following described issue applies when the config setting Enable initializing of a playlist or item in a playlist is not selected. The issue can be resolved in Avid MediaCentral® | Command (MSE-5670).
When the user right-clicks on a graphic element in Avid MediaCentral® | Command, the options for initialization are available. These options are also available in the Main Menu (Playlist > Graphics > Initialize Item/ Initialize Playlist).
Resource handling of rundowns from Avid iNEWS: If rundowns are not unloaded after use, or they are unloaded when the corresponding playlist is locked in Avid MediaCentral® | Command, the Vizrt graphics used in such rundowns will remain in the playlist held by Media Sequencer. This represents a resource leakage. A workaround for remove of such dangling elements is to delete the Pilot playlist created by Vizrt iNEWS Command Plugin and restart Media Sequencer and restart the Vizrt iNEWS Command Plugin.
Sometimes the user can experience missing thumbnail updates in Avid MediaCentral® | Command client. A workaround is to resize the column that shows the thumbnails.
Documentation
Documentation for the Vizrt iNEWS Command Plugin is available at the Vizrt Documentation Center:
Support
