DataPool User Guide
Version 2.13 | Published November 30, 2018 ©
External Interface
The external interface to DataPool is based on Viz messages sent to the DataPool plugin. Each message contains a series of data assignments to different DataFields.
The structure of the message is:
command1 command2 command3 ...
The structure of each command is as follows:
<Name>[items range] = datum1, datum2, datum3, ...;
Where name is the name of the DataField to assign data to and items range is a description of items to which the data is addressed.
Note: The semicolon is part of the command and should be added at all times. It is used to define the end of the command.
The item ranges are a comma-separated list of indexes, or a from-to index.
Examples
Send data to a field named VALUE:
VALUE=
30
Send data to the first five values of a field called VALUES:
VALUES[
0
4
0
1
2
3
4
The above is equivalent to sending:
VALUES[
0
0
; VALUES[
1
1
; VALUES[
2
2
; VALUES[
3
3
; VALUES[
4
4
Note: The indexes of the items are zero-based (start from 0).
Send data to the items 1-3, 55-57 and 101:
VALUES[
1
3
55
57
101
0
1
2
3
4
5
6
This is equivalent to sending:
VALUES[
1
0
; VALUES[
2
1
; VALUES[
3
2
; VALUES[
55
3
; VALUES[
56
4
; VALUES[
57
5
; VALUES[
101
6
