DataPool User Guide
Version 2.13 | Published November 30, 2018 ©
Silent Installation
The silent installation enables the user to install Viz DataPool without using the installer GUI. This option is used when a large number of machines require the software to be installed. To use the silent installation mode, run the installation file with the /s flag. This option installs most of the DataPool plugins (except for the project specific plugins).
Example
In a command shell, run the following command:
C:\Temp\DataPool_2.
11.0
.exe /s
Another option is to create a Windows shortcut to the installation file and add the /s parameter to the Target text field, after the file path.
