Version 2.2 | Published September 14, 2023 ©
Introduction
The Graphics Plugin integrates Vizrt’s graphics workflow into the Non-Linear Editing (NLE) workflow.
Users can follow their normal workflow using their preferred NLE system, while adding real-time rendered Vizrt graphics.
The Graphics Plugin integrates with a variety of NLE systems: Adobe Premiere Pro, Apple Final Cut Pro, Avid Media Composer, Quantel Rio and Grass Valley Edius. Although the Graphics Plugin versions are tailored to the specific platforms, the overall setup and user interface is the same.
Note:
The Graphics Plugin version 2.2 provides plugins to Adobe Premiere Pro, Avid Media Composer and Edius.
Viz Trio, Viz Pilot Edge, Viz Pilot, and the Graphics Plugin Editor are all interfaces that let the NLE user interact with the Vizrt graphics workflow and edit graphics elements. The Graphics Plugin supports NLE systems on both Windows and Apple platforms. Viz Trio and Viz Pilot Edge and Viz Pilot are available for Windows-based NLE Systems. Viz Pilot Edge and the Graphics Plugin Editor is available for the Mac-based NLE Systems.
Feedback
We welcome your feedback and suggestions regarding Vizrt products and this documentation.
Please contact your local Vizrt customer support team at http://www.vizrt.com.
Submitting a Support Request
The Graphics Plugin is (despite the simple interface) a complex integration of several products. The Graphics Plugin is hiding most of this complexity to the users and to a certain extent also to the people who set things up. When completing a support request, please add as much information as possible. See Log Files for information about how to reproduce the problem for the specific Graphics Plugin installed.
Note:
All problems should be registered using Vizrt’s Support Portal. If your company does not have access to the portal a report should be sent to a local Vizrt representative or directly to support@vizrt.com.
To submit a Support Request
  1. Go to www.vizrt.com.
  2. Click Menu > Support > Get Support.
  3. Click on Login to the Vizrt Global Support portal to submit your support request.
