Version 2.2 | Published September 14, 2023 ©
Supported NLE Systems
The list below currently supported NLE systems within the scope of this document. Other versions are not officially supported unless specifically mentioned as part of this document.
The following systems are supported:
Adobe Premiere Pro
The Graphics Plugin for Adobe has been tested against, and supports the following versions:
  • Premiere Pro CC 2019 (13)
  • Premiere Pro CC 2018 (12)
  • Premiere Pro CC 2017 (11)
This plugin works on both Windows and Mac machines.
Avid Media Composer and Avid NewsCutter
The Graphics Plugin for Avid supports the following versions:
  • Avid Media Composer 8.9
  • Avid Media Composer 2018
This plugin works on both Windows machines and Mac machines.
The following systems support the Avid Extensions (AVX) 2.0 System Development Kit (SDK):
  • Avid Digital Studio (DS)
  • Media Composer (Older Release and Post Adrenaline HD release that can run software only), Media Composer Adrenaline, and Media Composer Adrenaline HD
  • NewsCutter, NewsCutter FX, NewsCutter XP, and NewsCutter Adrenaline (FX)
  • Symphony and Symphony Nitris
  • Xpress, Xpress Pro, and Xpress Pro HD
Grass Valley EDIUS
The Graphics Plugin for EDIUS supports the following versions:
  • EDIUS 8
  • EDIUS 9
This plugin works only on Windows machines.
Apple Final Cut Pro
The Graphics Plugin for Final Cut works together with Apple Final Cut Pro 6 and 7 (available in Final Cut Studio 2 and 3, respectively), and Final Cut Pro X. This plugin works on Mac-machines only.
Note:
There are separate installers for versions 6+7, and X.
Quantel Rio
The Graphics Plugin for Quantel works together with Quantel Rio 4.3, or later. This plugin works on Windows machines only.
Note:
Version 2.0 of the Graphics Plugin supports earlier versions of Quantel QEffects/Rio (version 4.2).
