Template Builder User Guide
Version 1.0.3 | Published September 27, 2017 ©
Template Preparation
The current version of Template Builder relies on templates being generated and organized using Viz Pilot's Template Wizard. The following procedures will give you a quick introduction on how to create and manage a template. For more information on how to work with Template Wizard, please see the Viz Pilot User's Guide.
Creating a Template
images/download/attachments/30117088/image2017-5-10_13_24_21.png
The following procedure explains how to create and save a template.
To create a template:
  1. Start Template Wizard
  2. Connect to your Viz Engine
  3. On the File menu, select Wizard
  4. Drag and drop the scene to the Selected Scenes pane (right)
  5. Click Finish
  6. On the File menu, select Save (Ctrl+S)
  7. Enter a Template name
  8. Select a Concept name (or create a new)
  9. Click Save as New
Managing Concepts and Variants
images/download/attachments/30117088/image2017-5-10_13_17_39.png
The following procedures explain how to organize a template for use with more than one concept and variant, for example a Blue and Red concept with a lower and upper third graphic. As a prerequisite all scenes should have the same type of data in order to use the same template.
To manage concepts:
  1. On the Tools menu, select Template Manager
  2. Under the Concepts - All pane, click New
  3. Enter a name for the new concept and save it
  4. Open the other concept
  5. Drag and drop the template from the old to the new concept (and confirm the operation)
  6. Open the new concept
  7. Edit the template by selecting the correct Scene folder for your new concept
  8. Save and confirm the operation
To manage variants:
  2. Select your concept, then the template
  3. Under the Template variants pane, click New
  4. Enter a Description of the variant
  5. Select the Scene name that is a variant of the other
  6. Save and confirm the operation
