Gateway Administrator Guide
Version 5.1 | Published June 04, 2018 ©
Advanced Queuing (AQ) is not working properly.
  • An XML parser failure may be an indicator that the wrong AQ protocol is in use on the database.
  • Check if the Extended AQ is in use on the database. Gateway should detect if AQ is in use or not and set the correct parameters.
