Gateway Administrator Guide
Version 5.1 | Published June 04, 2018 ©
To start the Gateway controller client
Select the program from the Start menu: All Programs > Vizrt > Media Sequencer> Gateway Controller
IMPORTANT!
This shortcut will start the Gateway Controller as a web-application in the users default web-browser. The Media Sequencer must be running before starting the Gateway Controller.
It is also possible to launch the Gateway Controller by browsing to the following web address:
http://<ADDRESS>:8580/app/gatewaycontroller/gatewaycontroller.html
Substitute <ADDRESS> above by the actual IP or hostname of the Gateway server.
Note:
It is possible to use one instance of the client to connect to multiple Gateway servers. To do this, simply connect to one server at a time and enter the appropriate connection parameters.
