Graphic Hub Terminal Server Startup Issues
Graphic Hub Terminal Does Not Start the Server
This may occur if Graphic Hub is installed as a service but not started as a service.
To start Graphic Hub as a service
Exit Graphic Hub Terminal.
Wait until Graphic Hub Terminal starts itself automatically.
Graphic Hub Terminal Service Does Not Start
To start the Graphic Hub service
On your Windows desktop of the machine where the Deploy Agent is installed, right-click My Computer and select Manage.
The Computer Management window appears.
In the left panel, expand the node Service and Applications.
Click Services.
In the right panel, right-click GH Terminal Service Properties and select Start.
Wait for the Graphic Hub Terminal to start up. If this does not occur, contact Vizrt CA.
