![](assets/images/logos/GraphicHub.png)
Version 3.9 | Published January 25, 2024 ©
Change Graphic Hub Server
You can change the binding between the Graphic Hub REST and Graphic Hub server.
Navigate to Configuration > Change Graphic Hub server.
Select a Graphic Hub server from drop-down menu or enter the address manually in form of VizDbServer@GHServer:19396 to bind to Graphic Hub server
Confirm with Apply.
The server has been successfully changed and the binding to the previous server is removed.
