Graphics Plugin for Avid Release Notes
Version 2.3 | Published March 15, 2023 ©
Graphics Plugin for Avid 2.3.5
Release Date: 2023-03-15
These are the release notes for Graphics Plugin for Avid version 2.3.5. This document describes the user-visible changes that have been made to the software since version 2.3.4.
Windows and Macintosh
Improvements
  • Display an error dialog when the plugin is not configured, instead of rendering a black frame in preview (NLE-2175).
Fixed Issues
  • Edited templates are applied to wrong effects when copying/pasting, scrubbing on other effects on the timeline or adding new effects right after an editing (NLE-2833, NLE-2892, NLE-2893, NLE-2894 and NLE-2895).
  • Viz Pilot Edge Editor reports ERR_ABORTED when loading initial URL (NLE-2907).
  • Editing of hostname fields in the Configuration Tool for Windows are not saved (NLE-2915 and NLE-2917).
Graphics Plugin for Avid 2.3.4
Release Date: 2023-03-07
These are the release notes for Graphics Plugin for Avid version 2.3.4. This document describes the user-visible changes that have been made to the software since version 2.3.3.
Improvements
Windows
  • Updated the embedded web browser used by Graphics Plugin (NLE-2855).
  • Upgrade to NLE SDK 3.0.0 on Graphics Plugins and payload editor (NLE-2859).
Macintosh
  • Updated the embedded web browser used by Graphics Plugin (NLE-2862).
  • NLE SDK updated to version 3.0.1 and Pilot Edge Editor to version 2.0.1 (NLE-2869).
Fixed Issues
Windows
  • Fixed the issue that when upgrading from version 2.0 to 2.3, the timeline behavior in Avid MC changed (NLE-2818).
  • Fixed issue of the Avid NLE not refreshing if the data was rendered (NLE-2842).
  • Graphics Plugin on Avid MC wouldn't notify of changes and used old frames (NLE-2797).
  • Fixed issue of Pilot Edge NLE not opening properly in Media composer (NLE-2819).
Macintosh
  • Removed Graphics Plugin Editor (NLE-2727).
  • Fixed the issue when upgrading from version 2.0 to 2.3, the timeline behavior in Avid MC changed (NLE-2818).
  • Fixed issue of Pilot Edge NLE not opening properly in Media composer (NLE-2872).
Graphics Plugin for Avid 2.3.3
Release Date: 2021-09-03
These are the release notes for Graphics Plugin for Avid version 2.3.3. This document describes the user-visible changes that have been made to the software since version 2.3.2.
Fixed Issues
  • Fixed issue when changing the effect metagraphics setting and it not being saved when it is changed before selecting a Viz One Graphic (NLE-2770).
Known Issues
  • The Graphics Plugin Editor is not currently supported on macOS Catalina and newer versions.
Graphics Plugin for Avid 2.3.2
Release Date: 2021-05-04
These are the release notes for Graphics Plugin for Avid version 2.3.2. This document describes the user-visible changes that have been made to the software since version 2.3.1.
Fixed Issues
  • Fixed an issue when connecting to an https Pilot Edge using the "Untrusted SSL" option in Graphics Plugin configuration (NLE-2739).
Known Issues
Graphics Plugin for Avid 2.3.1
Release Date: 2021-01-15
These are the release notes for Graphics Plugin for Avid version 2.3.1. This document describes the user-visible changes that have been made to the software since version 2.3.0.
New Features
  • Added a new feature for single thread rendering, which will improve performance in most cases (NLE-2660).
Fixed Issues
  • Graphics Plugin for Avid no longer locks Media Composer while in use. This fixed the following issues:
    • Avid MC crashes after users click “OK” in Pilot Edge (NLE-2654).
    • NLE crashes randomly when used in Avid Media Composer (NLE-2578).
  • The Help button in the config panel does not open the documentation page on macOS (CODER-3519).
Known Issues
Graphics Plugin for Avid 2.3.0
Release Date: 2020-10-20
These are the release notes for Graphics Plugin for Avid version 2.3.0. This document describes the user-visible changes that have been made to the software since version 2.2.2.
New Features
  • Added support for metagraphics export (Windows only, to be used together with Avid Assistant 1.16.1) (NLE-2605).
Fixed Issues
  • Fixed still image playback while scrubbing the timeline. The frame would not update (NLE-2562).
  • Fixed alpha blending of graphics and video on transparent pixels when color correction option was set to true (NLE-2316).
  • Fixed NLE Payload Editor (hosts PilotEdge Editor) window not hiding to system tray when user interaction finishes on Windows systems (NLE-1500).
  • Fixed Gatekeeper compliance for macOS (NLE-2564).
Known Issues
  • The Help button in the config panel does not open the documentation page on macOS. Documentation is still locally available in
    /Library/Application Support/Avid/AVX2_Plug-ins/Vizrt/AvidGraphicsPlugin.avx/Contents/Resources/SharedSupport/.
Documentation
Documentation for the Graphics Plugins is available at the Vizrt Documentation Center:
Support
