The Viz Engine configuration needs slight adaptions for Reality Connect. These are described below:
Camera
Distortion Mode
Set to Internal.
Parameter Mode
Set to Tracking Hub.
Communication
Global
General Communication Port
Set to an available port other than 0. This port is required during the Tool Configuration.
Shared Memory
UDP Port
Unreal Engine
SHM Sync Master Mode
Set to Master.
SHM Sync Master Key
Specify a non-empty name. This name is required during the Tool Configuration.
