Template Builder User Guide
Version 1.2 | Published April 26, 2019 ©
Template Preparation
The current version of Template Builder relies on templates being generated and organized using Viz Pilot's Template Wizard. The following procedures will give you a quick introduction on how to create and manage a template. For more information on how to work with Template Wizard, please see the Template Wizard section in the Viz Pilot User Guide.
Creating a Template
The following procedure explains how to create and save a template.
To create a template:
Start Template Wizard
Connect to your Viz Engine
On the File menu, select Wizard
Drag and drop the scene to the Selected Scenes pane (right)
Click Finish
On the File menu, select Save (Ctrl+S)
Enter a Template name
Select a Concept name (or create a new)
Click Save as New
Managing Concepts and Variants
The following procedures explain how to organize a template for use with more than one concept and variant, for example, a Blue and Red concept with a lower and upper third graphic. As a prerequisite, all scenes should have the same type of data in order to use the same template.
To manage concepts:
On the Tools menu, select Template Manager
Under the Concepts - All pane, click New
Enter a name for the new concept and save it
Open the other concept
Drag and drop the template from the old to the new concept (and confirm the operation)
Open the new concept
Edit the template by selecting the correct Scene folder for your new concept
Save and confirm the operation
To manage variants:
Select your concept, then the template
Under the Template variants pane, click New
Enter a Description of the variant
Select the Scene name that is a variant of the other
