Template Builder Release Notes
Version 1.3 | Published July 10, 2020 ©
Template Builder 1.3.1
Release Date: 2020-07-10
These are the release notes for Template Builder version 1.3.1. This document describes the user-visible changes that have been made to the software since release 1.3.0.
Improvements
  • Keyboard shortcuts are disabled while deciding about unsaved changes or selecting a scene. (VPE-3312)
  • High Resolution Previews of images stored on Graphic Hub have been fixed. (VPE-3326)
  • Templates can be filtered depending on their visibility. (VPE-3242)
  • Template sort is more reliable. (VPE-3291)
  • Scene sort is more reliable. (VPE-3265)
  • Concept status icons (new / inactive) are more reliable. (VPE-3321)
  • Clicking a suggested tag works all the time. (VPE-3290)
  • Unused tags can be suggested. (VPE-3293)
  • Double-clicking an asset won't trigger an error message. (VPE-3324)
  • Suggests incremental titles when Saving as. (VPE-3288)
  • Improved error reporting when Graphic Hub is not available. (VPE-3279)
Known Issues
  • Replacing a concept in a template that is being used by a data element currently On Air removes this data element from the Media Sequencer playlist ( VPE-3097 )
Template Builder 1.3.0
Release Date: 2020-05-28
These are the release notes for Template Builder version 1.3.0. This document describes the user-visible changes that have been made to the software since release 1.2.0.
Improvements
  • Added config status indicators for both PDS and Graphic Hub. (VPE-3099)
  • Added the ability to sort Templates by modification date. (VPE-3120)
  • The default graphic hub is now used when the graphic_hub_url setting is empty. (VPE-3272)
Architectural Changes
Before using Scene Import, it's recommended that you save your scenes with a Viz Artist 3.14.2 or later.
You can re-save multiple scenes with a single operation using the Graphic Hub Manager:
images/download/attachments/61145648/resave.png
Known Issues
  • Map fields aren't picked up from scenes during scene import. They need to be added manually in the Model Editor. (VPE-3296)
  • Editing a variant created in Template Wizard will reset its external ID, description and category. (VPE-3307)
  • Scrolling through a long drop-down list (tags or concepts) with arrow keys doesn't always bring items into view. (VPE-3196)
  • In some special cases, parts of the header UI may be hidden from view if your browser window is too small. (VPE-3228)
Documentation
Documentation for Template Builder is available at the Vizrt Documentation Center:
Support
