Configure the Studio
This section details how to configure the Virtual Studio.
Click Open to select a previously saved studio configuration, or create a new configuration by clicking Save As.
Set the Frequency frame rate:
50 Hz -
60 Hz -
59.94 Hz
Set the Synchronization base:
Freerun: No synchronization. Tracking Hub runs using its own time base, corresponding with the configured frequency. Should not be used in production environments.
AV-Card: For Plura PCL-PCI and PCL-PCIe sync cards.
Viz Engine: Synchronized with Viz Engine, running on the same computer.
Go to Configure Topology.
