Modify a Rig
If a Tracking System parameter does not equal a Viz Engine parameter, a Viz Engine parameter can be modified to adapt to the Tracking System parameter.
This section contains the following topics and procedures:
To Modify a Rig
Right-click on a Tracking System. Select Connect to a rig.
The Tracking parameter routing window opens.
The Tracking System panel shows all the parameters that can be tracked
The Rig panel shows the Rig connections
If a Tracking System parameter does not equal a Viz Engine parameter, a Viz Engine parameter can be modified to adapt to the Tracking System parameter. Click on a Viz Engine parameter and drag to its new position, as required. If a red cross shows, after a parameter has been modified, it means that the connection is still valid, but the connection is now a cross-over connection and not a straight one.
In the Offset column, define an offset to each parameter. The values are given in cm or degree ( value with dot). The values are stored when the field loses focus.
In the Delay column, enter how many fields sending of the parameter should be delayed.
Click on a box under Connected to connect a parameter through the Rig.
Click OK.
No Tracking Parameters
If the Tracking parameter panel empty, there are no tracking parameters delivered from the tracking system.
Check what the icon of the tracking system shows (disconnected or connected, color, etc.)
Check all connectors until the required connections show in the Tracking Parameters panel.
Go to To Modify a Rig
