![](assets/images/logos/VizVirtualStudioLogo.png)
Tracking Hub and Studio Manager Release Notes
Tracking Hub / Studio Manager 1.3.1
Release Date: 2019-08-19
These are the release notes for Tracking Hub and Studio Manager version 1.3.1. This additional section describes the changes that have been done to the software since release 1.3.0.
Important: If you work with Viz 4.0, this is the first version which supports Cyc and CoCyc handling.
New Features
Summary |
Key |
Tracking Hub / Studio Manager 1.3.0
Release Date: 2019-07-30
These are the release notes for Tracking Hub and Studio Manager version 1.3.0. This document describes the user-visible changes that have been done to the software since release 1.2.0.
Minimum Hardware Configuration
Minimum 16 GB Ram
Dual-Core Intel CPU
10 gigabytes free disk space
OpenGL Hardware-accelerated Graphics Card
Recommended Hardware Configuration
32 GB Ram
Quad-Core Intel CPU
30 gigabytes of free disk space
NVidia P2000 Graphics Card
Supported Drivers and Software
This software has been tested to run on:
Windows 7 64-bit
Windows 10 64-bit
VizEngine 3.7.2 or later
Version 5.34 for Plura PCL-PCI and PCL-PCIe (LV, 3G) timecode reader cards (available on the Vizrt FTP in Vizrt Drivers/Alperman PCL).
SafeNet Inc. Hardlock Key driver Version 7.41. The driver is included in the installation package.
WIBU Codemeter 6.60a. The driver is included in the installation package.
Attention: 1.3.0 is the last Version of Tracking Hub and Studio Manager with 32-bit support. Future Releases will only be available in 64-bit!
Certified Tracking Systems
Shotoku
Motion Analysis
NCam
Egripment (Trackmen)
StypeKit
Vinten
Free-D
StarTracker
Vicon tracking system
XPecto
Thoma
BlackCam
Spidercam FrameB
Installation
Administrator privileges are required to install Tracking Hub/Studio Manager.
If the license dongle driver reports errors, please uninstall and reinstall the driver manually.
Known Issues
Visual representation of multiple camera usage for Motion Analysis during lens range calibration.
Localhost should be allowed always as option for network connection.
New Key Features
New Features
Support
Support is available at the Vizrt Support Portal <http://case.vizrt.com/>
Documentation
Documentation for Tracking Hub and Studio Manager are available at the Vizrt Documentation Center:
