The Configuration Service signs you in through Microsoft Entra ID, your organization's identity provider (OIDC). Use the same credentials you would for any other application connected to that provider.
First Sign-In
  1. Open https://<vam-host>:30443/config in a browser.
  2. Click Sign in with Single Sign-On.
  3. You are redirected to your identity provider's sign-in page.
  4. Enter your credentials.
  5. After successful sign-in you are redirected back to the Configuration Service and land on the Packages view.
Adding Users
Users, passwords and roles are managed in your identity provider, not in the Configuration Service. To give a user access, assign the user, or a group that the user belongs to, the roles that VAM expects: vam to use VAM, readwrite to work with the stored media and vam-admin to use the Configuration Service. A user without the right role signs in and then cannot do anything. See Identity Provider Setup > Assign Users and Groups.
Roles
The Configuration Service requires the role vam-admin on every request. The role grants full access: installing, upgrading and uninstalling packages, changing platform settings, taking and restoring backups and viewing cluster health. There is no read-only tier, so a user without vam-admin can sign in but cannot use the Configuration Service. All roles are listed in Identity Provider Setup > Define the App Roles.
Signing Out
Use the account menu (the avatar in the top-right) and choose Logout. You are returned to the sign-in page. Depending on your identity provider's settings, your session at the provider itself may remain. Sign out there too if you are on a shared computer.
Trouble Signing In
See Troubleshooting the Configuration Service > Cannot Sign In. For identity provider problems, such as a redirect URI mismatch, missing roles, an expired client secret or an access denied error from storage, see Identity Provider Setup > Troubleshooting Sign-In.
